Oh my god !! you electric bill will be very high too hahahaha but if you enjoy is ok, next month i will try 4870x2 2G also then you can see after the end of Feb
well my electric bill okay just wait till tomorrow because have my full water kit here but only the best Koolance, Aqua computer, feser , i have some mean looking GF295 cooling blocks to show i have spent around 300,000 on this computer then that's me just waiting for a new Asus P6T De New Hard drive because problem with Seagate 1TB frimewire fault and new OCZ Memory because fault i know too many fault noy jai mak
USA Import coming via DHL Now waitng for it to go Japan then Thailand :-(
i should have used ups would have been here today but was not sure on the route.. because stops in Anchorage it would have been Taiwan then Bangkok alot faster jing jing to DHL
Koolance 62 Line items
1/Lamptron Black Aluminum FC-2 Fan Controller - 45 watts / 6 Channels
1/Aquaero 4.00 USB Fan-Controller, VF
1/Black Faceplate for Aquaero
2 /Aqua Computer Poweradjust USB (with mounting kit)
1/Aquatube G1/4 Delrin black with fittings
1/Black Faceplate for Aquatube
1/ aquabay AT (installation bay for aquatube
2/ UN Designs Z-Bracket for 3G or Absolute Pump Brackets
9/ Blacknoise Noiseblocker Multiframe S-Series M12-S1 51.2 CFM
1/ Logisys Dual White 12in. CCFL Light kit
1/ Noise Isolator PSU Vibration Dampener Kit - Black
1/ Noise Isolator 3.5" Hard Drive Silicon Rubber Protective Skin
2/ Hard Drive Vibration Absorber for 3.5in. Drives
2/ SATA II Cable Black 24" 180 to 90 degree connector
1 /TIM-Consultants - T-C Grease™ 0098 Thermal Interface Material
1 /Floppy Black 18"
1/ Bitspower Rad Support
1/ Swiftech MCB-120 Rev 2 Radbox Radiator/fan housing - Black
2 / Feser One F1 Cooling Fluid - UV Black - 1 Liter
1/ Lian li 5.25 inch Black Dvd Rom front cover
3/ Lian li 5.95 Color = Black Mesh cover
2/ DD12V-D5 Pump Variable Speed by Laing
2 /Feser X-Changer QUAD 480 Extreme Performance Radiator
8/ Feser TFC Xtender - Radiator Shroud 120 - BLUE LED
2/A.C. Ryan AcrylPanel 3mm 480x480mm Black
Black Heatshrink 1/2 inch - 5 foot
Custom Cut Length 3/8 Expandable Sleeving - 10 foot
Tygon R3603 7/16 x 5/8" AAC00033 50 Foot
