สืบเนื่องจากปัญหาข่าวลือ BUG ในระบบคอมพิวเตอร์ที่ใช้ CPU AMD ประสิทธิภาพอาจลดลง 5-30%
  • #46
    ใครทำระบบคอมหรือเปิดเครื่องขุดก็เอา tool ตัวนี้มา scan เครื่องดูก็ดีนะครับว่ามีช่องโหว่ Meltdown หรือ Spectre หรือเปล่า เงินจะได้ไม่หาย ทำตามวิดีโอได้เลย
    อย่าลืมอัฟเดท แพทวินโดว์ และ อัฟเดทไบออส ปิดแมงใน CPU intel กันด้วย นะครับ
    • #47
      Intel CEO sold $39 million in company shares prior to disclosure of CPU security flaws
      CEO Intel ขายหุ้น บริษัท จำนวน 39 ล้านเหรียญสหรัฐก่อนที่จะเปิดเผยข้อบกพร่องด้านความปลอดภัยของ CPU
      A security flaw in Intel CPUs recently came to light that the company did its best to downplay, even as it put off releasing a comprehensive statement amid rising concerns about the possible performance impact of a fix. It's impossible to quantify how bad the situation actually is at this early point, although obviously it's not ideal.
      What may be worse, however, is news that Intel CEO Bryan Krzanich unloaded millions of dollars of Intel shares?the maximum amount he was allowed to sell, in fact?after security researchers revealed the flaw to Intel, but before it became widely known to the public. An Intel representative told MarketWatch that the sale was unrelated to the security vulnerabilities, and the sale was made as part of a 10b5-1 plan, which as Investopedia explains is a mechanism that helps corporate insiders avoid accusations of insider trading by setting up plans to sell predetermined numbers of shares at a predetermined time.
      In this case, Krzanich set up the plan just a month before the shares were sold, in the period between Intel's initial discovery of the exploit, but before its public disclosure. That in itself is not evidence of wrongdoing, and it's worth emphasizing that he is not facing any accusations of impropriety. However, the circumstances surrounding the sale may attract the attention of the SEC, particularly given its value, which was in excess of $39 million.
      If it does opt to investigate, the scrutiny won't do Intel any favors. The announcement of the security vulnerability led to Intel's worst day on the market in eight months, and an SEC investigation isn't the sort of thing that's likely to inspire confidence in a quick bounce-back.
      We've got a detailed rundown of the Meltdown and Spectre exploits, which despite Intel's reassurances "could be more far-reaching than any previous exploit." You can also see Meltdown in action here.
      ฟันกำไร 39 ล้าน
      ก่อนหุ้นตก
      • #48
        Smile if you have an AMD chip (for now).
        Do Meltdown and Spectre affect AMD CPUs?
        AMD claims that its CPU architecture is immune to the attacks, though this statement may have been made prematurely. Because exploits have different variants, current analyses only show that AMD CPUs are safe against the current version of Meltdown, which focuses primarily on Intel?s architecture. The Meltdown paper has the following statement:
        "We also tried to reproduce the Meltdown bug on several ARM and AMD CPUs. However, we did not manage to successfully leak kernel memory with the attack described in Section 5, neither on ARM nor on AMD. The reasons for this can be manifold. First of all, our implementation might simply be too slow and a more optimized version might succeed. For instance, a more shallow out-of-order execution pipeline could tip the race condition towards against the data leakage. Similarly, if the processor lacks certain features, e.g., no re-order buffer, our current implementation might not be able to leak data. However, for both ARM and AMD, the toy example as described in Section 3 works reliably, indicating that out-of-order execution generally occurs and instructions past illegal memory accesses are also performed."
        So far, then, AMD processors haven't been affected by Meltdown, but they're not immune against Spectre, which uses a wider range of speculative execution features. Spectre impacts CPUs from AMD, ARM, and Intel, and the cure may in some ways be worse than the disease, depending on how much it impairs performance.
