D.I.Y.ตอน เครื่องขยายเสียง
  • Originally posted by m shifu View Post
    อย่างที่บอกนะครับว่า L กะ C นี่ ถือว่าเป็นสิ่งมหัศจรรย์ของโลก
    โจทย์ง่ายๆที่ผมตั้งนี่ เป็นตัวอย่างนึงที่บอกความมหัศจรรย์ของมันครับ
    ผมเฉลยคำตอบนะ
    1. infinity ohm
    2. 0 amp.
    3. 0.628 amp.
    4. 0.628 amp.
    จากคำตอบนี้ จะเห็นว่า แอมป์ไม่ได้จ่ายกระแสเลยแม้แต่นิดเดียว
    แต่ L กะ C มีกระแสไหล 0.628 amp. ทั้งสองตัว (มาจากไหน ได้ไง!) งงมั้ย
    นี่คือความมหัศจรรย์ของ L กะ C ครับ
    สงสัยได้งง..อีกยาวๆครับ
    • Comment
      • The ferrite ring is wound like this:
        The main winding is 300 turns of AWG #30 enamelled copper wire with a diameter of 0.255 mm. Please notice the gap between the ends of that winding. That gap is important as high voltage is developed between the two ends of the winding and if the winding were continued all the way round the toroid, then the insulating enamel coating the wire would be liable to burn out due to the very high voltage difference between the first and last turns, causing a short-circuit. The two other windings are with AWG #24 enamelled copper wire which has a diameter of 0.511 mm and those two windings are positioned closely side by side in the middle of the gap between the ends of the 300-turn winding. The circuit is like this:
        The optional 25 ohm wire-wound variable resistor wastes power but creates a voltage drop across it, reducing the voltage reaching the circuit and so, dimming the light progressively, all the way down to zero. The base resistor ?R? has been set at 22 ohms by ?Lidmotor? who says that it really should be 100 ohms but he has lowered it to get brighter lighting. Please note which side of the 3-turn and 13-turn windings are connected in the circuit as the direction of winds is very important for those two windings.
        It is not uncommon for people to comment on the faint whistling sound make by a Joule Thief circuit (especially a low-voltage version like this). It is my experience that the sound is caused by the transistor resonating with the frequency of oscillation of the circuit, the TIP3055 being particularly prone to this. I suggest therefore, that bolting on a heat sink (which is most definitely not needed to dissipate heat produced by this circuit) will alter the resonant frequency of the transistor/heat sink combination and so stop the whistling.
        ทีมา
          โนเกีย(ก่อนเกือบเจ้ง) เคยทำมือถือพวกนี้ออกมาเป็นต้นแบบอยู่ครับ ใช้การเหนี่ยวนำของคลื่นในอากาศ ผ่านขดลวดมาเป็นพลังงาน
          อยากลองทำแบบนี้ แต่บ้านเรา(แถวบ้านผมด้วย)หาซื้ออุปกรณ์ยาก - -
          • Last edited by tiger X-fi; 2 Nov 2014, 15:22:45.
            • Comment
              • ชอบดูแบบนี้....แสงสีเยอะดี
                • ท่านเสือ ขยันจริงๆ
                  วงจรเค้าพิศดารดี
                  กว่าวงจรพวกนี้จะลงตัวได้ ไม่หมูนะครับ ต้องทดลองเยอะ
                  มีคลิปท้าพิสูจน์กะวิดวะด้วย อิ อิ
                  • ชอบไฟน่ะครับ....แต่มอเตอร์เล็กๆนี่น่าทำเล่นดู
                    อันนี้ดูแล้วง่าย น่าลองทำเล่นดู
                    • มันโหดมากกกกกกกก
                      • ราคา..หรือว่าไร....-
                        เมนบอร์ดอัพเรื่องเสียงหน่อย ราคาแพงมาก
                        ส่วนต่างผมยังว่าเล่นเมนบอร์ดที่ถูกกว่า
                        แล้วใช้กา์ดแยก ให้เสียงทีดีกว่าครับ
                        ชิพ น่าจะตัวเดียวกันกับ
                        Creative Sound Blaster Recon3D
                        Recon3D ผมว่าน่าจะเหมาะทำออนบอร์ดอยู่แล้ว
                        • ผมเคยลองทำครับกะว่าจะเอาเป้นโปรเจคจบ(ปวช.) มอเตอร์ 2 ตัว - - แต่มันเอาไปใช้งานจริงไม่ได้
                          เวลามีการดึงกระแส ของมอร์เตอร์อีกฝั่งมาใช้งาน มอเตอร์จะเกิดแรงต้านแล้วหยุดไปเลย - - แต่ถ้าต่อพวกกินกระแสน้อยๆ อย่างหลอดไฟ(LED หลอดเดียว)ก็พอได้อยู่ครับ
                          ไปๆมาๆ - - เหมือนมันเอาไปต่อยอดไม่ได้(เอาไปใช้งานจริงยาก) เลยเปลี่ยนโปรเจคเลย 555+
                          • Comment
                            • Originally posted by tiger X-fi View Post
                              ที่ผมสนใจ DAC-UP USB2 ครับ
                              ทั้งบอร์ดดูอยู่แค่ตรงนั้นล่ะ555
                              • มันก็แค่นี้เอง
                                จริงๆก็มีคนแรงจ่ายไฟภายนอกให้ไปใช้แทนของusbแล้วน่ะ(ยังต้องทำให้มีส่วนdetection pull downอยู่คือดึงไฟusbนิดหนึ่ง ไว้ให้รับรู้ว่ามีการเสียบอุปกรณ์แล้ว)
                                หรือเคยเห็นของคุณDracoVแว่บๆทื่ทำisolationอะไรสักอย่าง
                                ทั้ง2แบบรูป-ลิ้งค์อยู่ไหนก็ไม่รู้แหล่ะ (ขออภัยขี้เกียจหาอยู่)
                                ทำ1ใน2แบบนั้นน่าจะตรงโจทย์กว่าน่ะ ถ้าจะเอาแค่ไฟจากusbแบบดีๆหน่อยอ่ะน่ะ แต่ถ้าเอาฟังชั่นอื่นด้วยก็อีกเรื่อง (พูดในแบบคนที่DIYทำกันเองได้น่ะ)
