Originally posted by osxp
Daum PotPlayer Ver.1.5.31934 ตัวใหม่ออกแล้วนะครับ
32bit
64bit
Changes since v1.5.30857:
32bit
64bit
- Added the ability to jump to current subtitle position
- Added IMC1 ~ IMC4 color spaces
- Added Intel QuickSync Decoder (MPEG1/2, H264/AVC, WMV3, VC1 are supported)
- Some fixes while playing TS files
- Added an option to adjust window size from window center
- Improved filter priority handling
- Fixed an issue that FLAC audio codec selection did not work
- Fixed mouse response problem on file navigator
- Added the ability to move to chapters of blu-ray
- Added the ability to choose blu-ray playback method
- Added the ability to set custom screen size when starting video playback
- Added Built-in LPCM decoder
- Changed default setting of WMA audio codec to Built-in Decoder
- Fixed sync problem of Interlace VC1 playback when seeking
- Added the ability to specify the transparency of the navigation dialog
- Added the ability to rename filename in the playlist
- Fixed sync problem of built-in WMV DMO codec when seeking
- Changed default setting of built-in MPEG audio decoder to FFmpeg Float Decoder
- Added Nvidia CUDA Decoder (MPEG1/2, H264/AVC, VC1 are supported)
- Added an option to play the next item when failed to play
- Added CMD_VIDEO_CODEC_SIZE_MESSAGE, CMD_VIDEO_OUT_SIZE_MESSAGE, CMD_VIDEO_OUT_FPS_MESSAGE to skin support
- Some fixes for specific FFmpeg audio codec
- Some fixes for built-in H.264 DXVA decoder
- Added resolution limit setting to usage conditions of DXVA
- Improved support of Rar files
- Improved determination of interlaced WDM
- Added WMV9 VLD support to built-in DXVA decoder
- Added multiple audio output processing to built-in splitter
- Added AVX instructions support to built-in codec
- Fixed an issue that can not play a damaged part of ASF
- Improved album/favorite menu handling
- Added an option to scale subtitle's outline/shadow to fit screen size
- Fixed an issue that tray icon don't show up when using screen capture
