โมให้ดีกันเยอะแล้ว มาม๊ะ....มาโมให้"เจ๊ง"กันดีกว่า
  • แสดงว่าเอามาใช้กับไฟ AC ไม่ได้
    ไฟบ้านนี่เลยครับ...จะเสริมไปในปลั๊กไฟ
    อ่านแล้วเลิกล้มความคิดแล้วครับ....555+
    • ดูขนาดตัวC เทียบกับมือฝรั่ง
      John McDonald, President, weight lifting a 5uF/3,000 volt Auricap. His secret to that muscular build!
      C เค้าใช้ค่าทนไฟ 1.5KV (1,500v)
      (จำได้ว่าเคยโพสไส้ในตัวนี้ลงกระทู้ไปแล้ว ไม่แน่ใจว่ากระทู้นี้ หรือ กระทู้DIY 40วัตต์)
      Audience enjoys a well-deserved reputation among audiophiles as a manufacturer of high performance, good value interconnects, speaker cables, power cords and Auricap capacitors. The adeptResponse represents the company's first foray into power line conditioning and it is an auspicious entrance at that.
      The adeptResponse is a transformerless conditioner featuring twelve fully isolated Hubbell HBL 52662R outlets, chosen for their mechanical design and current-handling capacity. Each outlet sports its own individual circuit and the usual jumpers that connect the two outlets of each duplex have been removed. Isolation is further enhanced by the fact that unwanted high frequency noise between outlets must pass through three filters. According to the manufacturer, the isolation provided is sufficient to protect individual components from the hash associated with digital sources even when an entire system is fed from the adeptResponse. Nothing during my long term listening in three different systems indicated otherwise.
      Transformer-based power conditioners provide good filtering but often limit power transfer to result in a loss of current to power amplifiers. The net effect is an overall reduction in dynamics and one reason why many users of power conditioners do not plug their amplifiers into them. Audience recently made available test results that indicate that their conditioner exhibits virtually no DC resistance (roughly 44 milliohms with their powerChord attached). The adeptResponse is also a partial power correction device. Audience claims that not only does it not compromise system dynamics, perceived dynamics actually increase.
      Pricing for the new Audience Adept Response power conditioners is as follows: aR2-TS - $4,100, aR6-TS - $5,000 and aR12-TS - $8,600. Owners of a previous aR6 or aR6-T can have their power conditioners upgraded to include the new ground plane for $450, and $650 for the aR12 or aR12-T. (Units that have a ?G? in the serial number already have the new ground plane.)
      REVIEW
      > 6moons audio reviews Audience adeptResponse
      > Power Corrupts More Than We Ever Knew -- Jack Roberts' Quest for Clean AC Part Two: Audience's New aR6-T Power Conditioner
      รุ่นแพงสุด ใช้Cยี่ห้อ"auricap"เหมือนเดิม แต่เปลี่ยนเป็นรุ่นTeflon
