In conversion between digital and analog signals, the sampling frequency is normally assumed to be constant. Samples should be converted at regular intervals. If there is jitter present on the clock signal to the analog-to-digital converter or a digital-to-analog converter then the instantaneous signal error introduced will be proportional to the slew rate of the desired signal and the absolute value of the clock error. Various effects[specify] can come about depending on the pattern of the jitter in relation to the signal. In some conditions, less than a nanosecond of jitter can reduce the effective bit resolution of a converter with a Nyquist frequency of 22 kHz to 14 bits[citation needed].
This is a consideration in high-frequency signal conversion, or where the clock signal is especially prone to interference.
ถ้าพาดพิงอื่นๆ ถึงส่วนdigital นี้เอาเห็นผลแรงกว่าสาย
c couplingสัญญาณขาเข้า digital
DACบางตัวมี ลองเปลี่ยนดู
