the Revolutionary Class-T Digital Amplifier retain all the properties of the traditional T-Amp and incorporate the following NEW FEATURES:
* 12V 3A Stabilized Compact Switching Power Supply NOW INCLUDED
* Exceptional! - Headphone output for minijack plug added
* Better looking case
* Blue backlit for the On/Off switch and volume control
* Included n. 1 RCA-minijack cable and n. 1 RCA-minijack adaptor
* New battery seat for an easier access
Features:
- Portable Audio Amplifier
- 15w x 2 Channels Continuous
- Battery Powered
- AC Power Adapter Option
- Heat / Circuit Protection
- 4 & 8 ohm Compatibility
Specifications:
Digital integrated amp.
Class-T ? architecture incorporating Tri-mark TA 2024 digital amplifier chip and Digital Power Processing ? technology.
Outboard power supply.
One stereo RCA line input. Five-way speaker binding post speaker connection.
Power output: 10 watts/per channel ? 8 Ohms, 15 watts per channel ? 4 ohms @ 10% THD. 6 and 11 watts/channel (respectively) at 0.1% THD.
Dynamic Range: 98 dB.
88% efficiency @ 8 Ohms, 81% at 4 Ohms.
Size: 3.25? W x 7.5? D x 7.25? H.
After a successful run the T-150 has been refreshed with a more potent (90WPC)& better sounding MkII version. This well priced Tripath amplifier can power essentially any loudspeaker and sounds great!
The Specs:
Class T Digital Audio Integrated Amplifier
Monoblock Bridgable with 180 W/Channel
2 RCA Input & 1 Balanced Input for BTL
High Quality Components, including National FC & Nichon capacitors.
Over-Current Protection
Over-Thermal Protection
Volume Control can be bypassed and unit can be used as power amp
180 watts BTL output with RCA or Balance input
Frequency Response: 15-80 KHz (-1db)
S/N: 88dB
THD: 0.05% (1 KHz)
Audio Input Sensitivity: 200mV
Output Power: 90W+90W
Power Supply: AC 110V-230V (?10%) 50/60Hz
Max Power Dissipation: 120W
Weight: 4.5 kg
