GeForce Driver 182.50 WHQL มาแล้วค้าบ
  • GeForce Driver 182.50 WHQL มาแล้วค้าบ
    182.50 WHQL
    This is a WHQL-Certified driver for GeForce 6, 7, 8, 9, and 200-series desktop GPUs.
    New in Release 182.50:
    Optimized single GPU and SLI support for upcoming PC games.
    Numerous bug fixes. Refer to the release documentation notes.
    Users without US English operating systems can select their language and download the International driver here.
    New in Release 182 Drivers:
    Boosts performance in several 3D applications. The following are examples of improvements measured with Release 182 WHQL drivers vs. Release 181.22 WHQL drivers (results will vary depending on your GPU, system configuration, and game settings):
    Up to 8% performance increase in Fallout 3 at high resolution and AA.
    Up to 10% performance increase in F.E.A.R. 2: Project Origin
    Up to 9% performance increase in Half-Life 2 at high resolution with AA.
    Up to 11% performance increase in Left 4 Dead at high resolution with AA.
    Up to 10% performance increase in Race Driver: GRID at high resolution and AA.
    Includes full support for OpenGL 3.0 on GeForce 8-series, 9-series, and 200-series GPUs.
    Automatically installs the new PhysX System Software version 9.09.0203.
    Existing Support:
    Supports single GPU and NVIDIA SLI technology* on DirectX 9 and OpenGL including SLI support on SLI-certified Intel X58-based motherboards.
    Supports NVIDIA PhysX acceleration on a dedicated GeForce graphics card. Use one card for graphics and dedicate a different card for PhysX processing for game-changing physical effects. Learn more here. Note: GPU PhysX is supported on all GeForce 8-series, 9-series and 200-series GPUs with a minimum of 256MB dedicated graphics memory.
    Supports GeForce Plus Power Pack #2. Download these free PhysX and CUDA applications now!
    Supports CUDA.
    Supports GPU overclocking and temperature monitoring by installing NVIDIA System Tools software.
    *Note: The following SLI features are only supported on Windows Vista: Quad SLI technology using GeForce 9800 GX2 or GeForce GTX 295, 3-way SLI technology, Hybrid SLI, and SLI multi-monitor support.
    ลองกันรึยังจ๊ะ ลองเลย
    http://www.nvidia.com/object/winxp_182.50_whql.html
    เค้าไป 185.20 กันแล้ว -*-
      โหลดที่ใหนหรอครับ
        อ๋อรู้แล้ว แต่ 182.50 นี้ ได้รับการประทับตรา หัวม้าลาย เอ๊ย..!! ประทับตรา WHQL แล้วนะ
        งั้นไม่เอามาบอกหรอก
          เดี๋ยวนี้เค้าไป 185.65 กันแล้วครับ
          Guru3D.com - Your go-to source for tech news, reviews, and in-depth analysis of graphics cards, processors, motherboards, gaming hardware, and software from companies like AMD (Radeon) Intel (Core) and NVIDIA (GeForce). Stay updated with the latest trends and innovations in the world of technology .
            http://www.guru3d.com/news/download-...windows-vista/
            กำ...ตกข่าวได้ไง เดี๋ยวเอามาลองเทส 06 ก่อน หิหิหิ
              กำ 185.65 มาแล้วรึ
              มีใครลองแล้วได้ผลยังไงมารายงานด้วยนะครับ จะรอ อิอิ
                  ได้การอย่างไร แล้วมาบอกกันด้วยนะท่าน ...
                  ปล.ท่านอาจจะไม่ได้ตกข่าวหรอก ... เพราะมันออกแบบคลานตามกันมา กับตัว WHQL
                    185.65 ดียังไงมาบอกกันด้วยนะ คุณ TWK
                      ขอบคุณมากครับ ขอดูดไปลองเลยละกัน^^
                        185.66 ออกมาอีกแล้วครับ ....
                        จาก Nvidia เลย ..
                        ไปเลือก XP / Vista กันเองนะครับ
                          เวอร์ชั่นไหนแรงสุด ลงxpนะครับ
                            ตามหลักแล้ว ใหม่สุดก็ต้องแรงสุด แต่เลือกเอาครับ Beta หรือ WHQL
                              185.66 มาแล้วรึ - -*
                              เล่นออกdriver รายวันเลยนะเนี่ย ฮ่าๆ