      aR12-TSS2 : $9,995 (with powerChord e)
      aR6-TSS2 : $6,000 ? (with powerChord e)
      ที่คุณเสือคิดไว้ ทำได้ครับ ถ้าเงินเหลือพอ จะใส่ปลั๊กพ่วงหรือในเครื่องก็ได้
      ลองสนุกๆ NPEซื้อC Audyn ค่า5-10uF ค่าทนไฟ1,000v 4ตัว ต่อที่ขดไฟเข้าของหม้อแปลงในเครื่อง แล้วลองฟังดู
      ค่าความจุน้อยแบบนั้นคงไม่ได้ช่วยเรื่องไฟนิ่งเท่าไหร่ แต่ความแตกต่างที่ได้จะเป็นจากCที่ใช้
      แต่อยากบอกว่า มองต้นตอของปัญหาผิดจุดไปน่ะ ที่ไฟไม่นิ่งไม่พอเพราะหม้อแปลงมันตันมันไม่ได้ตามสเปคที่ควรจะเป็น
      หม้อแปลงที่ใช้ๆกัน ลูกมันเล็กไป คุณภาพของลวดที่ใช้พันก็จ่ายฉับพลันได้ไม่ดี + เส้นเล็กไป
      ถ้าจะเอาแบบงานอดิเรกยามว่าง
      หาโครงหม้อแปลงแบบEI เอาตัวใหญ่ๆเลย ขนาดเท่าหม้อแกงใบเล็กก็พอ จะได้ใช้ลวดเส้นใหญ่ๆได้
      รื้อโครงเดิม แกะEIเป็นชิ้นๆแผ่นๆ แล้วเอามาประกอบใหม่ พันลวดเอง
      • เรื่องหม้อแปลงนี่งานช้างไปครับ...แต่ถ้ามีโอกาศอาจได้ทำเล่นบ้าง
        ถ้าตามแบบนี้ นึกถึง C oil (มีขั้ว) ซึ่งราคาไม่แพงมากพอทำได้
        แต่กลัวเหมือนกัน Cตัวใหญ่ๆกลัวบึ้ม ก็เลยมาลองถามดูก่อนน่ะครับ
        ไม่ได้หวังผลมากมาย...ขอเพียงดีกว่าเดิมก็พอแล้ว
        ภาพด้านบนจำได้..เมื่อวานหาไม่เจอเหมือนกัน...พยามหาอยู่น่ะครับ
        C Audyn ค่า5-10uF ค่าทนไฟ1,000v คล่อม +- ได้เลยมั๊ยครับ
        เดี๋ยวลองดูที่ปลั๊กไฟน่่ะครับ
        ขอบคุณมากๆครับ
        • Originally posted by tiger X-fi
          ท่องให้ขึ้นใจเลยครับ
          ไฟAC ห้ามใช้Cมีขั้ว เด็ดขาด เพราะบึ้มแน่นอน
          ใส่คร่อมที่ขั้วLกับNได้เลยครับ ถ้ามีเวลาเหลือก็ลองสลับด้านCแล้วฟังเสียงเทียบกัน
          ลองแล้วมาเล่าให้เพื่อนๆฟังด้วยน่ะครับ
          ตอบที่คุนเสือถามไว้ข้างล่าง
          ถ้าเป็นแบบนี้ ตรงกลางยังเป็น กราวน์อยู่หรือป่าวครับ
          คุณเสือสับสนระหว่างไฟDCกับAC
          ACจากเมนการไฟฟ้า แบบ2เฟสตามบ้านคนใช้ทั่วไปตามปรกติ จะมีแค่2เส้นLกับN
          L กับ N = ขั้วบน-ล่าง (+หรือ- ตามรูปของคุณเสือ)
          EARTH GROUND = กราวน์ดิน (GND ตามรูปของคุณเสือ) / ไม่ใช่ศักย์ไฟกราวน์ของระบบไฟAC 220v
          L คือ เส้นที่การไฟฟ้าใช้สำหรับจ่ายศักย์ไฟ220vac มาให้ตามบ้าน
          N คือ เส้นที่การไฟฟ้าใช้สำหรับเทียบศักย์ไฟกับL โดยเปรียบเสมือนเป็นขั้วGNDของขั้วL
          • ถ้าเป็นแบบนี้ ตรงกลางยังเป็น กราวน์อยู่หรือป่าวครับ
            C Audyn ค่า5-10uF ค่าทนไฟ1,000v ลองแล้วจะมาเล่าครับ
            ขอบคุณมากครับ
            คือผมจะเปลียน 2ขา(เข้า) เป็น3ขา(ออก)
            ถ้างั้นตัวที่ผมถาม=EARTH GROUND = กราวน์ดิน
            เริ่มตรงนี้ลงดินได้เลย(ตรงกับความต้องการ...เผื่อได้กราวน์กระถาง)
            ถ้าตรงนี้ไม่มีปัญหา ..เดี๋ยวไม่นานได้ทำครับ
            (แบบกล่อง-สาย-หัวอยู่ในหัวแล้ว..ทำไม่ยากด้วย)
            ขอบคุณมากครับ
            ด้านล่าง
            เข้าใจหลักการทำงานแล้วครับ
            (ตรงกับความต้องการ...เข้าใจผิดว่า มันสำรองกระแส)
            ขอขอบคุณอีกครั้งครับ
            • แก้ไขรูปคุณเสือใหม่ เพื่ออธิบายการทำงาน