        เอเอ็มดีอ้างว่าสถาปัตยกรรมของซีพียูมีภูมิคุ้มกันต่อการโจมตี
        ในปัจจุบันแสดงให้เห็นว่าซีพียู AMDรุ่นปัจจุบันของ มีความปลอดภัย กับ Meltdown
        เรายังได้พยายามสร้างบัฟเฟอร์ Meltdown บนเครื่อง ARM และ AMD หลายตัวอย่างไรก็ตาม เราไม่สามารถไม่ประสบผลสำเร็จ จัดการหน่วยความจำเคอร์เนลได้ด้วยการโจมตี
        จนถึงตอนนี้โปรเซสเซอร์ AMD ไม่ได้รับผลกระทบจาก Meltdown
        สรุปอีกรอบ สบายใจได้
        • #49
          มีให้โพสต์เยอะเลยนะ ท่านผุ้นำช่วงนี้ อิอิ
          • #50
            tool อีกตัว ที่ใช้เช็คช่องโหว่ ก็ลองดู SpecuCheck ก็ได้ครับ ง่ายดี แต่รันผ่าน cmd น่ะ
            ดาว์นโหลด https://github.com/ionescu007/SpecuCheck/releases
            ภาพตัวอย่าง ผลการสแกน จากเครื่องผมเอง (R7 1700)
            CVE-2017-5754 = MELTDOWN
            CVE-2017-5715 = Spectre
            • #51
              น่าจะง่ายกว่าทูลของตาเดอะฟุลเดะ เดะขอลอง
              • #52
                Originally posted by CUTTER_Z View Post
                อ่านมาหลายวันแล้ว กับ AMD ไม่ค่อยมีผลเท่าใหร่ แต่กับ Intel มีผลเยอะพอสมควรมากน้อยก็ตามลักษณะการใช้งาน ยิ่งกับพวก Data Center แล้วร้องจ๊ากเลย พวกเราเป็น User บ้าน ๆ ก็เลยไม่ค่อยจะอะไรมากมาย คงไม่มีใครแฮ็คมาขอดู pwd เวปโป๊หรอก
                • #53
                  อยากจะร้อง
                  นี่แสดงให้เห็นว่าปัจจุบันระบบของคุณไม่ได้รับการแก้ไขเพื่อลดความเสี่ยงเหล่านี้
                  • #54
                    อืม ผมไม่แน่ใจว่าซอฟแวร์มัน โอเครึเปล่านะ อันนี้ไม่ทราบจริงๆๆๆ แต่ผล เหมือนท่านผู้นำ
                    หรือ os ลง อะไรขาดรึเปล่า เชน net framework รุ่นไม่ถึงที่มันต้องการ
                    FX 6300
                    ไรเซ่น 1400 ผม ขอพรุ่งนี้จริงๆๆ ผมชำแหระ เอา psu และการ์ดจอไปใส่เครื่องอื่น พรุ่งนี้ 55 psu มีไม่พอ
                    ปล. สนุก
                    • #55
                      Originally posted by THEFOOL View Post
                      ทดสอบดูครับ ผมก็ไม่รู้ ประเด็นคือ
                      1.โดนเรื่องความปลอดภัย อันนี้ น่าจะโดน แต่ไม่หนักเท่า intel ถ้าเอาตามที่ CEO amd ออกมายืนยันผลทดสอบในกระทู้โพสหน้าแรกๆ แต่ไม่สามารถทำอะไรได้เท่าไหร่ คือมีช่องโหว่ แต่ไม่ครบ องค์ประกอบในการ Hack
                      2.เรื่อง ความเร็วตกจาก cpu สมรรถภาพตก หลังจากอัฟแพท อันนี้ AMD น่าจะรอดตัวไป รอดูผลทดสอบจาก AMD อีกทีในอนาคต ถ้าออกจะนำมาลงเพิ่ม
                      ประเด็นจริงๆ ที่โดนด่า + ฟ้องกันแล้ว โดนกันทั่วโลก คือ เรื่อง CPU สมรรถภาพตก ในหลายๆ เรื่อง ถ้า แก้ไม่ขึ้น นี่ ละครับ
                      ส่วนเรื่อง Hack นี่ อัฟแพท อัฟไบออส เอาก็จบ User บ้านๆ คลิปบลาๆๆ นี่ไม่เท่าไหร่ ^^
                      แต่ที่ไม่จบคือ เฟรมตก ความเร็วหน่วยเก็บข้อมูล ssd ตก CPU สมรรถภาพตกลงอย่างมากกับ CPU นี่ละ ..
