<<< +++ Intel Sandy Bridge i5, i7 CLUB +++ >>>
  • ตัวล่าง T_T
    เย็นกว่าแค่ ไม่เท่าไหร่ แต่กัดซะขนาดนี้ ครั้งเดียวพอ ^^
    • ลองดูกับเค้าหน่อย ร้อนไปนิดนึงนะครับช่วงนี้อากาศร้อนมาก ห้องธรรมดาไม่แอร์
      2600k@4.7 Vcore1.415 + P67A UD7 + Halem
      • Originally posted by Mamark_LFC View Post
        ผมว่า 2600K 4.7G ไฟ 1.4+ สูงไปนะคับ ลองลดลงมาที่ 1.38 ดูคับ
        เปิด Load line ไว้เปล่าคับ
        • BIOS ออกมาใหม่อีกแล้ว
          P8P67 Deluxe / Pro / EVO / Standard / Sabertooth - 1305 -
          Change Log -
          - Improved OC performance using Multipliers or Auto Overclocking
          - Improved BCLK and DRAM OC capabilities when enabling the “Internal PLL Overvoltage” option in BIOS. Note - Sleep/Hibernate will not operate properly due to Intel Specs.
          - Improved USB performance, Improved P67 XMP profile compatibility (please note, memory with X58/P55 XMP profiles will generally work but is not optimized for P67 and will usually cause problems when overclocking in several cases)
          - Per Core Save Fixed
          - Disable/Enable BT
          - Minor Bug Fixes including new Auto Rules for C-States (C3/C6) when overclocking. If you are overclocking, C-States will be disabled for enhanced performance.
          - Intel RAID will not support bootable volumes greater than 2.2TB yet, Intel plans a firmware update shortly to allow this operation. AHCI and IDE are not affected.
          - Enhanced AI Suite II compatibility
          Note - These UEFI releases will be on our FTP and Support Sites shortly.
          UEFI 1305 - Pro
          MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
          UEFI 1305 - Standard
          UEFI 1305 - EVO
          UEFI 1305 - Deluxe
          UEFI 1305 - Sabertooth
          1. Reset your UEFI to Optimized Defaults, reboot, enter UEFI and then flash to the new UEFI build.
          2. After flash and restart, shutdown the system before you enter Windows/Linux.
          3. Remover the power cord from the power supply, wait thirty seconds, press Power On button to clear any remaining charge, clear CMOS for five seconds, reattach the power cord, power on the system, enter UEFI, set to Optimized Defaults, save and exit.
          4. Enter UEFI, set your system to customized settings based on your system configuration (RAID, OC, etc), save and exit.
          Credit: http://hardforum.com//showthread.php?t=1578865
          • เชื่ออันไหนดีครับบบ
            • Originally posted by theix View Post
              2600k + P67A UD7 Bios F7
              ตอนที่ใช้ Load Line Lv2 + Vcore 1.385 จะเทส LinX ผ่านครับ แต่ถ้า Vcore 1.385 + Load Line Lv1 เทสไม่ผ่านซะงั้น
              Load Line Lv2 ที่ Vcore 1.385 แล้วมันร้อนมากกว่าตอนที่ใช้ Load Line Lv1 + Vcore 1.415
              และพอเปิด Load line Lv1 ใช้ Vcore ต่ำกว่า 1.415 จะเทส Linx ไม่ผ่าน ผมก็เลยเลือกเอาที่มันเย็นกว่า
