ATI Catalyst™ 10.5a Hotfix
ATI Catalyst Version 10.5 Release Notes
ออฟชั่นใหม่ ของ ATI 10.5 ใครสนใจจะเปลี่ยนมาใช้ ลองอ่านดูคับ
เท่าที่ดู รู้สึก แก้ปัญหา ทั้งเล่นเกมส์ ทั้งปัญหา ในการดูหนัง ทั้งแก้ปัญหา ใน วินโดว์ ที่ ค้าง ต่างๆ พร้อม บางเกมส์ ก็ ปรับไปด้วย แก้ปัญหา ไดวเวอร์ชั่นเก่าๆ ไปหลายอย่าง เลยนะ
New Features
This section provides information on new features found in this release of the ATI
Radeon™ Display Driver. These include the following:
Support for 120 Hz displays on the ATI Radeon™ HD 4000 Series and ATI
Radeon™ HD 3000 Series
ATI Overdrive enhancement full support for multiple display configurations
Series and ATI Radeon™ HD 3000 Series
ATI Catalyst™ now supports 120 Hz Displays for the ATI Radeon™ HD 4000 and
configurations
ATI Overdrive has been enhanced delivering full support for over-clocking
functionality on supported ATI Radeon™ HD graphics accelerators connected to
Resolved Issues for All Windows Operating Systems
This section provides information on resolved issues in this release of the ATI Catalyst™
Software Suite for Windows. These include:
"Battlefield 2: Bad Company" maps no longer takes unusually long to load
Enabling hardware shaders (perfect mode) no longer causes text and on-screen menu
corruption while loading missions in "IL-2 Sturmovik: 1946" game
Re-logging into a system after a Remote Desktop connection no longer results in
"Catalyst Control Center is not supported..." warning message or the Graphics menu
for Catalyst Control Center Advanced view to go missing
HDTV resolutions are now properly reported by the tooltip when the mouse cursor
hovers over the CV display icon under "Desktops & Displays" in Catalyst Control
Center
ATI Catalyst™ Release Note Version 10.5 6
Resolved Issues for the Windows 7 Operating System
Software Suite for Windows 7. These include:
Alt-Tabbing to desktop and back into "Mass Effect 2" game no longer causes the
display to go black
In-game Anti-Alias can now be applied when other in-game options like Volumetric
Effects are enabled in "Empire: Total War" and "Napoleon: Total War" games
Enabling Anti-Alias in "Empire: Total War" no longer causes a performance drop
Running "Unigine Heaven Benchmark 2.0" in wireframe mode with tessellation
enabled no longer causes the application to fail on ATI Radeon HD 5000 Series cards
Changing in-game resolution in "Alien vs. Predator" no longer causes the screen to
flicker under Multi-GPU configurations
Catalyst Control Center now remembers the position of fourth monitor in Eyefinity
group
Black screen no longer observed with "Unigine Heaven Benchmark 2.0" application
with OpenGL mode settings
Enabling dynamic contrast in Catalyst Control Center video settings no longer causes
vertical stripes to appear during XVID content playback
Resolved Issues for the Windows Vista Operating System
Software Suite for Windows Vista. These include:
[Catalyst Control Center] Avivo basic color controls in the "All Settings" page can
now be applied and will not shift to default values
HBR (high bit-rate) audio now functions properly
"Tom Clancy's Splinter Cell Conviction" no longer fails during game play for ATI
Radeon™ HD 2000 and 3000 series cards
Resolved Issues for the Windows XP Operating System
Software Suite for Windows XP. These include:
