SmoothVideo Project (SVP) ออกใหม่แล้ว ช่วยให้ดูหนังแจ่ม โดยเฉพาะ อนิเม ลื่นไม่กระตุก
  • #46
    Originally posted by arnon9 View Post
    ทำไมมีไห้เลือกปรับเยอะกว่าผมนะ สอนตั้งค่าส่วนที่สำคัญหน่อยชิท่าน
    กำ
    คลิ๊กขวาที่ไอค่อน SVP แล้วเลือก interface type เลือกแบบ Expert ครับ จะปรับได้เหมือนของผมครับในรูปครับ
    • #47
      Originally posted by animeangel View Post
      สำหรับ anime ทางทีมงาน SVP แนะนำตามนี้ครับ
      แต่ผมก็ปรับของผมเองอยู่ดี lol
      แจ่มเลย ผมก็พึ่งเห็นนะเนี้ย เดี่ยวไปลองงมดู 555+
      ขอบคุณคับ
      • #48
        Watching anime
        From SmoothVideo Project
        Jump to: navigation, search
        Motionflow, TruMotion, Clearscan, etc. Dear child has many names. Most are familiar with frame-interpolation and its effects. However,it is never mentioned in the context of anime, how come?
        A large majority of people seem fond of its effects when it comes to panning and zooming scenes. What?s the catch then? Well, traditionally, it has been associated with the "soap-opera"-effect. With anime, the problem is not the same as with traditional film. Instead we get artifacts. There are mainly two artifacts to be concerned about:
        Double contours
        So you?ve grown tired of these horrible stuttering scenes. You install the SVP and you?re amazed at the smoothness of panning and zooming scenes, but then you see this:
        It?s almost as if two frames have been blended together. This is in fact what happens, one way of motion interpolating is simply blending frames together, for real movies this resembles motion blur, something which makes the movie appear more fluent. However, for anime this doesn?t work, since the contours are too sharp for it. Now, if you had a TV with hardware based frame interpolation, there?s basically no way to solve this. Software-based interpolation software is a little more flexible, by simply enabling ?Sharp? interpolation mode in the control panel, we circumvent this issue. Enabling "Sharp" interpolation means no frame blending will take place.
        Wave artifacts
        So far so good. We?ve fixed our double contours. But now, another problem becomes apparent. Our interpolated frames seem wavy:
        This problem stems from the fact that motion interpolation simply cannot create good enough frames for animated content. But what if we still want our smooth zooming and panning scenes? Fear not. By simply changing the parameters for when a motion vector is detected to something far more crude. The software will simply not detect anything but global motion (panning, zoom, etc) and will therefore not create frames under anything but the best conditions (global motion).
        So there you have it, smooth motion in panning and zooming scenes, while the rest remain untouched.
        • #49
          ผมปรับตามนี้อาการหนักกว่าแบบเดิมอีกแฮะ 5555 สรุปแบบเดิมไปล่ะ ดีสุด
          • #50
            • #51
              ถามหน่อยครับ ใช้กับไม่ใช้ GPU ช่วยนี่มันต่างกันไหมครับ ?
              • #52
                โปรแกรม SVP หรอ อยู่ที่ config ครับ
                ถ้าปรับเยอะ แล้วปิด GPU อาจมีกระตุก
                แต่ถ้าปรับต่ำๆ ใช้แต่ CPU ก็ลื่นๆครับ
                แล้วแต่จะเลือกครับ
                • #53
                  Originally posted by THEFOOL View Post
                  อืม ยังไม่เคยเจออาการจำพวกนี้ในเมะแฮะ เพิ่งจะเคยได้ยินด้วยว่าเมะมีปัญหาจำพวกนี้ เพราะเวลาตัดต่อวีดีโอผมมักจะมีปัญหากับไฟล์ที่มันมี upper field กับ lower field แล้วจะบังคับให้สามารถเล่นใน progressive scan โดยไม่กระตุก ก็จะทำการ interporated มันซะ มันจะเอา 2 เฟรมมาโยงซ้อนเข้าหากันจนได้ภาพที่สมูทงามตา ไม่แยกร่างเป็นเส้นน่าเกลียดแบบ blend field (พวกข่าวทีวีสมัยนี้จะเห็นชัด ดูรู้เลยว่ามัน blend field ใส่ AVI ภาพข่าวนี่แทบจะแยกร่างเวลาเคลื่อนภาพไวไว)
                  เดี๋ยวผมต้องลองไปเช็คกับเมะไฟล์เก่าๆซะหน่อย ว่ามันจะมีปัญหาจำพวกนี้ไหม เพราะลองเช็คกับเมะใหม่ๆไม่เจอปัญหาแบบในภาพ
                  อ่ะ......!! ใครมีจอ 120Hz ช่วยทดสอบเมนู3 Target Frame Rate ตั้งค่าเป็น To Screen refresh rate (default) (หรือบังคับ 120Hz) หน่อยครับ ว่าจะฟินขนาดไหน
