<<< +++ Intel Sandy Bridge i5, i7 CLUB +++ >>>
up ขึ้นที่นี้เลย ^^Originally posted by ksin View Post
http://i301.photobucket.com/albums/nn79/zalbard/LinXClubRed.gif Do you want to join the club? Then make a post and follow the rules: You must have at least 2GB of memory installed in the system. (Update: 31 Jan, 2010) 3GB+ for: Core i5 7xx, Core i7 8xx, Core i7 9xx; 4GB+ for: Core i5 2xxx, Core i7 2xxx. Screenshot must show a CPU-Z window with 4.5GHz+ frequency. (Update: 3 Jan, 2011) Sandy Bridge owners - please only post 5GHz+ submissions. I am keen on preserving the challenge, so I
Originally posted by LASeR09 View Postup ขึ้นที่นี้เลย ^^
http://www.xtremesystems.org/forums/...nX-Stable-Club
คนไทย ไม่แพ้ ชาติใดในโลก *.*
5GHz Club <Under 100 GFlops> (Sandy Bridge and others)
Rank | User | Frequency and # cores + threads | vCore | Motherboard | Cooling type | Full Batch #
- LASeR10 | Core i5 2500K [4C 4T] @ 5508.2MHz | 1.600 | ASUS Maximus IV Gene-Z | Single Stage | L051B314
- porn_43 | Core i7 2500K [4C 4T] @ 5500.0MHz | 1.672 | ASUS P8P67 Pro | Water | L051B314
- TWK_OCZ | Core i7 2600K [4C 8T] @ 5304.4MHz | 1.584 | ASUS P8P67 Pro | Water | L108B128
- Ace. | Core i7 2500K [4C 4T] @ 5300.1MHz | 1.520 | ASUS P8P67 WS | Water | L050A863
- SBB | Core i7 2600K [4C 4T] @ 5254.6MHz | 1.512 | ASUS P8P67 Pro | Water | L040B165
- C-N | Core i7 2600K [4C 8T] @ 5202.0MHz | 1.512 | Gigabyte P67A-UD5 | Air | L040B307
- SteveRo | Core i5 655K [2C 2T] @ 5200.7MHz | 1.776 | Gigabyte H55N-USB3 | Cascade | L008B538
- SteveRo | Core i7 980X [6C 6T] @ 5200.2MHz | 1.728 | Gigabyte X58A-UD7 | Cascade | 3003B287
- Sauron_Vie | Core i7 2600K [4C 8T] @ 5200.1MHz | 1.568 | ASUS P8P67 Pro | Water | L039B470
- porn_43 | Core i7 2600K [4C 8T] @ 5151.2MHz | 1.596 | Biostar TP67XE | Water | L042A969
- Daddyjaxx | Core i7 2600K [4C 8T] @ 5126.9MHz | 1.504 | ASUS P8P67 Deluxe | Water | L042B208
- Friday~13rd | Core i7 2500K [4C 4T] @ 5104.0MHz | 1.500 | Biostar TP67XE | Air | L041C119
- miahallen | Core i7 2600K (ES) [4C 8T] @ 5102.5MHz | 1.448 | ASUS Maximus IV Extreme | Air | ES
- miahallen | Core i5 670 [2C 2T] @ 5101.3MHz | 1.536 | Gigabyte H55N-USB3 | Water | L935B898
- Jor3lBR | C2D E8600 [2C] @ 5100.7MHz | 1.616 | ASUS Rampage Extreme | Phase | Q820A727
- coolhandluke41 | Core i7 2600K [4C 8T] @ 5100.2MHz | 1.480 | ASUS P8P67 Pro | Water | L040B671
