Originally posted by keang
BenQ E900W 19-inch LCD Monitor
จอตัวนี้เป็นของเพื่อนคนนึง ถ้าจำไม่ผิดน่าจะซื้อเมื่อปีต้นปี2009 (จอตัวนี้ผลิตปี2008)
เดิมๆก็ใช้งานได้ปรกติ ไม่มีปัญหาอะไร แต่ไหนๆขอเค้ารื้อดูไส้ในแล้ว ก่อนส่งคืนก็เลยโมดิฟายให้ด้วยเลย
The BenQ E900WA features a black matte finish front bezel with a small silver strip running below the panel. Standing on a relatively small -- but sturdy -- stand, the E900W measures a good 391.6x448x179.4 mm (LxBxD; depth including the stand).
The E900WA has a WXGA+ 19-inch panel with a viewing area of 408.24x255.15 mm. It supports a maximum resolution of 1440x900 pixels, with a pixel pitch of 0.283 mm. The screen has a response time of 5ms and can display 16.2 million colors.
The brightness is a standard 300cd/m2, while the contrast ratio is 700:1. The viewing angle is 160 degrees -- both horizontally and vertically.
The monitor has a D-Sub (VGA) connector but sadly, no DVI-D port. Maybe, it's a cost-cutting thing; but it doesn't make any sense, since DVI-D is more suited to LCDs and gives better image quality.
Although BenQ's official Web site doesn't mention anything about integrated speakers on the E900WA, a couple of them lie hidden under the front panel. I guess they would be around 1W each. It also has a headphone jack on the right.
Neatly labeled OSD buttons are placed above the headphone jack on the right side and can be accessed quite easily; however, mastering how to press the right buttons takes some time.
Other features in the E900WA include BenQ's proprietary Senseye+Photo Technology that gives four preset modes -- Standard, Dynamic, Movie, and Photo -- providing instant optimized settings for different usage scenarios. Senseye+Photo is an enhanced version that adds an sRGB mode to support the industry-standard sRGB color space, allowing you to obtain consistent results when you view and manipulate images on an E Series monitor and on other sRGB-compliant devices.
PARTS standard ( ViewSonic รุ่นVX2240W ก็ใช้ บอร์ดพาวเวอร์ซัพพลาย กับ บอร์ดวิดิโอ ตัวเดียวกัน )
PARTS modify
- บอร์ดพาวเวอร์ซัพพลาย
- บอร์ดพาวเวอร์ซัพพลาย - ไฟเลี้ยงพาแนล
- บอร์ดพาวเวอร์ซัพพลาย - ไฟเลี้ยงบอร์ดวิดิโอ + แอมป์ขยายเสียง(ใช้ไอซีแอมป์ขับลำโพง)
- อะหลั่ยของเดิม ที่ถอดออก (ในรูปขาดCไปอีก1ตัว)
ผลลัพท์ที่ได้ :
- การแยกระดับของgray scaleดีขึ้นกว่าเดิม สีดำก็ดำสนิทกว่าเดิม สีขาวก็ขาวกว่าเดิม
- ภาพสว่าง และ สีเนียนขึ้นกว่าเดิม
- น้ำเสียงนุ่มนวลกว่าเดิม ให้น้ำหนักเสียงได้ดีขึ้น
PARTS modify
ผลลัพท์ที่ได้ :
) ซะเล็กน้อยก่อนขั้นต้น
พึ่งจะซื้อมา แต่เสาร์อาทิตย์ นั่งฟังๆ มองๆ ก็โดนซะนิดนึงล่ะ
หาเรื่องไม่อยู่สุข
ยังครับ แค่ประมาณครึ่งเดียวเอง 55+