                  • #54
                    ผมเคยเจอบางเรื่องนะ จำไม่ได้ละ นานมาก แต่ปรับกราฟฟิกอะไรนั้นจำไม่ค่อยได้ละ อาการเหมือนในรูปเลย แต่ไปปรับ config ใน svp แก้ตรงไหนจำไม่ได้ละ นานมากมาย
                    แต่ตอนนี้เท่าที่ดู อนิเมใหม่ๆ กับ svp ตัวใหม่ ยังไม่เจออาการเก่าๆ แบบในรูปเลย
                    รอ grungust ทดสอบแล้วได้ผลเป็นอย่างไรบอกด้วยนะ ^^
                    • #55
                      ลองเทสเรื่องสภาเสื่อมให้หน่อยงับ ของผมมีอาการนิดๆ
                      • #56
                        ปรับตามนี้ดูยังเป็นหรอครับ
                        • #57
                          สเตตัสต่างๆก่อนเปิด เป็นไฟล์ AVI 23fps รูปแบบ progressive scan
                          เปิด SVP ด้วยค่า Default ทั้งหมด ดูไม่จืด (Apply ก่อนเทส)
                          ลองเลือกShaderเป็น Anime (Apply ก่อนเทส) ก็ยังไม่เพียงพอ
                          ลองเลือก Interpolated เป็นแบบ for anime (Apply ก่อนเทส) ก็ยังไม่พอ
                          ก็เลยลองกดเพิ่มออพชั่นไปอีก 1 ตัว คือ Motion vectors grid
                          จัดไป 32 px Large 0 ผลออกมาตามภาพครับ ใช้ได้ แต่ขอบอกก่อนว่ายังไม่สมบูรณ์
                          เพราะผมกด step ดูยังมีบางจังหวะที่มันเหมือนผ้าใบโดนดึงอยู่ ที่บริเวณภาพที่เคลื่อนไหว
                          อาจจะต้องปรับออพชั่นอื่นๆเสริมอีกทีครับ (ขี้เกียจละ)
                          สำหรับอนิเมะเก่าๆ ที่ใช้กรรมวิธีซ้อนภาพในการผลิต เท่าที่ลองดูจะไม่เจอปัญหาภาพบิดเบี้ยวขณะ Interpolated
                          แถมยังได้ข้อดีจากการที่ภาพสมูธขึ้นเป็น 60 fps คือ อาการสั่นของภาพเวลา PAN จะน้อยลงจนหายไปเกือบหมด
                          ส่วนอนิเมะที่นำมาทดสอบนี้ ก็จะเหมือนไฟล์ยุคใหม่ทั่วๆไป ถ้านำ SVP มาใช้เพิ่มความสมูธก็จะเจอกับปัญหา
                          ทำการ interporated ไม่สมบูรณ์ จะต้องปรับตั้งค่าให้เป็นค่าสำหรับการดูอนิเมะโดยเฉพาะ
                          โดยจะต้องเลือก
                          Frames Interpolation Mode เป็น 1.5m , for anime (ลอง 0 กับ 2 m แล้ว ไม่ผ่าน, โหมดอื่นก็ไม่ผ่าน)
                          SVP Shader เลือกเป็น anime
                          Motion Vectors grid เลือก 24 px ก็ได้ แต่ขนาดผมจัดไป 32 px ยังเกือบไม่รอด เพราะต้องตั้งค่าอื่นๆต่อด้วย
                          ค่าอื่นๆไปลองกันเอาเองครับ ผมไม่เชี่ยวชาญ บางทีเมะบางเรื่องอาจจะใช้การตั้งค่าไม่เหมือนกันด้วย เพราะเมะเรื่องใหม่ๆ
                          ผมไม่เจอปัญหาภาพข้างบนครับ กด default บ้านๆยังดูได้ ไม่เจอปัญหาใดๆ
                          ปล. เอาอีไฟล์แนบออกยังไงหว่า -.- ข้างล่างเนี่ย
                          • #58
                            โดยจะต้องเลือก
                            เทพ
                            เทพ กูรู มาบอกมาเองเลย
                            แจ่มมาก จดๆๆ ไว้เป็นข้อมูล
                            รู้สึกว่า แก้
                            Wide search ปรับสุดทางขวาสุดนะครับ
                            Artifacts masking ปรับสุดทางขวาสุดนะครับ
                            แก้อาการภาพแยกเวลาภาพเคลื่อนไหวเร็วๆ จะช่วยให้ภาพไม่ขาด แต่ก็ยังมีอาการบ้างแล้วแต่เรื่องนะ
                            ส่วนของผมที่ปรับ Motion vectors grid จัดไป 32 px Large 0 นั้นเพราะ CPU ผมไม่แรงพอ ถ้าปรับอย่างอื่นสูงกว่านั้นแล้วหนังมีอาการกระตุก เพราะ CPU ไม่พอ Load นะครับ
                            ถ้าสเป็กแรงๆ หรือใช้ i5 หรือ FX 8 หัวนี้ ปรับค่าอื่นได้เลยนะ
                            • #59
                              ลองแล้วก็โอเคครับ ใช้ได้เลย อาการภาพโดนดึงในตัวอย่างก็หายไปด้วย โอเคเลย แต่ Motion grid step ไรพวกนี้ยังไม่แน่ใจว่าจะปรับยังไงให้เหมาะ
                              พวกฉากที่เคลื่อนไหวกันไวมากๆ ดูแทบไม่ออก แต่พอมากด Step ดูถึงรู้ว่าภาพเน่าได้ใจ แล้วจะเริ่มเห็นชัดขึ้นเมื่อขนาดวีดีโอใหญ่ขึ้น (720p 1080p)
                              ตอนแรกคิดว่าพวกเมะใหม่ๆภาพลื่นๆจะไม่เจอปัญหา เอาเข้าจริงๆกด Step ดูเห็นชัดแจ๋วเลยว่าภาพเน่าตอนเคลื่อนตัวไวๆ
                              setting นี้เอาไปดูหนังชมพูด้วยคงน่าจะเข้ากันได้แฮะ
                              • #60
                                ขอบคุณครับ ลองละ
                                ประบแล้วมันนิ้งมากๆเลย
                                แต่กิน CPU หัวแทบแตก
                                พอดีทดลองใน Notebook ที่ไม่ค่อยแรง ฮ่าๆๆ
