Mikrotik Club
  • ท่านใดมีสคริป no-ip สำหรับ 2 pppoe ผมขอหน่อยครับ
    • ทำไมผมลองใส่ Netwatch กับ Block DNS ที่ Firewall Filter
      DNS True ถึง ping ไม่เจอ งง
      ปล.1 WAN1 = PPPoE (3BB) WAN2 = DHCP (TRUE DOCSIS)
      Config ผมประมาณนี้ แต่ มัน Ping ออก DNS True ไม่ได้ ทำให้ Script Auto Disable Load-Balance มันทำงาน งงมาก
      # aug/11/2014 1437 by RouterOS 6.18
      # software id = 56YE-PIRA
      /interface ethernet
      set [ find default-name=ether3 ] arp=reply-only name=lan1
      set [ find default-name=ether4 ] master-port=lan1 name=lan2
      set [ find default-name=ether5 ] master-port=lan1 name=lan3
      set [ find default-name=ether1 ] name=wan1
      set [ find default-name=ether2 ] name=wan2
      /ip dhcp-server
      add add-arp=yes disabled=no interface=lan1 lease-time=1d name=default
      /ip pool
      add name=default-dhcp ranges=172.22.22.184-172.22.22.247
      /port
      set 0 name=serial0
      /interface pppoe-client
      add ac-name="" add-default-route=no allow=pap,chap,mschap1,mschap2 \
      dial-on-demand=no disabled=no interface=wan1 keepalive-timeout=10 \
      max-mru=1480 max-mtu=1480 mrru=1600 name=pppoe-out1 password=xxxxxx \
      profile=default service-name="" use-peer-dns=yes user=xxxxxxxxxx@3bb
      /ip address
      add address=172.22.22.254/24 comment="default configuration" interface=lan1 \
      network=172.22.22.0
      add address=192.168.1.2/24 interface=wan1 network=192.168.1.0
      /ip arp
      add address=172.22.22.250 comment=DEVIL-AP_FL1 interface=lan1 mac-address=\
      xx:xx:xx:xx:xx:xx
      /ip dhcp-server network
      add address=172.22.22.0/24 comment="default configuration" dns-server=\
      172.22.22.254 gateway=172.22.22.254
      /ip dns
      set allow-remote-requests=yes cache-size=5000000KiB max-udp-packet-size=512
      /ip dns static
      add address=172.22.22.254 name=router
      /ip firewall filter
      add action=drop chain=output comment=block_dns_!pppoe-out1 dst-address=\
      110.164.252.222 out-interface=!pppoe-out1
      110.164.252.223 out-interface=!pppoe-out1
      add action=drop chain=output comment=block_dns_!wan2 dst-address=\
      203.144.206.29 out-interface=!wan2
      203.144.206.49 out-interface=!wan2
      add action=drop chain=input comment="drop ftp brute forcers" dst-port=21 \
      protocol=tcp src-address-list=ftp_blacklist
      add chain=output content="530 Login incorrect" dst-limit=\
      1/1m,9,dst-address/1m protocol=tcp
      add action=add-dst-to-address-list address-list=ftp_blacklist \
      address-list-timeout=3h chain=output content="530 Login incorrect" \
      protocol=tcp
      add action=drop chain=input comment="drop ssh brute forcers" dst-port=22 \
      protocol=tcp src-address-list=ssh_blacklist
      add action=add-src-to-address-list address-list=ssh_blacklist \
      address-list-timeout=1w3d chain=input connection-state=new dst-port=22 \
      protocol=tcp src-address-list=ssh_stage3
      add action=add-src-to-address-list address-list=ssh_stage3 \
      address-list-timeout=1m chain=input connection-state=new dst-port=22 \
      protocol=tcp src-address-list=ssh_stage2
      add action=add-src-to-address-list address-list=ssh_stage2 \
      protocol=tcp src-address-list=ssh_stage1
      add action=add-src-to-address-list address-list=ssh_stage1 \