"Resident Evil 5" now launches properly with a HDMI display connected to an AGP
card
PowerDVD no longer exhibits blue and pink tint when adjusting brightness and
contrast in Catalyst Control Center when viewing Blu-ray content
Known Issues Under All Windows Operating Systems
The following section provides a summary of open issues that may be experienced under
the Windows operating system in the latest version of Catalyst™. These include:
Disabling CrossFire™ for the first time may cause the "Contrast" value to change to
zero in Catalyst Control Center - Display Properties Color page
ATI Catalyst™ Release Note Version 10.5 7
Known Issues Under the Windows 7 Operating System
the Windows 7 operating system in the latest version of Catalyst™. These include:
Corruption may be observed during "Bioshock 2" gameplay in DirectX 9 and
DirectX 10 mode with CrossFire™ enabled
PowerDVD may exhibits blue/pink tint and might not display smooth transition when
adjusting brightness and contrast in Catalyst Control Center when viewing Blu-ray
content
Grass and crop may be rendered randomly at unusual locations in "Battlefield 2: Bad
Company" game scenes
[Windows 7 64-bit] Under specific Multi-GPU configurations, "Desktop Window
Manager has stopped working" error may appear after driver installation and will not
be enabled until after restart
[Catalyst Control Center] Customized Avivo video settings may revert to default
values after resuming from sleep/hibernation during SD or Blu-ray playback
Drag and Drop transcoded H264i content may experience audio and video
synchronization issues and deinterlacing lines when viewed on some devices
Under Multi-GPU configuration with Crossfire™ enabled, setting both "Shaders
Quality" and "Post-Processing Quality" to "Enthusiast" may cause the frame rate to
drop in "Crysis Warhead" DirectX 9 game
Green texture corruption may be observed when resolution/video settings are
changed in "Metro 2033" game in DirectX 10 and 11 mode on some cards
Assigned hotkeys may fail to be retained for "Desktops & Displays" after Catalyst
Control Center restart
Known Issues Under the Windows Vista Operating System
the Windows Vista operating system in the latest version of Catalyst™. These include:
Performing bezel compensation on 3x2 Eyefinity configuration may cause the bezel
group (resolutions) to go missing
ตอนนี้ ผมใช้อยู่ 10.5 + sdk 2.1 ปรกติ ไม่มีปัญหา Error แฮ้ง ใช้งานได้ปรกติ อยู่คับLast edited by THEFOOL; 29 May 2010, 20:20:14.
ผมไปดูมาตะกี้ ของ ATI Catalyst™ 10.5 ตัวที่ปล่อยโหลด ที่ เวป amd เลยนะคับ
DriverVer=05/04/2010, 8.732.0.0000 เอง
ส่วน ATI Catalyst™ 10.5 hotfix ออก
DriverVer=05/27/2010, 8.732.1.0000
แต่เท่าที่ดู คาดว่า คงเป็นตัวเดิม ที่ออก 05/04/2010 คับ เพราะเป็น 8.732
แล้ว จับมายัด hotfix เพิ่ม แก้ โหลดเกมส์ ที่ลืม ยัด ของ ati 4000+ นะ
ส่วนตัวนี้ ati 10.6 เด่ว รอ 10.6 ตัวนี้โหลดเสร็จก่อน 55+
อีก 20 นาที โหลดเสร็จ ไฟร์ ใหญ่ มาก 300 mb นะ
-.-Last edited by THEFOOL; 29 May 2010, 22:11:31.
10.6 โหลดเสร็จละ มัวแต่ไปโม้ในกระทู้อื่นไม่ได้ดูว่าโหลดเสร็จ
DriverVer=04/06/2010, 8.740.0.0000
อันนี้วันนที่ออก เดือน 4 จริงๆ ด้วย
แต่เดี่ยวไปลอง ก่อน คับ
คร่าวๆ ที่โหลด มา มีทั้ง ไดวเวอร์ การ์ดจอ ไดวเวอร์ raid ไดวเวอร์ บอร์ด เรียกได้ว่า ครบ ชุดเลย
เดี๋ยวขอไปลองก่อน งับ
งานนี้ ถ้า เดี่ยวไป งมไดวเวอร์ก่อน ถ้าไม่งานเข้า ถึงวินโดว์ ล้ม คงได้เจอกันไวคับ 55+Last edited by THEFOOL; 29 May 2010, 22:48:31.