- owikh84 | Core i7 2600K [4C 8T] @ 5100.2MHz | 1.536 | ASUS Maximus IV Extreme | Water | L048A937
- donmarkoni | Core i7 2600K [4C 8T] @ 5100.1MHz | 1.488 | ASUS P8P67 Pro | Chilled Air | L040B694
- skeyo | Core i7 2600K [4C 8T] @ 5088.7MHz | 1.428 | Gigabyte P67A-UD7 | Water | L038A660
- miahallen | Core i5 670 [2C 4T] @ 5050.5MHz | 1.536 | Gigabyte H55N-USB3 | Water | L935B898
- little_scrapper | Core i7 2500K [4C 4T] @ 5047.8MHz | 1.408 | ASUS P8P67 WS | Air | 3101A127
- twirlywhirly555 | Core i3 560 [2C 4T] @ 5025.6MHz | 1.520 | Gigabyte H55N-USB3 | Chilled Water | L013B634
- x-built-Stan | Core i7 980X [6C 12T] @ 5022.4MHz | 1.554 | ASUS Rampage III Extreme | Single Stage | 3032A343
- kazukun | Core i7 2600K [4C 8T] @ 5014.8MHz | 1.608 | Gigabyte Z68X-UD7 | Water | L102B549
- nijel | Core i7 2600K [4C 8T] @ 5011.6MHz | 1.404 | Gigabyte P67A-UD7 | Air | L041C108
- PolRoger | Core i7 2500K [4C 4T] @ 5006.9MHz | 1.336 | Asrock P67 Professional | Air | L041C123
- kitfit1 | Core i7 975 [4C 8T] @ 5004.2MHz | 1.552 | EVGA Classified E760 | Single Stage | -
- PolRoger | Core i7 2600K [4C 8T] @ 5002.8MHz | 1.416 | Biostar TP67XE | Air | L041C106
- the_real_7 | Core i7 2600K [4C 8T] @ 5001.8MHz | 1.391 | Gigabyte P67A-UD7 | Water | L040B705
- tnc99 | Core i7 2600K [4C 8T] @ 5001.7MHz | 1.452 | Gigabyte P67A-UD7 | Water | L041B213
- C-N | Core i7 2500K [4C 4T] @ 5001.5MHz | 1.445 | Gigabyte P67A-UD5 | Air | L041B517
- OC Nub | Core i5 660 [2C 2T] @ 5000.7MHz | 1.552 | Gigabyte P55A-UD6 | Water | L935B896
- KURTZ | Core i7 2600K (ES) [4C 8T] @ 5000.3MHz | 1.416 | ASUS P8P67 | Water | ES
- The Nemesis | Core i7 2600K [4C 8T] @ 5000.1MHz | 1.520 | Maximus IV Extreme | Water | L042B243
- famich | Core i7 2600K [4C 8T] @ 5000.1MHz | 1.448 | ASUS P8P67 Deluxe | Water | L041B213
- SimpleTECH | Core i7 2600k [4C 8T] @ 5000.0MHz | 1.440 | Asus P8P67 Pro | Water | L040B208
__________________
รายการเด็กเล่น ...Originally posted by ksin View Postคนไทย เมพๆ น่าจะติดรูปธงชาติ เล็กๆ ด้วยเนอะ เท่ดี เหอๆ
อยากเมพ มังอะ
ธงชาติ ที่นี้เลย โชว์พาว์ อุณหภูมิ ได้ ^^
เล่นฟรี 1 หัว กับ 2 หัว พอไหว ^^
จัดไป 5.5G รอชมอยู่ ^^
ต้องเทสให้ restart หรอครับ ? ไม่เคยเทสตัวนี้*** ถ้าไม่อยากคิดมาก i7 2600K ลองคล๊อกตามที่ผมเทสแล้วได้เลยครับ (ทดสอบกับ megahalem + MX-4 + พัดลม 1 ตัวปรับรอบ 1200 rpm) รัน LinX 8GB 20 loop 5 รอบ restart ทุกรอบ คิดว่าน่าจะเสถียรใช้งานได้ 24/7 สบาย และเสียงไม่ดังจนน่ารำคาญเวลาใช้ครับ ***