      protocol=tcp
      add action=drop chain=input comment="Block External DNS Request" dst-port=53 \
      in-interface=wan2 protocol=udp
      add action=drop chain=input dst-port=53 in-interface=wan2 protocol=tcp
      add action=drop chain=input dst-port=53 in-interface=pppoe-out1 protocol=udp
      add action=drop chain=input dst-port=53 in-interface=pppoe-out1 protocol=tcp
      add action=drop chain=forward comment="Block External DNS Relay" dst-port=53 \
      out-interface=!wan2 protocol=udp
      add action=drop chain=forward dst-port=53 out-interface=!wan2 protocol=tcp
      add action=drop chain=forward dst-port=53 out-interface=!pppoe-out1 protocol=\
      udp
      tcp
      /ip firewall mangle
      add action=mark-routing chain=prerouting dst-address=110.164.252.222 \
      new-routing-mark=to_wan1
      add action=mark-routing chain=prerouting dst-address=203.144.206.29 \
      new-routing-mark=to_wan2
      add action=mark-routing chain=prerouting dst-address=192.168.1.0/24 \
      in-interface=lan1 new-routing-mark=to_wan1
      add action=mark-routing chain=prerouting dst-address=192.168.100.0/24 \
      in-interface=lan1 new-routing-mark=to_wan2
      add action=mark-connection chain=input comment=load-balance in-interface=\
      pppoe-out1 new-connection-mark=wan1_conn
      add action=mark-connection chain=input comment=load-balance in-interface=wan2 \
      new-connection-mark=wan2_conn
      add action=mark-routing chain=output comment=load-balance connection-mark=\
      wan1_conn new-routing-mark=to_wan1
      wan2_conn new-routing-mark=to_wan2
      add action=mark-connection chain=prerouting comment=load-balance \
      dst-address-type=!local in-interface=lan1 new-connection-mark=wan1_conn \
      per-connection-classifier=both-addresses-and-ports:2/0
      dst-address-type=!local in-interface=lan1 new-connection-mark=wan2_conn \
      per-connection-classifier=both-addresses-and-ports:2/1
      add action=mark-routing chain=prerouting comment=load-balance \
      connection-mark=wan1_conn in-interface=lan1 new-routing-mark=to_wan1
      connection-mark=wan2_conn in-interface=lan1 new-routing-mark=to_wan2
      /ip firewall nat
      add action=masquerade chain=srcnat dst-address=192.168.1.0/24 out-interface=\
      wan1
      add action=masquerade chain=srcnat dst-address=192.168.100.0/24 \
      out-interface=wan2
      add action=masquerade chain=srcnat comment=nat_wan1 out-interface=pppoe-out1
      add action=masquerade chain=srcnat comment=nat_wan2 out-interface=wan2 \
      to-addresses=0.0.0.0
      add action=dst-nat chain=dstnat comment="Remote Mikrotik" dst-address-type=\
      local dst-port=8088 protocol=tcp to-addresses=172.22.22.254 to-ports=80
      add action=dst-nat chain=dstnat comment="Remote Modem WAN1" dst-address-type=\
      local dst-port=8090 protocol=tcp to-addresses=192.168.1.1 to-ports=80
      add action=dst-nat chain=dstnat comment="Remote Modem WAN2" dst-address-type=\
      local dst-port=8091 protocol=tcp to-addresses=192.168.100.1 to-ports=80
      add action=dst-nat chain=dstnat comment="Remote AP GooJ" dst-address-type=\
      local dst-port=8089 protocol=tcp to-addresses=172.22.22.253 to-ports=80
      add action=dst-nat chain=dstnat comment="Remote AP 6" dst-address-type=local \
      dst-port=8092 protocol=tcp to-addresses=172.22.22.252 to-ports=80
