Originally posted by holeinone
<<< +++ Intel Sandy Bridge i5, i7 CLUB +++ >>>
ท่านลองตามนี้แล้วยังไงก็ไม่ได้ใช่มั้ยครับOriginally posted by ksin View Postasus มีใคร downgrade bios ได้บ้าง ครับ
USE AT YOUR OWN RISK
1. If you haven't already, download BUPDATER version 1.22, make something to boot real DOS and make sure you have backed up your BIOS.
2. Enter BIOS, select F5 and load optimized settings. Save and exit F10. If you want to be ultra cautious you could check stability, in particular RAM using optimized defaults.
2. Reboot to real DOS and run "BUPDATER /pc /g".
3. Select 0804PRO2.ROM and yes to flash. Note that if you select and read a valid ROM image and decide not to go ahead the /pc switch seems to do something anyway and you will probably need to go into the EFI BIOS again and save your settings. Seems like a bug in BUPDATER for it to do that. It may post with "press F1 to enter setup" after detecting improper BIOS settings however if you have "ignore F1" set in the BIOS then it will try to boot with the improper settings so make sure you hit the delete key and get into the BIOS setup before trying to run your OS regardless and save your BIOS settings after checking to be safe.
4. Once you have successfully flashed the modded 0804 image 0804PRO2.ROM you can go into the BIOS setup and flash any of the other BIOS images up to 1305 using EzFlash. If you want to use 0804 you can flash over the modded one with the original 0804 to keep things straight if you wish.
0804PRO2.ROM will only work for images upto and including hardware version 2. If some time later Asus does another hardware version increment then a newer modified 0804 image would have to be made.
I haven't a PRO to test on so please post some feedback, good or bad. If you have any questions or are not sure of something please feel free to ask.
จากเว็ป http://www.xtremesystems.org/forums/....php?p=4761529
เพิ่มเติมครับอ่านดูที่นี่ครับหวังว่าคงได้นะครับ http://support.asus.com/technicaldoc...Language=en-usLast edited by nava; 27 Feb 2011, 18:02:22.
Originally posted by sonny* View Post
ในรูปท่าน OC ไป 4.5 idle อยู่ที่ 40 ก็น่าจะปกตินะครับ
ผมก็ OC ไป 4.5 idle อยู่ที่ประมาณ 37-42 sink Mega halem
ลองแล้วครับ มันยังOriginally posted by nava View Postท่านลองตามนี้แล้วยังไงก็ไม่ได้ใช่มั้ยครับ
version in rom file is older than existing boarder!
ครับผม
แฮะ ๆ ขอ update score หน่อยนะครับ
หลังจากที่ปล้ำมานาน............ กับ Vantage ที่กะว่าจะให้ผ่านที่ 5.4 วันนี้สำเร็จแล้วครับ
สรุป ต้องเพิ่มไฟ Vcore 1.655 ใน Bios
VRAM 1.740
PCH. 0.980
PLL 1.860
ถึงจะผ่าน
แต่ linX ค่าไฟนี้ ไม่ต้องถามเลยครับ กด เป็น Blue 555