                      เล่นจาก 20% พุ่งไป 60% หลังอัฟแพท แบบนี้ เอาตรงๆ คำนวนไม่ถูกเลย ว่า CPU สมรรถภาพ ประสิทธิภาพ ตกไปเท่าไหร่ กันแน่ ที่แน่ๆ ตกเกิน 5% แน่นอน กระทบหนัก
                      ขอบคุณครับ ตาเดอะฟูล
                      - - - Updated - - -
                      Originally posted by Beaver_XT View Post
                      ไม่เสียแรงที่เก็บไว้เพราะไม่ได้เสียตังค์ครับ 555+
                      FX นี่ก็ยังใช้ทำงานได้เรื่อย ๆ นะ ตัดต่อ 4K กับ 1080p 60FPS ไหว แค่เรนเดอร์ช้าหน่อย
                      เป็นยูทูเบอร์นี่ก็ยากเหมือนกันนะ ขนาดแค่สัปดาห์ละวีดีโอยังเหนื่อยเลย เห็นพวกที่เค้าออกทุกวันได้แล้วนับถือจริง ๆ
                      โดนหมดครับ เพราะเป็นระดับ hardware
                      OS ไหนอัพเดตเร็วก็โอเค แมคผมยังเป็น Yosemite อยู่ ไม่เห็นมีอัพเดตอะไรออกมา
                      ส่วน Ubuntu ผม 16.04 เท่าที่เห็นคือเดี๋ยววันที่ 9 นี้ Kernel Update ครับ
                      ขอบคุณครับ ผมกำลังตามอัพเดทอยู่
                      • #56
                        • #57
                          สำหรับไมโครซอฟท์ได้พักการทำแพทช์ meltdown/spectre สำหรับเอเอ็มดี แล้ว เหตุเนื่องจากมีปัญหาบูทไม่ขึ้นหลังจากลงแพทช์ KB4056892 (2018-01) Cumulative Update
                          แถม โทษเอเอ็มดีว่าไม่ได้ให้เอกสารที่ถูกต้องแก่วิศวกรของไมโครซอฟท์ในการทำแพทช์ (not supplying its engineers with the right documentation to develop their patches)
                          ที่มา
                          Microsoft Halts Meltdown-Spectre Patches to AMD PCs as Some Turn Unbootable
                          Microsoft late-Monday halted Meltdown and Spectre security patches to machines running AMD processors, as complaints of machines turning unbootable piled up. Apparently the latest KB4056892 (2018-01) Cumulative Update causes machines with AMD processors (well, chipsets) to refuse to boot. Microsoft ...
                          • #58
                            ที่มา
                            https://www.techpowerup.com/240436/m...urn-unbootable
                            ทำแล้วอาจจะแรงเกินไป
                            • #59
                              กรรมแล้ว น่าจะหมายถึง ไรเซ่น ทีนี้ FX มันจะได้แพตช์ใหม่ไม้นั่น
                              ฟีน่อม ยังมีคนใช้สงสัยไม่ต้องถาม แล้ว AMD ผมบ่นหน่อยนะ
                              เป็นบริษัทที่ทำ อาคิเทคเจอร์ ซีพียู จนครบ ลองหมดแล้วล่ะ 555
                              CMP ฟีน่อม แอธล่อน64 CMT (FX) SMT(ไรเซ่น)
                              • #60
                                CPU?8700K@5.1GHz(delided) ?Cooler:Corsair H110i GT ?GPU?GTX 1080ti(ZOTAC AMP Extream) ?MOTHER?ASUS ROG MAXIMUS X CODE ?MEMORY CLOCK?3900Mhz ?CEMU VER:1.11.3 ?UPDATE VER?1.4.1 ?DLC VER?3.0 ?graphic packs?https://slashiee.github.io/cemu_graph... ?resolution:1080p ?OS:Windows10
                                อัฟแค่แพทวินโดว์ ยังไม่ได้อัฟแพทไบออส CPU
                                - - - Updated - - -
                                ได้แต่ รอเลื่อนออกไปแก้ไขใหม่ เพราะ ดับในบางตัวที่มันไม่ตรง
