ขอสเป็คที่แพงที่สุดเลยครับ
Originally posted by EK View PostCPU: Intel Core2 Extreme QX9775 3.2GHz 12MB L2 Cache 1549
M/B: Intel BOXD5400XS Dual LGA 771 Skulltrail D5400XS Extended ATX Motherboard 629
RAM: Kingston 8GB (2 x 4GB) 240-Pin DDR2 FB-DIMM ECC Fully Buffered DDR2 667 600
VGA: ATI 100-505520 FireGL V8650 2GB PCI Express x16 Workstation Video Card 2314
HDD: HP 411089-B22 300GB 15000 RPM Ultra320 SCSI Hard Drive 1000
HDD Controller: Intel SRCU42L 64-bit/66MHz PCI 2.2 interface, universally keyed for 3.3V and 5V signaling, backward compatible to 33MHz SCSI Controller Card RAID 0/1/4/5/10 JBOD 10000
OPTICAL: SONY Black & Gray 16X DVD+R 8X DVD+RW 4X DVD+R DL 16X DVD-R 6X DVD-RW 2X DVD-RAM 16X DVD-ROM 40X CD-R 32X CD-RW 40X CD-ROM 8MB Cache SATA 4X Blu-ray DVD Burner 560
PSU: ePOWER EP-2000P10-T3 2000W ATX12V Ver.2.2 Power Supply 100 - 240 V CB, CE, FCC, TUV, cUL 650
CASE: ZALMAN TNN 300 Black Steel MicroATX Mid Tower Computer Case 350W Power Supply 655
ราคา้ประมาณ 600,000 บาท สำหรับเครื่องนี้
QX9770 Core2 Extreme 3.20GHz / LGA775 Quad-Core / 1600 MHz / 12MB / 45nm*2 105000 บาท
บอร์ดผมจำรุ่นไม่ได้ แต่จำได้ว่ามันเรียกกันว่า V8 ลองหาดูนะคับมันเปง 2CPU 3GPU
30000
F3-12800CL7D-4GBHZ
Specification
Main Board intel
System Desktop
System Type DDR3
M/B Chipset intel X38,
intel P35
CAS_Latency 7-7-7-18
Capacity 2GB (1GB x 2), 4GB (2B x 2)
Speed DDR3-1600 (PC3 12800)
Test_Voltage 1.9 Volts
PCB 6 Layers
Registered/Unbuffered Unbuffered
Error_Checking Non-ECC
Type 240-pin DIMM
Warranty Lifetime
19,500 บาท
150*4 GB. RAPTOR 10000 RPM
Performance Specifications Rotational Speed 10,000 RPM (nominal) Buffer Size 16 MB Average Latency 2.99 ms (nominal) Contact Start/Stop Cycles 20,000 minimum Seek Times (Average) Read Seek Time (Average) 4.6 ms Write Seek Time (Average) 5.2 ms (average) Track-To-Track Seek Time 0.4 ms (average) Full Stroke Seek 10.2 ms (average) Transfer Rates Buffer To Host (Serial ATA) 150 MB/s (Max) Buffer To Disk 84 MB/s (Sustained) 28000บาท
Geforce 9800 GX2 *2
Chipset Geforce 9800 GX2
Memory 1G GDDR3
Core Frequency 600MHz
Memory Frequency 2000MHz
RAMDAC 400MHZ
Interface PCI-Express 2.0
Memory Bus 256-bit x2
Stream Processors 128 x2
Max. Resolution 2560 x 1600
SLI Ready Yes
Output 1. Dual-Link DVI 2. HDMI
HDCP Yes 42600บาท
ThermalTake SwordM
Built in liquid cooling solution with extra large radiator and two 12cm fans
Fully handmade multifunctional high class PC case
All aluminum extrusion built chassis
Hydraulic mechanisms for the top and side panel
Revolutionary open back plate design provides maximum internal air flow.
Tool-free design for easy installation
Support up to ten 5.25 drive bays
7 drive bay for optional 7 touch screen LCD monitor. (P/N:A2413-03)
15,500 บาท
SilverStone 1200W DA
SilverStone 1200W DA ถอดสายได้
100% modular cables with cable bag
Powerful single +12V rail with 90A
1200W continuous power output rated up to 50℃
Efficiency greater than 80% at 20%~100% loading
Japanese primary capacitors
Dual PCI-E 8pin & Six PCI-E 6pin
Dual EPS12V 8pin & Six SATA connectors
Silent running 135mm ball bearing Fan
Support ATX 12V 2.3 & EPS 12V
12,900 บาท
LCD24" 1920*1200 MAC TV 30000
LG 16X [BE06LU]
[BOX] Blu-Ray 16,930 บาท
WINDOWS VISTA BUSINESS 5,150 บาท
Crative 750 7.1 ไร้สาย24900
การ์ดเสียง x-Fi+ Front 16900
Logitech G25 พวงมาลัยมี คลัช เพื่อชอบไว้ขับเล่น12500
Logitech MX5000 CORDLESS MS.LASER+KB.BLUETOOTH,5YRS WARRANTY
Logitech Cordless Desktop MX 5000 ชุดคียบอร์ดและเม้าส์ไร้สายดีไซน์ล้ำสมัยจาก Logitech ชุดคีย์บอร์ดและเม้าส์ไร้สายดีไซน์ล้ำสมัยล่าสุดจาก Logitech...
5,790 บาท
