ท่านคิดว่า PSU ยี้ห้อไหน ทน นิ่งเสถียรสุด
  • 80Plus Platinum ตัวใหม่จาก ITsonas ครับ
    http://www.overclockzone.com/forums/...ad.php/1804972
    • Originally posted by ManiacMaew View Post
      อ้างอิง
      ATX12V Power Supply Design GuideVersion 1.3
      http://www.formfactors.org/developer...X12V_1_3dg.pdf
      อ้อ ไม่มีอุปกรณ์ที่จะใช้กับมันแล้วสินะ
      • Originally posted by Gumblar View Post
        มันทำยังกับละครช่อง 7 อุปโลคเอาว่างั้น
        • งบ 2500-3000+ ถอดผ้าเอ้ยถอดสายได้นี้ แนะนำทีครับ
          • กี่วัตต์ครับ
            • มาแล้ว!!! Corsair AX1200i 80+ Platinum
              ควบคุมการทำงานแบบ Digital
              ดูสถานะแบบ Real Time ได้!!!
              Exclusive hands-on with Corsair's AX1200i digitally power controlled PSU
              Posted: 6 hours, 39 mins ago
              Computex 2012 - Yesterday we visited the Corsair suite for an early looking at its new products and one of the biggest new items from the company is its AX1200i power supply.
              Many of you would be aware of the popular and impressive AX1200 power supply, but let's introduce the brand new AX1200i PSU. It is a 80 Plus Platinum rated power supply, but the big story here is it is Corsair's first consumer fully digitally controlled power supply that features a DSP (Digital Signal Processor). That means it's able to work in conjunction with Corsair Link 2 software that allows you to do all sorts of cool things thanks to the new full digital nature of the PSU.
              You can some really cool things such as monitor the real-time power in and power out of your PSU along with measure the efficiency percentage. You can even go as far as measuring the power consumption on the PCI-E power (as well as the 12v rail, SATA, main and so on) to get a fairly good idea of what your video card is using. You can also set Over Current Protection individually. Corsair also claims at the AX1200i features very impressive tight power regulation which we cannot wait to check out in our full review when we get a unit in from Corsair.
              As if that were not enough, you can also set the fan profile depending on the type of performance / quiet factor that you are looking to achieve with your system. The other new thing with the AX1200i is that this PSU will run at around 400 - 500 watts with the PSU running completely silently. That is, the PSU will not start to spin up to cool down the PSU until it hits over roughly 500 watts.
              Corsair says that you will be able to buy the AX1200i around late July or early August. We don't have any pricing details at this stage. All we know is that we want one, now.
              http://www.tweaktown.com/news/24432/...psu/index.html
              • Originally posted by azutozoma View Post
                Scythe GOURIKI-III 700w 2950.-
                • Originally posted by Geek View Post
                  แหล่มเลย 1x,xxx ได้เนอะ ใช้ตัวลูกต่อไป AX750
                  • เทพจุติแล้ว เอิ๊กๆ ใครจะเสี่ยง
                    700W. ITsonas Forsa Pro
                    • Originally posted by H2OPlUS View Post
                      • ผมขออนุญาติถามท่านหน่อยครับ (มันหลายหน้าเกิน ผมศึกษาได้ไม่หมดครับ ต้องขออภัยด้วย)
                        งบไม่เกิน 2 พัน ตัวไหนที่คุ้มสุด ที่หาซื้อได้ ขอตัวเลือกสัก 2-3 ตัวนะครับ spec ผมเป็นเครื่องเล่นเกมกลางๆ ทั่วไป ของเดิมใช้ raidmax 530 ครับ มีความรู้สึกว่ามันไม่พอ ยังไงรบกวนด้วยนะครับ
                        • http://www.overclockzone.com/forums/...ad.php/1804972
                          อย่าทำหน้าเศร้าสร้อยแบบนั้นสิครับท่านกีก
                          ได้ 80Plus Platinum เชียวนะครับ กว่าจะแคปภาพ ก๊อปปี้ลิงค์(PSU ตัวอื่น) ยืนยันมาว่าได้จริงๆ
                          แถมตัวที่ส่งไปเทสกับตัวขายจริงหน้าตาไม่เหมือนกันด้วยนะครับ เค้าใส่ใจผู้บริโภค ปรับปรุงหน้าตาสินค้าใหม่ให้ดูสวยงาม
                          ตั้ง 32A มากกว่าพวก PSU วัตต์ละบาทเยอะอยู่นะครับ แพงกว่ากันแค่สามสี่พันเอง
                          จ่ายไฟได้ตั้ง 91.04% ยี่ห้ออื่นราคาเดียวกันทำไม่ได้นะครับ เห็นทำกันได้ 100% กันทั้งนั้น
                          • งบ2000 ลองดู
                            Scythe GOURIKI-III 500w 1950.-
                            Silverstone 500w 1830.-
                            Corsair CX600 1980.-
                              แถมโปรโมชั่น
                              ให้คอมคุณไปจุติใหม่ ในโลกหน้า
                                น่าสงสารพวกแมงเม่า ที่ไม่มีความรู้เรื่อง PSU
                                คงโดนความสวยงามของกล่องหลอกแดกอีกตามเคย
                                55555555555555555555555555
