ซิ้งค์เดิม 4.5 ไม่ไหวนา
ขอ Config E8400 + P5Q PRO หน่อยจ่ะ ขอแบบละเอียด
AI Overclock tuner: ManualOriginally posted by JanGl3eaU View Postปรับที่หนาย อ่าจ๊ะ
ลงภาพ ให้หน่อยจ่ะ
ช่ยขุดๆๆ หน่อย
เด่วตก
หุหุหุ
CPU Ratio Setting: 8 (or 9)
FSB Strap to North Bridge: 333 or AUTO
FSB Frequency: AUTO
PCI-E Frequency: 100
DRAM Frequency: DDR2-1066 **************
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: Manual **************
1st Information:
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: AUTO
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
2nd Information :
All AUTO
3rd Information :
All AUTO
DRAM Static Read Control: AUTO
DRAM Read Training: AUTO
MEM. OC Charger: AUTO
AI Clock Twister: AUTO
AI Transaction Booster: AUTO
Common Performance Level: AUTO
CPU Voltage: AUTO
CPU GTL Voltage Reference (0/2): AUTO
CPU GTL Voltage Reference (1/3): AUTO
CPU PLL Voltage: AUTO
FSB Termination Voltage: AUTO
DRAM Voltage: 2.00 **************************
NB Voltage: AUTO
NB GTL Reference: AUTO
SBridge Voltage: AUTO
PCIE SATA Voltage: AUTO
Load Line Calibration: Enabled
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
CPU Clock Skew : AUTO
NB Clock Skew : AUTO
เข้า bios ครับ สังเกตุตรงมี ************************************************ (ดาว)
ตามนี้เลยหรอจ๊ะOriginally posted by nonsiOC View PostAI Overclock tuner: Manual
FSB Frequency: AUTO
DRAM Frequency: DDR2-1066 **************************
DRAM Timing Control: Manual **************************
1st Information:
CAS# Latency: 5
2nd Information :
All AUTO
3rd Information :
All AUTO
CPU Voltage: AUTO
DRAM Voltage: 2.00 **************************************************
NB Voltage: AUTO
เข้า bios ครับ สังเกตุตรงมี ************************************************************************************************ (ดาว)
confing นี้ เท่าไรอ่ะ
4.5 หรอจ๊ะ
ซิ้งเดิมนะ
แล้วไฟ CPU เท่ารายหรอ
ตอนนี้ 4.095 ไฟ 1.336 v
เปิดมาครั้งแรกมานจาดับก่อนแล้วค่อยติดอีกที งง อ่ะ
ขุดๆๆๆๆ
เข้ายากมาก web overclockzone ลาก cpu ไกลแล้วนะ ลาก cpu ไกลทดแรม 1:1 (DRAM Frequency ค่าน้อยที่สุด) แล้วก็ AI Transaction Booster ตั้งเป็น manual แล้วก็ Common Performance Level ตั้งเป็น (11) แล้วก็ FSB Termination Voltage ตั้งเป็น 1.40 vOriginally posted by JanGl3eaU View Postขุดดๆๆๆๆ
เด่วตกๆๆ
ตอบทีจ่ะ
รอนานแระ
อ้าวนึกว่าต้อง Auto หมดOriginally posted by nonsiOC View Postเข้ายากมาก web overclockzone ลาก cpu ไกลแล้วนะ ลาก cpu ไกลทดแรม 1:1 (DRAM Frequency ค่าน้อยที่สุด) แล้วก็ AI Transaction Booster ตั้งเป็น manual แล้วก็ Common Performance Level ตั้งเป็น (11) แล้วก็ FSB Termination Voltage ตั้งเป็น 1.40 v
OV_CPU, OV_NB มันไว้ สำหรับOriginally posted by nonsiOC View Postเปลี่ยน connect สาย power 12V. เป็น 8 pin หรือยังครับ (จาก 4pin เป็น 8pin) จ๊ำเปอร์ที่เมนบอร์ด OV_CPU, OV_NB (สลับด้วยนะเป็นการoverclock cpu)
ปรับไฟ เกิน ไม่ใช่หรอครับ ไม่เกี่ยวกัน
เอาไว้ ให้ ปรับไฟ ได้ สูง ขึ้น
ไม่รู้ใคร จะ ปรับ ถึงนั่น
จขกท ผมขอเสนอ ให้ ท่าน เก็บ ตัง ซื้อซิ้งใหม่ก่อน แล้วค่อยว่ากัน
หรือว่าเปลี่ยนแล้ว
ผมก็คู่ฮิต e8400+p5q pro+g.skill4pk/800
ตอนนี้ 9*425 ทด 1:1 cl5 ไฟแค่ 1.26 ใช้งานปกติเสถียรดี เทส pi orthos ผ่าน
ผมดันได้บัส 445 เอง ที่เทสผ่านและเสถียร
ตั้งแต่บัส 450+ ตัวคูณต่ำๆ เทส pi จะฟ้อง not exact in round และบางครั้งก็ not convergent in sqr
รัน orthos ภูเขาไฟระเบิด บางครั้งก็จอฟ้า
ผมก็อยากเล่นบัส 500 มั่ง ลองทำตาม rep บนๆแล้วก็ยังไม่ได้