      add action=dst-nat chain=dstnat comment="Remote AP 7 " dst-address-type=local \
      dst-port=8093 protocol=tcp to-addresses=172.22.22.251 to-ports=80
      add action=dst-nat chain=dstnat comment="Remote AP 1" dst-address-type=local \
      dst-port=8094 protocol=tcp to-addresses=172.22.22.250 to-ports=80
      add action=dst-nat chain=dstnat comment="Remote AP 8" dst-port=8095 protocol=\
      tcp to-addresses=172.22.22.249 to-ports=80
      add action=dst-nat chain=dstnat comment="Remote AP 4" dst-address-type=local \
      dst-port=8096 protocol=tcp to-addresses=172.22.22.248 to-ports=80
      add action=dst-nat chain=dstnat comment=WinBox dst-address-type=local \
      dst-port=8291 protocol=tcp to-addresses=172.22.22.254 to-ports=8291
      add action=redirect chain=dstnat comment="Block Internal DNS" dst-port=53 \
      in-interface=!wan2 protocol=udp
      add action=redirect chain=dstnat dst-port=53 in-interface=!wan2 protocol=tcp
      add action=redirect chain=dstnat dst-port=53 in-interface=!pppoe-out1 \
      protocol=udp
      protocol=tcp
      /ip route
      add check-gateway=ping comment=load-balance distance=1 gateway=pppoe-out1 \
      add check-gateway=ping comment=load-balance distance=1 gateway=wan2 \
      add check-gateway=ping distance=1 gateway=pppoe-out1
      add check-gateway=ping distance=2 gateway=wan2
      add distance=1 dst-address=192.168.100.0/24 gateway=wan2
      /ip upnp
      set enabled=yes
      /system clock
      set time-zone-name=Asia/Bangkok
      /system lcd
      set contrast=0 enabled=no port=parallel type=24x4
      /system lcd page
      set time disabled=yes display-time=5s
      set resources disabled=yes display-time=5s
      set uptime disabled=yes display-time=5s
      set packets disabled=yes display-time=5s
      set bits disabled=yes display-time=5s
      set version disabled=yes display-time=5s
      set identity disabled=yes display-time=5s
      set pppoe-out1 disabled=yes display-time=5s
      set wan1 disabled=yes display-time=5s
      set wan2 disabled=yes display-time=5s
      set lan1 disabled=yes display-time=5s
      set lan2 disabled=yes display-time=5s
      set lan3 disabled=yes display-time=5s
      /system ntp client
      set enabled=yes primary-ntp=203.185.69.60 secondary-ntp=203.185.69.59
      /system scheduler
      add comment="Update No-IP DDNS" interval=5m name=no-ip_ddns_update on-event=\
      no-ip_ddns_update policy=read,write,test start-date=jun/29/2014 \
      start-time=1629
      add comment="Update No-IP DDNS2" interval=5m name=no-ip_ddns_update2 \
      on-event=no-ip_ddns_update2 policy=read,write,test start-date=jun/29/2014 \
      start-time=1613
      add comment="Reboot Router Daily" interval=1d name="Reboot Router Daily" \
      on-event="/system reboot" policy=\
      ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=\
      jan/01/1970 start-time=00:00:10
      /system script
      add name=no-ip_ddns_update policy=\
      ftp,reboot,read,write,policy,test,password,sniff,sensitive source="# No-IP\
      \_automatic Dynamic DNS update\r\
      \n\r\
      \n#--------------- Change Values in this section to match your setup -----\
      -------------\r\
      \n\r\
      \n# No-IP User account info\r\
      \n:local noipuser \"xxxxxxxx\"\r\
      \n:local noippass \"xxxxxxxx\"\r\
