E8400 E0 5GHz On TT 850i Water colling
  • #16
    Originally posted by arkomk View Post
    Code:
    [b][u]GIGABYTE GA-EP45_EXTREME[/u][/b]
    [u][b]MB Intelligent Tweaker(M.I.T.)[/b][/u][b][/b]
    Robust Graphics Booster ...............:[Manaul]
    CPU Clock Ratio ..........................:[9 X]
    Fine CPU Clock Ratio.....................:[+0.0]
    CPU Frequency ...........................:[5.04 GHz (561x9)
    [b]Clock Chip Control
    Standard Clock Control[/b]
    CPU Host Clock Control..................: [Enabled]
    CPU Host Frequency (Mhz) ............: [561 Mhz[
    PCI Express Frequency (Mhz) .........: [101]
    C.I.A.2 .................................:[Disabled]
    [b]Advanced Clock Control [Press Enter][/b]
    CPU Clock Drive...........................:[800mV]
    PCI Express Clock Drive.................: [900mV]
    CPU Clock Skew (ps)....................: [0ps]
    MCH Clock Skew (ps)...................: [0ps]
    [b]DRAM Performance Control[/b]
    Performance Enhance...................: [STANDARD]
    Extreme Memory Profile (X.M.P.).....: [Disabled[
    (G)MCH Frequency Latch...............: [Auto]
    System Memory Multiplier ..............:[2.00B]
    Memory Frequency (Mhz) ..............800 [1122]
    DRAM Timing Selectable ................: [Manual]
    [b]Standard Timing Control[/b]
    CAS Latency Time........................4  [5]
    tRCD ...................................4        [  5]
    tRP'....................................4          [  5]
    tRAS....................................12       [ 15]
     [b]Advanced Timing Control[/b]
    tRRD...........................................[4]
    tWTR..........................................[4]
    tWR............................................[8]
    tRFC...........................................[50]
    tRTP...........................................[4]
    Command Rate (CMD) ....................:[AUTO]
    [b]Driving Strength Profiles[/b]
    Driving Strength ............................
    [b]Channel A[/b]
    Static tRead Value.........................:7-10
     tRD Phase0 Adjustment...................:<<< Leave for all below as well
    tRD Phase1 Adjustment...................:Auto
     tRD Phase2 Adjustment .................:Auto
     tRD Phase3 Adjustment..................:Auto
    Trd2rd(Different Rank)....................:Auto
    Twr2wr(Different Rank)...................:Auto
    Twr2rd(Different Rank)...................:Auto
    Trd2wr(Same/Diff Rank)..................:Auto
    Dimm1 Clock Skew Control...............:Auto  ps
    Dimm2 Clock Skew Control...............:Auto  ps
    [b]Channel B[/b]
    tRD Phase1 Adjustment...................:[Auto]
     tRD Phase2 Adjustment .................:[Auto]
     tRD Phase3 Adjustment..................:[Auto]
    Trd2rd(Different Rank)....................:[Auto]
    Twr2wr(Different Rank)...................:[Auto]
    Twr2rd(Different Rank)...................:[Auto]
    Trd2wr(Same/Diff Rank)..................:[Auto]
    Dimm1 Clock Skew Control...............:[Auto]  ps
    Dimm2 Clock Skew Control...............:[Auto]  ps
    [b]Motherboard Voltage Control[/b]
    Voltage Type.………... Manual
    [b]CPU[/b]
    CPU Vcore….……….........................:1.65000V]
    CPU Termination…..... 1.200V*.......:[1.280V]
    CPU PLL…………………....1.500V*.......: [1.580V]
    CPU Referen.…………....0.755V*.......: <<< .64% Of Vtt (Termination above) Auto Will set this correctly
    CPU Reference2………,,0.800V*.......:<<< .67% Of Vtt (Termination above) Auto Will set this correctly
    [b]MCH/ICH[/b]
    MCH Core…………….....1.100V...........: [1.480V]
    MCH Reference….…….0.800V...........; [Auto]
    MCH/DRAM Ref.…......0.900V...........: [Auto]
    ICH I/O……………….....1.550V............: [Auto]
    ICH Core…………...……1.100V............: [Auto]
    [b]DRAM[/b]
    DRAM Voltage ……....1.800V............:[2.200V]
    DRAM Termination .…0.900V............: [Auto]
    Channel A Reference 0.900V............: [Auto]
    Channel B Reference 0.900V............: [Auto]
    [b]Advanced Settings[/b]
    Limit CPUID Max. to 3.....................: [Disabled]
    No-Execute Memory Protect............: [Enabled]
    CPU Enhanced Halt (C1E)................: [Disabled]
    C2/C2E State Support....................: [Disabled]
    x C4/C4E State Support..................: [Disabled]
    CPU Thermal Monitor 2(TM2) ...........: [Enabled]
    CPU EIST Function.........................: [Disabled]
    Virtualization Technology................: [Disabled] Enabled if you use Vmware/Virtual PC
    [b]Integrated Peripherals[/b]
    Legacy USB Storage Detect ..............[Disabled] *Note* Must be enabled to flash from USB
    [b]Note[/b]: * refers to 45nm CPU
    คอนฟิคเทพ
    • #17
      แรงๆๆๆครับพี่x
      • #18
        ขอบคุณคับต้องลองแล้วละเอียดยิบ
        • #19
          พอจะมีวิธี configคร่าวๆของ e8400 P5e Mod bios เป็น Rampage Formula ไหมครับขอบคุณครับ
          • #20
            ขอดู 3d mark 06 หน่อยจิ
            • #21
              จัดไป..............
              • #22
                แรง !!!
                • #23
                  ใช้ M/b อะไรหว่า
                  • #24
                    Gigabyte EP45-Extreme
                    • #25
                      Originally posted by Explosively View Post
                      แรง !!!
                      ยังแรงได้อีก.......
                      • #26
                        โหดจิง
                        เราไปได้แค่4.8 T-T ซิ้งค์ลม
                        • #27
                          อยากเห็น prime95 สัก 1 ชั่วโมงอะครับ ขอหน่อยท่าน
                          • #28
                            ป๊าดดด แรงขิงๆ
                            • #29
                              จัด i7 5GHz อีกตัวดีไหมว้า...............iiGum
                              • #30
                                เทสไป บอร์ด cpuพังป่าวๆครับ ลากโชว์ เฉยๆครับ ไม่เน้นใช้งานครับ
