AMD Catalyst 14.12 WHQL (Omega) Far Cry 4 Up to 50% Call of Duty up 30%
  • #76
    280x อัพแล้ว ลองก่อนนิ
    • #77
      ลื่นขึ้น ทุกเกมเลย amd รอบนี้ driver ทำมาเยี่ยมเลย
      ก่อนลง ผม ล้างไส้ ของเก่าให้หมดก่อนแล้วลง ใหม่
      • #78
        vsr 4k for 1080p นี้มันปรับยังไงเหรอครับ การ์ด 7xxx สามารถปรับได้ไหม หรือปรับได้เฉพาะตระกูล r รบกวนท่านที่ปรับได้ชี้แนะหน่อยครับ
        ปล.ไม่ได้ลองเล่นอะไรมาก แต่รู้สึกลื่นขึ้น ส่วนใหญ่ใช้งานดูหนังอย่างเดียว .
        • #79
          VSR is AMD's answer to Nvidia's DSR tech
          by Cyril Kowaliski ? 11:01 PM on December 8, 2014
          In case you missed the big news, AMD has posted a new Catalyst release packed with new features?and one of the additions is Virtual Super Resolution, a technology that's very much like Nvidia's Dynamic Super Resolution.
          Cue shameless self-quotation:
          Like DSR, VSR renders games above the display's native resolution and then downscales them to fit. The effect is something akin to full-scene antialiasing, and at least in the case of DSR, it can pay real dividends in terms of image quality. The downside is, obviously, a high performance cost.
          VSR currently works only on Radeon R9 285 and R9 290 series graphics cards, and it supports the modes outlined in the matrix below. The feature can be enabled by ticking a checkbox in the Catalyst Control Center (under the My Digital Flat Panels section). Users can then select higher resolutions via in-game menus. Unlike with DSR, though, there's no way to dictate which scaling modes are exposed to games, and there's no slider to change the smoothness of the downscaling filter.
          Nvidia's DSR works on plenty of older GPUs, including the GeForce GTX 400, 500, and 600 series. Considering DSR also exposes smoothness and scaling multiplier controls, I'd say the Nvidia technology still has a leg up for the time being.
          AMD says it plans to add support for Radeon R-series cards from the R7 260 up, but only in a "phase 2" driver due in January or February 2015. The company says adding support for those lower-end cards requires it to "explore a new implementation vs. what's in Omega," which will "take additional time"?hence the delay.
          รุ่นอื่น รอ ปีหน้ามั้งครับ
          AMD Virtual Super Resolution เล่นเกมภาพคมชัด4k
          • #80
            ขอบคุณสำหรับข้อมูลครับ
            อดสิ่น้ะ TT
            • #81
              อดสิ่น้ะ TT
              กดเบาๆ http://www.overclockzone.com/forums/...B8%AD%E0%B8%87
              • #82
                Guild War 2
                3200*1800
                1920*1080
                • #83
                  TressFX Hair 3.0
                  AMD's proprietary TressFX hair graphics package is back with version 3.0. It grabbed a lot of attention when it was used for Lara's hair in the Tomb Raider reboot, but this update now adds fully-rendered fur support. It remains to be seen just how horrifyingly demanding TressFX Hair 3.0 is, but the thought of booting up Far Cry 4 with a bit of this would be difficult to resist.
                  ว่าแต่ มีใครเห็น หมี หรือยังครับ
                  ใครเล่น Far Cry 4 ช่วยไล่ล่า หมี มาให้ดูหน่อยสิ 55555+
                  • #84
                    อดลอง 4K สินะ 280x T_T
                    • #85
                      ลองแล้ว. ลื่นขึ้นจริงๆแหะ แต่ไร้ประโยชน์สำหรับ gamer บางกลุ่ม ที่ชอบเล่นวันแรกที่เกมส์ออกจนเคลียร์หมดแล้ว กว่าจะออกไดร์เวอร์สมบูรณ์มา เคลียร์ไปเป็นสัปดาห์แล้วพี่ ยิ่งขรรม ที่บอก RE5 แรงขึ้น จะเล่นตลกกันไปถึงไหน ไม่เอามาริโอ้ให้แรงขึ้นเลยละ เกมส์เค้าเคีลยร์เป็นปี พี่ยังมานั่งแต่งไดร์เวอร์ให้อีกกำ
                      • #86
                        ของผม ลอง farcry 4(เถื่อน) นะ FPS เท่าเดิมเลยครับ 35-42 R9 290x oc นะ = =
                        ปล.ถอนติดตั้ง เซฟโหมด แล้วลงใหม่ก็แล้ว
                        • #87
                          ลื่นขึ้นจริงครับ ลองกับอีแก่ 7850 กับ Assassins Creed Unity,Shadow of Mordor,Farcry 4
                          • #88
                            Originally posted by THEFOOL View Post
                            TressFX Hair 3.0
                            เมื่อกี้ลองเกม ลื่นยังกะได้การ์ดจอใหม่ ก่อนออกมาโดนหมีตบตายเพราะ มัวดูขนสวยๆ ของหมีอยู่ครับ
                            • #89
                              ถ่าย หมี มาให้ดูหน่อย ขอบคุณครับ555+
                              • #90
                                มีแต่ของผมที่มีปัญหาหรือนี้ หรือว่าต้องซื้อแท้ เฮือกกก