      \n\r\
      \n# Set the hostname or label of network to be updated.\r\
      \n# Hostnames with spaces are unsupported. Replace the value in the quotat\
      ions below with your host names.\r\
      \n# To specify multiple hosts, separate them with commas.\r\
      \n:local noiphost \"xxxxxx.no-ip.biz\"\r\
      \n\r\
      \n# Change to the name of interface that gets the dynamic IP address\r\
      \n:local inetinterface \"pppoe-out1\"\r\
      \n\r\
      \n#-----------------------------------------------------------------------\
      -------------\r\
      \n# No more changes need\r\
      \n\r\
      \n:global previousIP1\r\
      \n\r\
      \n:if ([/interface get \$inetinterface value-name=running]) do={\r\
      \n# Get the current IP on the interface\r\
      \n :local currentIP [/ip address get [find interface=\"\$inetinterface\"\
      \_disabled=no] address]\r\
      \n\r\
      \n# Strip the net mask off the IP address\r\
      \n :for i from=( [:len \$currentIP] - 1) to=0 do={\r\
      \n :if ( [ick \$currentIP \$i] = \"/\") do={ \r\
      \n :set currentIP [ick \$currentIP 0 \$i]\r\
      \n } \r\
      \n }\r\
      \n\r\
      \n :if (\$currentIP != \$previousIP1) do={\r\
      \n :log info \"No-IP: Current IP \$currentIP is not equal to previou\
      s IP, update needed\"\r\
      \n :set previousIP1 \$currentIP\r\
      \n\r\
      \n# The update URL. Note the \"\\3F\" is hex for question mark (\?). Requi\
      red since \? is a special character in commands.\r\
      \n :local url \"http://dynupdate.no-ip.com/nic/update\\3Fmyip=\$curr\
      entIP\"\r\
      \n :local noiphostarray\r\
      \n :set noiphostarray [:toarray \$noiphost]\r\
      \n :foreach host in=\$noiphostarray do={\r\
      \n :log info \"No-IP: Sending update for \$host\"\r\
      \n /tool fetch url=(\$url . \"&hostname=\$host\") user=\$noipuse\
      r password=\$noippass mode=http dst-path=(\"no-ip_ddns_update-\" . \$host \
      . \".txt\")\r\
      \n :log info \"No-IP: Host \$host updated on No-IP with IP \$cur\
      rentIP\"\r\
      \n }\r\
      \n } else={\r\
      \n :log info \"No-IP: Previous IP \$previousIP1 is equal to current \
      IP, no update needed\"\r\
      \n }\r\
      \n} else={\r\
      \n :log info \"No-IP: \$inetinterface is not currently running, so there\
      fore will not update.\"\r\
      \n}\r\
      \n"
      add name=no-ip_ddns_update2 policy=\
      \n\r\
      -------------\r\
      \n\r\
      \n\r\
      \n:local noiphost \"xxxxxx.no-ip.org\"\r\
      \n\r\
      \n:local inetinterface \"wan2\"\r\
      \n\r\
      -------------\r\
      \n\r\
      \n:global previousIP2\r\
      \n\r\
      \n\r\
      \n } \r\
      \n }\r\
      \n\r\
      \n :if (\$currentIP != \$previousIP2) do={\r\
      \n :set previousIP2 \$currentIP\r\
      \n\r\
      entIP\"\r\
      r password=\$noippass mode=http dst-path=(\"no-ip_ddns_update2-\" . \$host\
      \_. \".txt\")\r\
      rentIP\"\r\
      \n }\r\
      \n } else={\r\
      \n :log info \"No-IP: Previous IP \$previousIP2 is equal to current \
      \n }\r\
      \n} else={\r\
      \n}\r\
      \n"
      /tool netwatch
      add down-script="/ip route set [find comment=load-balance] disabled=yes\r\
      \n\r\
      \n/ip firewall mangle set [find comment=load-balance] disabled=yes" host=\
