[Review]HIS Radeon HD 5970 CrossFire
  • #31
    Value and Conclusion
    * At US $599 a piece, two Radeon HD 5970 accelerators should typically set you back by $1200. You will also need a motherboard with two PCI-Express slots, which supports ATI CrossFire technology.
    * Fastest setup possible
    * Support for DirectX 11, DirectX 10.1
    * Some things just look better in pairs™
    * Low idle power consumptions of each card makes overall idle power draw comfortable
    * Excusably quiet in idle
    * GDDR5 memory
    * Support for software based voltage control
    * Support for AMD EyeFinity Technology
    * Native HDMI & DisplayPort
    * Improvements to integrated HDMI audio device
    * High price, really!
    * Fails several game tests at 2560x1600
    * Not useful for resolutions lower than 2560x1600
    * Requires a CrossFire supportive motherboard with two PCI-Express slots
    * Massive heat output
    * DirectX 11 won't be relevant for quite a while
    * No support for CUDA / PhysX
    9.3 It sure isn't the most sensible thing to spend $1200 on two graphics cards, that dump about 600W of heat in your room when fully loaded, that barely fit inside your computer, and that make a quite some fan noise. But oh boy, the frames fly like you've never seen before! The "All Resolutions" performance summary graph simply doesn't do justice as HD 5970 CrossFire gets irrelevant, and CPU-limited in lower resolutions. 2560x1600 seems to be the only resolution where having a pair of these will allow you to splurge on eye-candy like never before.
    If you want to build the fastest rig money can buy then a HD 5970 CrossFire setup is what you need. Die-hard overclockers all over the planet will open their wallets and camp the online stores to get a pair of these, unfortunately supply will be limited.
    Should you not belong to the most extreme crowd of gamers or tweakers then it might make more sense to get a single HD 5970 or "only" a HD 5870 because these cards offer much better price/performance ratios. It should also be noted that the drivers do not seem to be in a fully finalized state yet. Three of our benchmarks failed to run at 2560x1600, which, for this kind of product, is the only resolution that really counts in the results. I am confident however that AMD will quickly address these issues in a future driver version.
    • #32
      • #33
        ผมว่า เดี๋ยวราคามันก็น่า จะลง อ่า ครับ แค่เมื่อไร เท่านั้นเอง หุหุ - -
        • #34
          อ่านเจอราคาราวๆ20000+
          ถ้าลดเดือนละ1000
          10เดือนก็10000+ ราคาพอยอมรับได้
          แต่10เดือนข้างหน้าอะไรที่ดีและคุ้มกว่าก็คงจะมา
          • #35
            ไอ้ การ์ด pci 1x สีดำนั้นมันคืออะไรครับ
            • #36
              599$
              ซื้อคอมใหม่ดีก่า
              • #37
                ความรู้จดจดจด((จำทำไมเนี้ย))
                • #38
                  มัน 5970 crossfire นะครับ ตัวละ 26000
                  2 ตัวก็ 52000 แต่ก็ปั่นเฟรมซะสะใจใจเลย
                  แต่คนที่จะใช้คงต้องเล่น res. 2560 x 1600 ถึงจะคุ้ม
                  CPU คงต้องเป็นตระกูล extreme ถึงจะดึงความแรงออกมาหมด
                  • #39
                    ความแรงอันยิ่งใหญ่..ต้องมาพร้อมกับกระเป๋าตังค์ที่ใหญ่กว่า
                    • #40
                      ฝรั่งเขา ซื้อมา cf กันได้อยู่
                      อิจฉา 5555
                      • #41
                        แรงจัดอิอิอิอิอิระบบทีใช้มีอะไรบ้างครับ
                        • #42
                          เเรง อิบอ๋าย วายวอด
                          เเรงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงงง
                          • #43
                            นานาจิต ตก!!!!!!
                            อยากเอามานอนกอด
                            555+
                            • #44
                              แรงจริง ๆ นะเนี่ย
                              • #45
                                ใบเดียวก็พอแล้ว
