Gtx 880 maxwell20nm จะไม่มาปีนี้ครับจ ะมาแค่การ์ดระดับกลาง ความแรงควบคุมได้อยู่แล้วต่อให้เป็น maxwell GTX750Ti ก็ไม่แรงกว่า 760
อ้างอิง
Well this is interesting. According to SweClockers NVIDIA will launch the first Maxwell GPU with the graphics card from GeForce 700 series ? not 800.
As we told you numerous times before first Maxwell GPUs are not high-end parts. Instead NVIDIA decided it will slowly progress to 20nm process with more advanced GPUs later.
The first Maxwell GPU, probably GM107, will be used with GeForce GTX 750 Ti, a new mid-range graphics card replacing GeForce 650 Ti. The exact details remain unknown, but are almost 100% sure its 28nm process GPU.
The new feature of the Maxwell architecture is a coherent memory, which is basically a special buffer for both CPU and GPU. This feature is not exactly new, it is available through CUDA interface, but this time NVIDIA will take this to the hardware level. According to SemiAccurate sources NVIDIA has not yet prepared a GPU with built-in ARM processor (similar to Tegra K1), instead first Maxwell GPUs would simply use a special onboard controller. In fact I don?t see the point of Project Denver in mid-range GPUs. Hopefully this will be fully implemented with the high-end GeForce GTX 800 models later this year.
Source: SweClockers
อ้างอิง
Source: SweClockers