      110.164.252.222 up-script="/ip route set [find comment=load-balance] disab\
      led=no\r\
      \n\r\
      \n/ip firewall mangle set [find comment=load-balance] disabled=no"
      \n\r\
      203.144.206.29 up-script="/ip route set [find comment=load-balance] disabl\
      ed=no\r\
      \n\r\
      • Originally posted by kookhaha View Post
        ผมใช้ script นี้มาจะ 2 ปีแล้วครับ อัพเดตตลอด
        script no-ip.txt
        • Originally posted by devilnaked View Post
          เอ่อ ขอบคุณมากครับ ผมพยายามทำอยู่ตั้งนาน เลยไปบังคับทำที่ Route เลย ต้องแรกใส่ที่ Prerouting-Routing Mark ทำยังไงก็บังคับทางไปไม่ได้ ตอนนี้ทำได้แล้ว
          • rb2011 v.6.7 เพื่อนๆใช้scriptตัวไหนบล้อคบิทกันครับ ผมใช้ตัวนี้อยู่ก็เนทวิ่งบ้างไม่วิ่งบ้าง พอdisable เนตวิ่งฉิวเลยครับ
            http://http://classicthais.blogspot.com/2014/03/block-bit-mikrotik-450g.html
            • รบกวนสอบถามหน่อยครับ พอดีว่าที่บริษัทต้องการติดกล้องวงจรปิดโดยใช้แบบ IP Camera แล้วผู้รับเหมาเค้าต้องการ 3 อย่างคือ 1.การทำ dyndns 2.forward port 3.ต้องการปิด firewall เฉพาะ ip ที่ใช้กับกล้องวงจรปิด ช่วยแนะนำผมทีครับว่า 3 อย่างนี้ทำอย่างไร หรือถ้ามีตัวอย่างมาให้ศึกษาก็ได้นะครับ ยินดีครับผม
              ขอบคุณล่วงหน้าครับ
              • เงียบกันหมดเลย
                • มีท่านใดเคยเซ็ต mikrotik แบบ pcc load balance + hotspot + web proxy พอดีผมอยากอยาก redirect บางไอพีของ hotspot ไปยัง local web server แต่ผมทำไม่ได้สักที รบกวนด้วยนะครับ
                  • ในกรณีที่ใช้เชื่อมต่อ ONU/Modem bridge<--->MT PPPoE<--->Client
                    มีวิธีปรับแต่ง ให้สามารถเข้าไปดูสถานะของ ONU/Modem ได้มั้ยครับ คล้ายๆกับพวก Tomato,DD-wrt ที่วาง script เอา
                    ONU = 10.0.0.1
                    MT = 192.168.1.1
                    • user login แล้วขึ้น error แบบนี้ครับ
                      "mikrotik failed to add session: columns acctSessionId, ipRouter, nasPortType are not unique"
                      แก้ไขยังไงครับ ช่วยบอกที
                      • ผมมีปัญหาครับ พวก notebook ไม่สามารถเข้าหน้า logim page ได้อะครับไม่รุ้เพราะอะไรแต่พวกโทรศัพท์มือถือสามารถเข้าได้ปรกติ ไม่ทราบว่าพอมีวิธีแก้ไหมครับ
                        • สอบถามผู้รู้ทุกท่านครับ ผมเริ่มทำ hotspot mikrotik ทำหน้า login ได้แล้ว แต่ว่า มือถือ เข้าไม่ได้ กลับกัน คอมพิวเตอร์เข้าได้ ตอนแรก มือถือเข้ามาขึ้นหน้า login ให้ แต่พอเชื่อมเสร็จแล้ว เข้าเว็บไม่ได้เลย ท่านใดรู้ช่วยทีครับ ผิดพลาดตรงไหน
                          • Originally posted by Zepherous View Post
                            ONU = 10.0.0.1
                            MT = 192.168.1.1
                            config ตามนี้
                            Originally posted by tommy605
                            /ip address add interface=etherX address=10.0.0.2/30 comment=Manage_ONU
                            /ip firewall nat add chain=srcnat dst-address=10.0.0.1 out-interface=etherX action=src-nat to-addresses=10.0.0.2 comment=NAT_to_ONU
                            หมายเหตุ: etherX ให้เปลี่ยนตาม physical interface(อินเทอร์เฟสจริง) ที่นำมาเชื่อมต่อแบบ pppoe-client interface(อินเทอร์เฟส pppoe-out1)
                            • Originally posted by k-7 View Post
                              เอา script ที่ config แล้วให้ผมดูก่อนครับ
                              • ขาย RB450G 3,000 บาท รวมส่ง ประกัน D-network ซื้อมาเดือน 06/2557 ที่ขายเพราะเปลี่ยนใช้ Server คล่องกว่า
                                สนใจ โทร 082-8412954 ส่ง พกง.ได้ครับ
