Version 5.6.1-Service release (July 3, 2015)
New:
- New: Private SNMP MIB
- New: IPv6 support
- New: Manage custom scriptsโ?จ- New: Extend Statistics reporting - TX/RX reporting improvementโ?จ- New: Extend Statistics reporting - Latency for each Station
- New: Statistics - ACK/Distance display
- New: Report remote TX power in AP/STA info
- New: Show RX Signal per Chain
- New: Add firmware prefix reporting for any model (TI/XM/XW)
- New: Display actual operating frequency range in MAIN page
- New: Show radio mode in Site Survey scan results
- New: DHCP address reservation
- New: Implement QOS for VLANS
- New: Increase password length to more than 8 symbols
- New: Increase MTU/MRU to 1500 bytes for PPPoE (server must support max-payload tag)
- New: airMAX devices will support only WPA-AES/WPA2-AES security (WEP optional for AP-Repeater mode)
- New: Channel shifting is removed. Frequency selection in 2MHz/5MHz steps available when in airMAX mode
- New: TCP support for remote system logging
- New: DynDNS More providers supportย
- New: Linux kernel update to 2.6.32.65
- New: Upgrade lighttpdย 1.4.35
- New: Update hostapd/wpa_supplicant to the latest available stable version (v2.1 final)
- New: Upgrade libevent to 2.0.22
- New: Upgrade dropbear to v2014.63
- New: Upgrade OpenSSL to 1.0.2a
Fixes:
- Fix: Device hangs on startup when DHCP relay is enabled on two LAN interfaces
- Fix: Long Range PTP mode stops passing traffic on high load (XW)
- Fix: Sometimes AP canโ?t change channel after RADAR detection
- Fix: airGW provisioning creates wrong forward rules in case of PPPoE client configuration on WAN interface
- Fix: Broadcast goes from one STA to another STA even if Client Isolation function is enabled on AP
- Fix: Report DFS Wait or DFS Radar in MAIN page
- Fix: AP drops all stations. Recovers after reboot. (XW)
- Fix: Crash during upgrade from v5.5.x when parsing incorrect IPTABLES rules
- Fix: Update EIRP limits for Australia according channel bandwidth
- Fix: Allow 0.0.0.0 Fallback IP for PPPoE client configuration
- Fix: Various DFS and Frequency List usage improvementsโ?จ- Fix: Speed test low values when using Management VLAN
- Fix: DFS improvements for Czech Republic
- Fix: airSelect can use only non-DFS frequencies
- Fix: No full-restart when changing ACL list first time after upgrade to v5.6.x
- Fix: Wrong 32 symbols SSID reporting to airControl
- Fix: Remote statistics reporting to client keeps Android phone wake up all the time
- Fix: Update EIRP limits for Brazil
- Fix: PPPoE MTU/MRU limited according to parent interface settings
- Fix: Traffic stops after Site Survey execution on remote Station when hidden SSID is set on AP
- Fix: M900 radio fails initialisation in heavy noise environment
- Fix: STA Device Name is truncated in SNMP reporting
- Fix: SNMP string sizes
- Fix: Station can't connect to AP with Hidden SSID (XW)
- Fix: Discovery response leak across VLANs
- Fix: Station shows wrong "TX Signal" in AP details window
- Fix: The same channel numbering for 4920-5000MHz and 5920-6000MHz (Compliance Test).
- Fix: Disable UPnP SSDP messages in Syslog
- Fix: Main tab is empty if device name contains <tab> symbol
- Fix: Scan results buffer size limit issue (at ~200 APs found)
- Fix: Reduce TX power to the EIRP Limit when radio is operating in Station mode or Auto frequency selection is chosen for AP
- Fix: Speedup DHCP and PPPoE clients to update IP settings after successful WPA authentication
- Fix: SSL v3 POODLE vulnerability
- Fix: Add 5GHz frequencies for Kazakhstan
- Fix: Validate ping interval for Ping Watchdog. It canโ?t be set to 0 sec.
