แมวเทพ AMD Shader Cache วันนี้คุณกินแมวหรือยาง reduced game load times CPU stutter ^^
AMD Radeon Software Crimson Edition
DX12 ได้แรงขึ้นอีก สินะ
AMD promises that these drivers have all the latest optimizations for the holiday game titles and if you are playing game titles like Star Wars Battlefront or Call of Duty: Black Ops 3 you?ll want to be using Crimson drivers! Check out the release notes and AMD Radeon Software Crimson Edition video card driver overview video below.
?Radeon Software Crimson Edition is AMD?s revolutionary new graphics software that delivers redesigned functionality, supercharged graphics performance, remarkable new features, and innovation that redefines the overall user experience.
Radeon Software Crimson Edition ventures beyond the realm of traditional graphics driver software to deliver extraordinary performance and precise control of graphics, video, displays, and forward-thinking power efficiency from the latest AMD technologies and advances:
Fast high-speed game loading with Shader Cache.
Optimized Flip Queue Size provides users with the very latest keyboard and mouse positional information while gaming
Frame Pacing: smoother gaming enhancements enabled on DirectX 9 games
Enhanced image quality for 1080p media content scaled to 4K using adaptive directional filtering technology
Fine-tuned Dynamic Contrast algorithm
Enhanced Video quality settings for 6th Generation A-Series AMD APUs
Display Port to HDMI 2.0 dongle support
Customizable display settings with fine tuning for resolutions, timings, and refresh rates
AMD FreeSync technology enhancements including AMD CrossFire? support for DirectX 9 games and low frame rate compensation for smoother gameplay when below the minimum refresh rate
Incredible power efficiency for select products and applications through power optimizations
Frame Rate Target Control enhancements including; power saving capability, support for DirectX 9 games and extended range for target control (20 ? 200 FPS)
AMD Radeon Software Crimson Edition Features:
Radeon Settings:
Radeon Settings is the new, streamlined user interface, engineered to bring out the best of AMD graphics hardware. User-friendly and feature-rich, Radeon Settings is lightning fast and starts upto 10x times faster? than the previous AMD Catalyst Control Center. Radeon Settings provides a brand new game manager, improved AMD Overdrive options per game and new video, display and Eyefinity tabs.
New Install UI:
The driver installer now provides a brand new, streamlined user experience with a reduced number of clicks required, providing better usability and an easy to install user experience.
Liquid VR:
The AMD Radeon Software Crimson edition is the first publicly available driver that enables all LiquidVR features, which are currently being validated and tested by VR headset manufacturers and ecosystem partners.
Asynchronous Shaders:
A feature that has been extensively used by game console developers is now available to PC Gamers. Asychronous Shaders break complex serial workloads into smaller parallel tasks, thereby allowing idle GPU resources to be used more efficiently and parallel workloads allow taskes to be completed much faster.
Read more at http://www.legitreviews.com/amd-rade...958GIf49rbJ.99Last edited by THEFOOL; 25 Nov 2015, 11:18:06.
Click the Home button in Cnext > Preferences > Radeon Additional Settings.Originally posted by daimon View Postสอบถามหน่อยครับ ปรับ Dynamic Full 0-255 ตรงใหนครับเหมือนมันหายไป
This will open CCC "lite" which should have switchable settings.
Unless your graphics card is part of those that have a bug and won't show any switching settings in CCC.
ลองดูตามนี้ครับ
ไม่แน่ใจว่าจะมีให้ปรับหรือป่าวนะครับ พอดีใช้ DP 1.2
ลด Input lag ได้นี่มันแหล่มจริงๆ
Moving to a single buffer, as AMD's example above shows, can reduce input lag to 16.7 ms on a 60Hz display, versus 50 ms with triple-buffering enabled. AMD says this improvement makes mouse and keyboard input more responsive. We don't see a per-application setting for the flip queue size in Radeon Settings, so we're guessing that Crimson manages it automatically.
ปรับใน player ก็ได้ครับ ถ้ามันไม่มีให้ปรับจริงๆOriginally posted by daimon View Postสอบถามหน่อยครับ ปรับ Dynamic Full 0-255 ตรงใหนครับเหมือนมันหายไป
ตรงหน้า custom มีให้ปรับรึเปล่าหว่า
+1Originally posted by aosbee View Postเหมาะสำหรับเกมออนไลน์เลย
อย่าลืมเปิดใช้กันด้วยนะ จริงๆ AMD ก็เลือกไว้ AMD optimized ไว้อยู่ละ
Shader Cache ? Smoother Gameplay And Faster Load Times
We?ve mentioned faster game load times earlier, which have rarely traditionally been part of the focus for graphics drivers, but with Radeon Crimson Edition they are. Shader Cache is a brand new feature that?s debuting with Crimson. Thanks to the re-architected drivers, shaders can now be compiled and sorted into a cache on your SSD or hard drive, in both cases enabling significantly faster load times. The feature is especially of benefit in open world games like the Battlefield series, Fallout 4 or The Witcher 3 where load times are generally speaking lengthier than in other linear games.
Read more: http://wccftech.com/amd-radeon-softw...#ixzz3sTVNm695
ใครเล่นเกม open world เจอพลังแมว
ถ้าไม่อย่างนั้นก็ไปที่ C:\AMD\Radeon-Crimson-15.11-Win10-64Bit\Config
หาไฟล์ที่ชื่อ Language.Dat ครับ จะเป็น ตัวทำให้ติดตั้งเป็นไทย แก้ไปเอาของ en มาใส่แทน ก่อน setup ไดวเวอร์การ์ดจอ
มั้งนะ เดาเอา
## This will contain all of the Supported Languages ##
## The format is as follows: ##
## [Name]=[Value] ##
None=00
English(English)=01
???????(Arabic)=02
?e?tina(Czech)=03
Dansk(Danish)=04
Deutsch(German)=05
????????(Greek)=06
Espa?ol(Espa?ol)=07
suomi(Finnish)=08
Fran?ais(French)=09
?????(Hebrew)=10
Magyar(Hungarian)=11
Italiano(Italian)=12
???(Japanese)=13
???(Korean)=14
Nederlands(Dutch)=15
Norsk(Norwegian)=16
Polski(Polish)=17
Portugu?s (BR)(Portugu?s (BR))=18
???????(Russian)=19
Svenska(Swedish)=20
ไทย(Thai)=21
T?rk?e(Turkish)=22
??????(Chinese (Simplified))=23
??????(Chinese (Traditional))=24
All=25