              - ตัวเก็บประจุแบบไม่มีขั้ว 5,000uF + 0.1uF ทำหน้าที่รับสัญญาณรบกวนจากขั้วL,N ให้ผ่านไปที่ขั้วEarth Ground
              ความถี่ของสัญญาณรบกวน จะสัมพันธ์โดยตรงกับค่าความจุและชนิดของตัวเก็บประจุ
              - ตัวเก็บประจุทั้งสองตัว ไม่ได้ทำหน้าที่สำรองไฟเลี้ยงให้ขั้วLกับขั้วN
              ถ้าจะใช้ตัวเก็บประจุเพื่อทำหน้าที่สำรองไฟ ต้องใช้ตัวเก็บประจุแบบไม่มีขั้วต่อคร่อมขั้วLกับขั้วN
              • ตัดจุดเชื่อมต่อแค่จุดเดียว...หลักการทำงานเปลี่ยนเลย
                ตรงนี้ผมเข้าใจถูกต้องมั๊ยครับ
                ตรง ทำหน้าที่สำรองไฟ
                เราเอาตรงนี้มาใช้กับแอมป์
                วางไว้หน้าหม้อแปลง(ก่อนเข้าหม้อแปลง)
                ได้ด้วยมั๊ยครับ
                คงต้องยอมลดค่าครับ ไม่มีขั้วราคาแพง
                มีขั้วถูกกว่าเยอะหาค่าสูงๆหน่อยเอา(เอามาทำไม่มีขั้ว)
                ทำให้เข้าใจอะไรเยอะเลย
                นิดๆหน่อยๆนี่ต่างกันเยอะเลย..เปลี่ยนหน้าที่เลย
                ขอบคุณอย่างสูงเลยครับ
                • ใช่ครับ
                  แต่ตัวเก็บประจุ5,000uF ให้ต่อแบบขนานแทนน่ะครับ จะได้เพิ่มค่าความจุสูงขึ้น
                  (ในรูปต่อแบบอนุกรม ค่าความจุลดลง)
                  • เอามีขั้ว2ตัวกันมาต่ออนุกรม ใช้กับไฟacได้มั้ย
                    • อนุกรมแบบแปลงเป็นBPใช้ไม่ได้ครับ ต้องเป็นNON-Polarเท่านั้น
                      • Originally posted by ManiacMaew View Post
                        ถ้าแบบปกติ เสียบปลั๊กกลับข้าง...บึ้มแน่
                        ถ้าต่อแบบไม่มีขั้วน่าจะได้ครับ
                        ไปดูมาแล้ว C oil VAC ค่าสูงๆไม่มี
                        สงสัยต้องใช้ C 450VDC แทนครับ
                        ราคาก็ไม่ถูกเหมือนกัน
                        วันนี้ซื้อ Rubycon 300uf/450VDC 85องศา
                        เดี๋ยวลองดูก่อนว่าบึ้ม...ไม่บึ้ม...
                          เตรียมโล่ห์กำบังไว้ล่ะ
                          ________________
                          ฉนวน สายไฟ สายสัญญาณเปล่ามันมีขายมั้ย ถ้ามีที่ไหนบ้าง
                          ใครพอทราบรบกวนหน่อยครับ
                          • tda1541 vs pcm1793 คิดว่างัยอ่ะครับ
                              ________________
                              ยังไม่ได้ลองเลยครับ
                              ปลอกยางสายไฟ..เคยเห็นว่ามีขายหน้าคลองถมครับ
                              • Clarion PP-3091H อัพเดท
                                > หน้า138 #2756
                                เปลี่ยนNJM2060ของJRC เป็นเบอร์ใหม่
                                บัดกรีแบบpoint-to-point ขาของตัวไอซีแอมป์ กับ ขาC inputชนิดFilm ตัวเหลืองข้างเขียว
                                > หน้า148 #2949
                                ขาตัวCฟิลม์ ดัดม้วนรอบขาตัวICแอมป์1รอบ เพื่อเพิ่มหน้าสัมผัสที่มากขึ้น และเพิ่มความแข็งแรงให้กับจุดบัดกรี
                                Cฟิลเตอร์ ไฟเลี้ยงชิบIC Amp
                                ( เดินดูทั่วบ้านหม้อ หาของดีที่ถูกใจไม่ได้สักตัว จัดหนักใส่Rubycon Black Gateซะเลย )