- Fix: Improved Wireless page loading routineโ?จ- Fix: AirMax Capacity/Quality calculation/reportingย with Fixed Ratesโ?จ- Fix:ย TX flow control and multi queue support. (XW)
- Fix: Error after run Speed Test (XW)โ?จ- Fix: ACK/Distance miscalculation when connecting to XM AP. (HT8, HT30, XW)โ?จ- Fix: AP/STA performance issues (XW, airMax)โ?จ- Fix: HT20 Rates are reported/used when device is configured to operate in HT40 and fixed rate is selected. Alternative rate module selectedโ?จ- Fix: Site Survey does report the same NF value for each channel (XW)โ?จ- Fix: Strange AirView view on Rocket M5 Titanium (XW)โ?จ- Fix: airSync does not work with fixed rates (XW)โ?จ- Fix: Radio has to fallback to full channel list if configured Frequency List is enabled but doesn't contain valid frequencies (XW)โ?จ- Fix: Remote Syslog message type is "unknown"โ?จ- Fix: Last IP isn't taken from VLAN tagged packets (XW)โ?จ- Fix: RADIUS accounting issue (XW)
- Fix: Selecting SSID on HT40 may change Channel width from 'Auto HT20/40' to 'HT20'โ?จ- Fix: Disable ACK slider if AirSync/Long range PtP selectedโ?จ- Fix: Antenna alignment tool (beeper) crashes on iPhone, iMac, etc.โ?จ- Fix: Don't suggest WPA key as Username for login save (Firefox)โ?จ- Fix: Wireless page is broken (IE8/9)
- Fix: XW: Improved Data Rate selection for Default rate algorithm when operating in noisy environment
- Fix: Remove 924MHz (shifted frequency) as itโ?s out of allowed band range (10MHz channel width)
- Fix: Add full product name in discovery reporting
- Fix: AP crash with Multicast Enhancement enabled and specific multicast traffic on STA association
- Fix: Scan results ageing issue
- Fix: Ping tool doesnโ?t execute ping in 1sec interval
- Fix: Ping tool ping count is sometimes higher than defined
- Fix: Unable to set empty PPPoE password (Chrome specific)
- Fix: Proper antenna polarisation selection for 802.11abg support
- Fix: Some frequencies were missing for India when 30MHz channel width is selected
- Fix: Improved association with older devices
- Fix: Escape quotes for Device Name and SSID in Station List
- Fix: Make โ?Feed only -3dBiโ? as default antenna selection for appropriate models
- Fix: XW: WPA2-PSK Association time out in case of long channel list
- Fix: Min TX Power for NanoBridgeM5 should be -8dBm
- Fix: Discovery returns wrong product name
- Fix: Speedtest duration validation in range [1-99]
- Fix: Reload newly uploaded configuration file
- Fix: ac-agent doesn't send GPS coordinates read from GPS module
- Fix: STA continuous crash when connecting to Apple AirPortย AP
- Fix: AP doesn'tย initiate re-authentication to RADIUS server when Station re-associates
- Fix: EAP TTLS/PEAP do not check time in TLS session
- Fix: WEB UI: Canโ?t logout on high CPU load
- Fix: Discovery shows empty Device Name if length is 64 symbols
- Fix: Italian translation updates
- Fix: Spanish translation updates
- Fix: Simplified Chinese translation updates
Improvements:
- WEB UI: Disable controls while Speed Test is in progress
- WEB UI: Show explanation after move mouse on RX/TX Signal labels
- WEB UI: Ordering by frequency improvement
- WEB UI: Site Survey results sorting improvements
- WEB UI: Update โ?Long Range PtP Modeโ? help message
- WEB UI: Change EIRP Limit warning message and Auto Adjust to EIRP Limit label
- WEB UI: Increase TEST mode timeout for DFS frequencies
- WEB UI: Donโ?t allow to select AP with unsupported security mode in Site Survey
- WEB UI: Port forwarding from LAN side when accessing WAN IP (NAT loopback)
