i3-6100 vs fx-6300
  • บ้านจนครับ Cpu 3 พันก่าๆ
    บอรด 1800
    แรม 2พันปลายๆ
    vga ยืมเค้ามา
    GPU: AMD Radeon (TM) R9 Fury Series
    CPU: AuthenticAMD
    AMD A8-7650K Radeon R7, 10 Compute Cores 4C+6G
    Physical Cores: 2
    Logical Cores: 4
    Physical Memory: 14301 MB
    Allocatable Memory: 134217727 MB
    == Configuration =========================================================
    API: DirectX 12
    Resolution: 2560x1440
    Fullscreen: True
    Bloom Quality: High
    PointLight Quality: High
    Glare Quality: High
    Shading Samples: 16 million
    Terrain Shading Samples: 16 million
    Shadow Quality: High
    Temporal AA Duration: 12
    Temporal AA Time Slice: 4
    Multisample Anti-Aliasing: 4x
    Texture Rank : 1
    == Results ===============================================================
    BenchMark 0
    TestType: Full System Test
    == Sub Mark Normal Batch =================================================
    Total Time: 60.081039 ms per frame
    Avg Framerate: 34.852924 FPS (28.691996 ms)
    Weighted Framerate: 34.080479 FPS (29.342310 ms)
    CPU frame rate (estimated if not GPU bound): 50.039459 FPS (19.984228 ms)
    Percent GPU Bound: 95.040413 %
    Driver throughput (Batches per ms): 2198.256836 Batches
    Average Batches per frame: 6996.740234 Batches
    == Sub Mark Medium Batch =================================================
    Total Time: 61.967201 ms per frame
    Avg Framerate: 29.176727 FPS (34.273891 ms)
    Weighted Framerate: 28.806204 FPS (34.714745 ms)
    CPU frame rate (estimated if not GPU bound): 45.262428 FPS (22.093380 ms)
    Percent GPU Bound: 99.337265 %
    Driver throughput (Batches per ms): 3289.365723 Batches
    Average Batches per frame: 14889.599609 Batches
    == Sub Mark Heavy Batch =================================================
    Total Time: 57.977619 ms per frame
    Avg Framerate: 26.906933 FPS (37.165142 ms)
    Weighted Framerate: 26.729830 FPS (37.411388 ms)
    CPU frame rate (estimated if not GPU bound): 36.901947 FPS (27.098843 ms)
    Percent GPU Bound: 98.915642 %
    Driver throughput (Batches per ms): 4294.373047 Batches
    Average Batches per frame: 32623.564453 Batches
      ดูไม่รู้เรื่องนะ
      ลองโปรแกรมนี้ดูนะ
      V
      Originally posted by iambic View Post
      มาลองทดสอบ Unigine 'Valley' Benchmark 1.0 กันครับ
      โปรแกรมนี้เห็นต่างประเทศนิยม test กัน เน้น VGA เป็นหลัก
      Download here Unigine Valley Benchmark
      ทดสอบแบบ Extreme HD นะครับ
      อันนี้ผลเทสจากเวปต่างประเทศ
        ผมชอบ ของใหม่ครับ ทางเลือกใหม่ๆ ไม่ต้องจ่ายเยอะ ขอบคุณครับ
        Ashes of the Singularity Dx12 Benchmark
          Oxide Games
          Ashes Benchmark Test - ฉ2015
          Version 0.61.13854
          == Hardware Configuration ================================================
          CPU: AuthenticAMD
          AMD A8-7670K Radeon R7, 10 Compute Cores 4C+6G
          Physical Cores: 2
          Logical Cores: 4
          Physical Memory: 14263 MB
          API: DirectX 12
          Fullscreen: True
          Bloom Quality: High
          Glare Quality: High
          Terrain Shading Samples: 8 million
          Texture Rank : 1
          TestType: CPU Test (infinitly fast GPU)
          Total Time: 59.965176 ms per frame
          Avg Framerate: 40.206673 FPS (24.871494 ms)
          จริงๆนะครับ Cpu ตัว 3พันกลางๆ
          • 1440P
            Core i4 6100 + GTX 980 Ti
            • Comment
              • cpu ผมถูก เล่น medium ไม่ไหวครับ ต้อง crazy
                • FX-8350 ยังเงิบ
                  • A8 + ddr3 + บอรด ตัว ละพันกว่าบาท
                    • ตอนนี้แฟนบอยแดงเมาหมัดน้ำลายฟูมปากไปหลายรายละ
                      • medium มังครับ
                        • จะเอามโพสทำม้าย โพสว่า ข้าแน่ ทนใช้เทคโนโลยี่เก่าเก่าได้งั้นเหรอครับ มี ddr4 มีอะไรใหม่ใหม่ตามเขาค่อยมาโพสเหอะ
                          • แค่ไม่อยากเสียตังเพิ่ม แต่ใช้ได้เหมือนกันป่าวครับ
                            พอดีที่บ้านผมไม่ค่อยมีตังอะครับ
                            • ผมไม่มีตังแต่ใช้เพนเทียมจีแรงกว่าเยอะใช้งบน้อยกว่าด้วย
                              • ใหม่มาเก่าไป อ้างแรมบัสน้อยหุหุ บลาๆๆๆ
