ดังแน่ล่ะท่าน osxp แต่ลมก็สุดยอดเหมือนกันไม่งั้นก็ลดรอบเอาอ่ะครับ
Brand : ADDA
Fan Model : ADN512HB-A91
Bearing Type : Dual Ball Bearing
Dimensions : 135 * 135 * 25mm
Fan Speed : 2,200 RPM
Noise : 39.6dBA
Airflow : 95.373 CFM
Pressure : 4.826 mmAq
Life: 100,000 hours (25 ํc)
Current 0.33A ( rated 0.18A)
Rated Voltage : 12V
Interface : Power Big 4D or 2-wire or 2P 3P
Cable length : 28CM
Features double ball bearing maintenance , long service life , sufficient cooling air volume and pressure
Applicable : 1U server fans , switches, Northbridge and grapcs card cooling transformation, memory heat transformation, and other uses
Brand : ADDA
Noise : 39.6dBA
Rated Voltage : 12V
Cable length : 28CM
