Benchmark WarHead, Farcry2, 3DMark Vantage, GF295sli
  • Benchmark WarHead, Farcry2, 3DMark Vantage, GF295sli
    Benchmark Crysis WarHead, Farcry2, 3DMark Vantage, GF295sli
    3DMark Vantage,
    Farcry2,
    Crysis WarHead,
    Crysis Warhead Benchmark
    v1.1.1.0
    The benchmark started at 1/26/2009 831 PM
    System Information
    Operating system: Windows (TM) Vista Ultimate
    System memory: 4.0 GB
    CPU: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
    CPU speed: 3700 MHz
    Graphics card: NVIDIA GeForce GTX 295 - 0 MB
    Benchmark information
    Demo: Cave
    Quality: Very High (tweaked)
    Renderer mode: DirectX 10
    Antialising mode: 16xQ
    Filtering mode: Anisotropic 16×
    MultiGPU support: Enabled
    Boost renderer: Disabled
    Use Custom Config File: No
    Random .exe: Disabled
    Resolution: 1920×1080 (HD WideScreen)
    Result(1): Minimum= 37 FPS Average= 81 FPS Max= 186 FPS
    v1.1.1.0
    The benchmark started at 1/26/2009 814 PM
    System Information
    CPU speed: 3700 MHz
    Demo: Cave
    Resolution: 1280×768 (HD WideScreen)
    Result(1): Minimum= 41 FPS Average= 88 FPS Max= 153 FPS
    v1.1.1.0
    The benchmark started at 1/26/2009 810 PM
    System Information
    CPU speed: 3700 MHz
    Demo: Cave
    Resolution: 1600×1200
    Result(1): Minimum= 42 FPS Average= 82 FPS Max= 142 FPS
    System SpecsCPU maker: CPU: i7 920
    Motherboard: Asus P6T DE
    GPU maker: Graphics Card: XFX GTX 295 & ASUS ENG TX 295 SLI
    Memory: Ocz 12/1600 Triple Channel DDR3
    Hard Drive: Seagate 1TB
    Optical Drive: Pioneer DVR-S16FXB DVD-RW 20X / SATA / Black Piano
    Power Supply: ThermalTake ToughPower 1200
    Display: Samsung 23" 2333SW
    Case: Cooler Master Stacker 832 Black
    Sound Card: SB X-Fi Titanium Fatal1ty Champion Serie
    Speakers: Pioneer High Power AV Receiver / S-MS700/S-EW2
    Mouse: Logitech MX5500
    Mouse pad: Cooler Master Stacker
    Keyboard: Logitech MX5500
    Operating System: Vista Ultimate 64bit
    The best !
      55555 i think so here in thailand but still not in the usa and uk
        Could you please post a bigger Vantage score pic. I can't see it clearly ,thanks.
          just worry about price.
            here the link then your going to have to zoom in to see
              100.000 plus this computer from, jedicool also not give me any discount but thats thai chinese for you also not good if have problems not really care i sometimes have problems with Memory if computer on for along time say 24hrs then it starts to crash i think fault on this p6t but they will never change it for me i've been to the shop so many time also i stay in pattaya i told them change my p6t but never do they say everything ojay no problem how you know only see for 4 hours try 24 hrs or longer then you will see but never they do so next time i have problem i just sent it back to asus any how they lose me i spend alot on computer alwats update when something new comes out i just not go there shop i sum num na them now
                sorry to hear that...
                  mai pen rai its okay i can understand greedy mak mak never offer me anything seat drink but they lose have so many girls in there shop dont know what they are doing if i had very big money for sure in pantip i open the best overcloking shop because i know what to buy i know what will sell same when get 2 vga card they not understand what i'm doing everybody in shop go i'm 1st who buy 2 vga lol
                    ซวยเลย ตอนเด็กๆดันไม่ตั้งใจเรียนภาษาอังกฤษ
                      english ซวยเลย ตอนเด็กๆดันไม่ตั้งใจเรียนภาษาอังกฤษ
                        ไรแว้ อ่านไม่ออกอุ๊ย
                          try to see
                            i know same not easy to see but i was using a 40inch lcd but change because kill all my vga when Benchmark now use 23inch but far cry about the same as Crysis Warhead Benchmark
                              Anyway, welcome to OCZ nicky hope to see your OCing benchmark score from your superb PC next time...
                              Ps. Sorry for my poor english skill...55555(ha-ha-ha)
