F3-12800CL7D-4GBHZ
Specification
Main Board intel
System Desktop
System Type DDR3
M/B Chipset intel X38,
intel P35
CAS_Latency 7-7-7-18
Capacity 2GB (1GB x 2), 4GB (2B x 2)
Speed DDR3-1600 (PC3 12800)
Test_Voltage 1.9 Volts
PCB 6 Layers
Registered/Unbuffered Unbuffered
Error_Checking Non-ECC
Type 240-pin DIMM
Warranty Lifetime
19,500 บาท
150*4 GB. RAPTOR 10000 RPM
Performance Specifications Rotational Speed 10,000 RPM (nominal) Buffer Size 16 MB Average Latency 2.99 ms (nominal) Contact Start/Stop Cycles 20,000 minimum Seek Times (Average) Read Seek Time (Average) 4.6 ms Write Seek Time (Average) 5.2 ms (average) Track-To-Track Seek Time 0.4 ms (average) Full Stroke Seek 10.2 ms (average) Transfer Rates Buffer To Host (Serial ATA) 150 MB/s (Max) Buffer To Disk 84 MB/s (Sustained) 28000บาท
ThermalTake SwordM
Built in liquid cooling solution with extra large radiator and two 12cm fans
Fully handmade multifunctional high class PC case
All aluminum extrusion built chassis
Hydraulic mechanisms for the top and side panel
Revolutionary open back plate design provides maximum internal air flow.
Tool-free design for easy installation
Support up to ten 5.25 drive bays
7 drive bay for optional 7 touch screen LCD monitor. (P/N:A2413-03)
15,500 บาท
SilverStone 1200W DA
SilverStone 1200W DA ถอดสายได้
100% modular cables with cable bag
Powerful single +12V rail with 90A
1200W continuous power output rated up to 50℃
Efficiency greater than 80% at 20%~100% loading
Japanese primary capacitors
Dual PCI-E 8pin & Six PCI-E 6pin
Dual EPS12V 8pin & Six SATA connectors
Silent running 135mm ball bearing Fan
Support ATX 12V 2.3 & EPS 12V
12,900 บาท
Case :Silverstone TJ10B-WES Black Tower Case with Aluminium Front Panel/Door, 2.0mm aluminum body, SSI, Extended ATX, ATX, Micro ATX, No PSU = 12,000 บาท
Water Cooling:Zalman Reserator XT Water Cooling System, Active/Passive Cooling, Alarm System, Monitoring Display, Aluminium, 2 Ball-bearing, 22-34dBA, Black *2 =14,918*2 = 29,837 บาท
Speeker : Sony SPEAKER BUNDLE (SAWVS300+SSFCR300H)
Components not sold separate as single units
8 Ohm, 150W, 81dB Sensitivity, 120 Hz - 50, 000 Hz
Sub Woofer- 15cm Bass Driver, 150W Output = 33,142 บาท
TV-Tuner :HauppaugeTV PVR-USB2
USB CONNECTIVITY FOR NOTEBOOK AND PCS
1 COMPOSITE 1 S-VIDEO CONNECTOR SOFTWARE PROVIDED = 15,279 บาท
System Foundation
________________________________________
Processor
Quad Core - Intel® Core2™ Extreme Quad-Core 3.2GHz QX9770
Memory
8GB 1600 MHz CORSAIR PC-12800 DDR3 SDRAM (4x2GB)
Thermal Management
CPU and Graphic Cards Liquid Cooling (Nvidia Graphics)
Motherboard
EVGA nForce™ 790i Ultra
Operating System
Microsoft® Windows Vista™ Ultimate (64 Bit)
Warranty
1 year limited hardware and 1 year technical support
Graphics and Audio
Graphics Cards
Dual NVIDIA GeForce GTX-280, with 1GB of GDDR3 SDRAM (LC)
Audio Boards
Creative Audio Sound Blaster® X-Fi™ XtremeGamer Fatal1ty Professional
Power Supply
1.1KW Power Supply
Storage Systems
Primary OS Storage
RAID (1) Data Reliability - 2 x 750GB 7200 rpm SATA
Secondary Data Storage
RAID (0) Performance - 3 x 750GB 7200 rpm SATA
Optical Disk Bay 1
Super multi-drive, slim slots with Lightscribe (DVD+/-R/RW+/-DL)
Optical Disk Bay 2
Second Super multi-drive, slim slots with Lightscribe (DVD+/-R/RW+/-DL)
5.25" Bay
Blu-Ray Rewriter Drive with LightScribe (CD-R/RW, DVD-R/RW/RAM, +R/RW, +/- R DL)
Software
Security Software
Grisoft AVG Internet Security - 2 year subscription
Productivity Software
Microsoft® Office Pro 2007
Accessories
Speakers Systems
Bose Companion® 5 multimedia speaker system
Headsets
Creative Fatal1ty Gaming Headset
Mice
Logitech G9 Mouse
Keyboards
Logitech diNovo Keyboard
Gaming
Logitech Force 3D Pro
