TQFP-32 to SIP PCB Adapter PCM2706 , PCM2707
S03-02 : P LCC28 - 50mill / TQFP 32 - 0.5mm to SIP8*4 = 45฿ > คลิก
- Plated Through Holes
- Easy to Replace On-Board
- Top layer : LCC28-50mill to SIP
- Bottom layer : TQFP32-0.5mm to SIP
- Material : FR4
- Thickness : 1.6 mm.
- Dimensions: 33x38 mm.
TQFP-32 to SIP PCB Adapter PCM1792A, PCM1793, PCM1794A, PCM1795, PCM1796, PCM1798
S18-01 : TSSOP28 to DIP Convert PCB Adapter pitch 0.65mm. = 45฿ > คลิก
- Top layer : TSSOP28 (0.65 mm) to DIP
- Material : FR4
- Dimensions: 22x38 mm.
SOIC-8 to DIP-8 PCB Adapter OPA627U, OPA637U, OPA2107U, OPA2132U
S05-01 : SO8 to DIP8 Convert PCB Adapter = 30฿ > คลิก
- Top layer : SO8 to SIP
- Material : FR4
- Dimensions: 12x15 mm.
S04 : SOIC 8 to SIP4x2 Convert PCB Adapter = 30฿ > คลิก
- Material : FR4
- Dimensions: 13x13 mm.
- Material : FR4
- Material : FR4
- Material : FR4
- Material : FR4