              ใครพอจะอธิบายเกี่ยวกับการทำงานของ Load Line Lv1 กับ Lv2 ให้ผมกระจ่างทีครับว่ามันทำงานต่างกันยังไง
              เพราะเท่าที่สังเกตตอนที่เทส LinX cpu ทำงาน Full Load จะเห็นว่า Lv1 จะทำให้ cpu ลด Vcore ลงมาจากที่เซ็ท Vcore ใน Bios เอาไว้
              แต่ถ้าเป็น Lv2 ตอนที่ CPU ทำงาน Full Load มันจะเพิ่ม Vcore จากที่เซ็ทเอาไว้ใน Bios รอผู้รู้มาชี้แจงแถลงไขให้ทีครับ ขอบคุณครับ
              ตอนที่ LinX ตอนใช้ LoadLine LV1 + Vcore 1.415
              ตอนที่ LinX ตอนใช้ LoadLine LV2 + Vcore 1.385
              • ไม่ได้ OC นะครับ ช่วยดูให้หน่อยว่าปกติมั้ยครับ
                ถ้าจะ OC ต้องไปปรับอะไรบ้างครับ เห็นมันมีตัวเลือกเยอะมาก
                อยากได้สัก 4.8 อ้ะครับผม
                • ถามหน่อย ความร้อน cpu อย่าเกินเท่าไรกำลังดีอะครับ
                  • Originally posted by [B] View Post
                    ผมว่า 80 - 85 องศากำลังดีนะคับ
                      ผมคิดว่าคำตอบอยู่ในคำถามของท่านเองแล้วครับ
                      คิดเช่นนั้นเหมือนกันครับ
                      ข่าวดี P67A-UD5 ออกแล้ว TK & BANANA
                      • ถ้ารักที่จะโหด ก็ควรเลือก Load-line L2 ไว้อ่ะดีแล้วครับ เพราะมันรองรับการ OC CPU ที่ความถี่สูง ๆ
                        เหมือนรถที่ โมระดับ 500 แรงม้าขึ้นไปอ่ะ บางทีจะต้องเพิ่มรางหัวฉีดน้ำมันแต่ละลูกสูบ เพื่อที่จะจ่ายน้ำมันให้ได้ทันกับแรงม้า ที่เพิ่มขึ้น
                        แต่ก็ต้องยอมแลกกับอัตราการบริโภคไฟ (เอ้ย น้ำมัน) ที่เพิ่มขึ้นและความร้อนที่เพิ่มขึ้น ดังนั้น step โมต่อไป รถแรง ๆ เหล่านั้นจึงต้องเพิ่ม Intercooler ขนาดใหญ่ สำหรับระบายความร้อนที่เกิดกับเครื่องในขณะที่ใช้รอบและความเร็วสูง ๆ
                        computer เรา ๆ ที่ OC ระดับ 5 GB ขึ้นไปอย่าง Sandy หลาย ๆ ท่านจึงต้องเพิ่มระบบระบายความร้อน โดยใช้น้ำกันไงครับ ลมอย่างเดียวระบายไม่ทันละ หน้าร้อนเริ่มเข้ามาแล้วด้วย
                        ดูแลมันหน่อยละกันนะ ถ้าอยากโหด...
                        • เปลี่ยนรูปอีกและ ไม่ดูชื่อนี่ผมงงไปและครับ
                          มีดีอย่างนึงนะครับ ทำให้เรารักบ้านมากขึ้น ได้อยู่บ้านมากขึ้น
                          ได้ออกไปไหนน้อยลง ไม่ต้องกลัวขโมยเพราะเฝ้าบ้านตลอด
                          ป.ล ขอแอด msn ท่านparmafc นะครับ ^^
                          ~@~ปิดทองหลังพระ....พระราชดำรัส.~@~
                          ......พระเจ้าอยู่หัวทรงแย้มพระสรวล ก่อนที่จะมีพระราชดำรัสตอบด้วยพระสุรเสียงที่ส่อพระเมตตาและพระกรุณาว่า......
                          ~@~...ปิดทองไปข้างหลังพระเรื่อยๆ แล้ว ทองจะล้นออกมาที่หน้าพระเอง...~@~
                          sigpic
                          • Originally posted by Areyo View Post
                            ของไม่หาย แต่แฟนกำลังจะทิ้ง T^T
                            • Originally posted by mazaki01 View Post
                              สถานภาพเดียวกัน (ถ้าแฟนรู้นะว่าซื้ออะไรบ้าง) แต่ตอนนี้ยังไม่รู้ หุหุ
                                นอนกอดคอมฯดีแล้ว ไม่มีบ่น
