QX9650-STRIKER II FORMULA
  • QX9650-STRIKER II FORMULA
    ขออนุญาติลบรูปออกเวปจะได้เบาขึ้น
    เทียบเคียง VISTA64BIT VS W764BIT กันสักนิด
    INTEL QX9650
    ASUS STRIKER II Formula
    Kingston D9 533 1GB X4
    COOLERMASTER HYPER 48
    SEAGATE 80GB X4 RAID 0
    GALAXY 260GTX SLI
    Enermax 1000 W
    ForceWare 180.48 64bit
    Vista Ultimate 64-bit
    1440 x 900 AA 0x 3X @ ambush/DX10/E/0
    1440 x 900 AA 2x 3X @ ambush/DX10/E/0
    1440 x 900 AA 4x 3X @ ambush/DX10/E/0
    1440 x 900 AA 8x 3X @ ambush/DX10/E/0
    1440 x 900 AA 8xQ 3X @ ambush/DX10/E/0
    1440 x 900 AA 16x 3X @ ambush/DX10/E/0
    1440 x 900 AA 16xQ 3X @ ambush/DX10/E/0
    Processor: Intel(R) Core(TM)2 Extreme CPU X9650 @ 3.00GHz @ 4200 Mhz
    CPU ID: Intel64 Family 6 Model 23 Stepping 6
    Operating System: Microsoft® Windows Vista™ Ultimate 64-bit Service Pack 1
    Physical memory: 4.00 GB
    Display adapter: NVIDIA GeForce GTX 260 0 MB
    Driver version: 7.15.11.8048 (20081112075400.000000-000)
    TimeDemo Play Started , (Total Frames: 3502, Recorded Time: 92.69s)
    !TimeDemo Run 0 Finished.
    Play Time: 65.46s, Average FPS: 53.50
    Min FPS: 29.89 at frame 87, Max FPS: 71.37 at frame 1316
    Average Tri/Sec: -31866306, Tri/Frame: -595607
    Recorded/Played Tris ratio: -0.88
    !TimeDemo Run 1 Finished.
    Play Time: 63.84s, Average FPS: 54.85
    Average Tri/Sec: -30690312, Tri/Frame: -559484
    Recorded/Played Tris ratio: -0.93
    !TimeDemo Run 2 Finished.
    Play Time: 63.64s, Average FPS: 55.03
    Average Tri/Sec: -30794190, Tri/Frame: -559586
    TimeDemo Play Ended, (3 Runs Performed)
    Play Time: 74.82s, Average FPS: 46.81
    Min FPS: 31.36 at frame 1865, Max FPS: 59.94 at frame 684
    Average Tri/Sec: -27736662, Tri/Frame: -592573
    Play Time: 74.04s, Average FPS: 47.30
    Average Tri/Sec: -26584710, Tri/Frame: -562044
    Play Time: 73.98s, Average FPS: 47.34
    Average Tri/Sec: -26656702, Tri/Frame: -563090
    Play Time: 74.78s, Average FPS: 46.83
    Min FPS: 31.15 at frame 65, Max FPS: 60.46 at frame 1267
    Average Tri/Sec: -27808042, Tri/Frame: -593803
    Average Tri/Sec: -26571898, Tri/Frame: -561822
    Play Time: 74.02s, Average FPS: 47.31
    Average Tri/Sec: -26631196, Tri/Frame: -562893
    Play Time: 76.95s, Average FPS: 45.51
    Min FPS: 30.44 at frame 1866, Max FPS: 58.09 at frame 1282
    Average Tri/Sec: -27056140, Tri/Frame: -594544
    Play Time: 76.28s, Average FPS: 45.91
    Average Tri/Sec: -25702022, Tri/Frame: -559842
    Play Time: 76.23s, Average FPS: 45.94
    Average Tri/Sec: -25836546, Tri/Frame: -562365
    Play Time: 90.17s, Average FPS: 38.84
    Min FPS: 25.55 at frame 1754, Max FPS: 51.71 at frame 680
    Average Tri/Sec: -23195556, Tri/Frame: -597217
    Recorded/Played Tris ratio: -0.87
    Play Time: 89.83s, Average FPS: 38.99
    Average Tri/Sec: -21972662, Tri/Frame: -563598
    Play Time: 88.06s, Average FPS: 39.77
    Average Tri/Sec: -22473674, Tri/Frame: -565135
    Recorded/Played Tris ratio: -0.92
    Play Time: 78.22s, Average FPS: 44.77
    Min FPS: 31.42 at frame 1883, Max FPS: 58.15 at frame 766
    Average Tri/Sec: -26538314, Tri/Frame: -592757
    Play Time: 77.56s, Average FPS: 45.15
    Average Tri/Sec: -25173760, Tri/Frame: -557512
    Recorded/Played Tris ratio: -0.94
    Play Time: 77.47s, Average FPS: 45.20
    Average Tri/Sec: -25303572, Tri/Frame: -559789
    Play Time: 92.99s, Average FPS: 37.66
    Min FPS: 22.88 at frame 1743, Max FPS: 50.25 at frame 698
    Average Tri/Sec: -22379836, Tri/Frame: -594257
    Play Time: 93.15s, Average FPS: 37.59
    Average Tri/Sec: -21163824, Tri/Frame: -562943
    Play Time: 91.33s, Average FPS: 38.34
    Average Tri/Sec: -21580148, Tri/Frame: -562792
    //////////// Summary \\\\\\\\\\\\\
    01/04/2552 2236 - Microsoft® Windows Vista™ Ultimate 64-bit Service Pack 1
    DirectX 10 ENTHUSIAST 3X @ Map: ambush @ 0 1440 x 900 AA 0xx
    ==> Framerate [ Min: 29.89 Max: 71.37 Avg: 54.94 ]
    DirectX 10 ENTHUSIAST 3X @ Map: ambush @ 0 1440 x 900 AA 2xx
    ==> Framerate [ Min: 31.36 Max: 59.94 Avg: 47.32 ]
    DirectX 10 ENTHUSIAST 3X @ Map: ambush @ 0 1440 x 900 AA 4xx
    ==> Framerate [ Min: 31.15 Max: 60.46 Avg: 47.31 ]
    DirectX 10 ENTHUSIAST 3X @ Map: ambush @ 0 1440 x 900 AA 8xx
    ==> Framerate [ Min: 30.44 Max: 58.09 Avg: 45.93 ]
    DirectX 10 ENTHUSIAST 3X @ Map: ambush @ 0 1440 x 900 AA 8xQx
    ==> Framerate [ Min: 25.55 Max: 51.71 Avg: 39.38 ]
    DirectX 10 ENTHUSIAST 3X @ Map: ambush @ 0 1440 x 900 AA 16xx
    ==> Framerate [ Min: 31.42 Max: 58.15 Avg: 45.18 ]
    DirectX 10 ENTHUSIAST 3X @ Map: ambush @ 0 1440 x 900 AA 16xQx
    ==> Framerate [ Min: 22.88 Max: 50.25 Avg: 37.97 ]
      INTEL QX9650
      GALAXY 260GTX SLI
      Enermax 1000 W
      ForceWare 185.20 64bit
      Windows 7 Ultimate 64bit
        Operating System: Microsoft Windows 7 Ultimate
        Driver version: 7.15.11.8520 (20081226000000.000000-000)
        Play Time: 66.97s, Average FPS: 52.29
        Min FPS: 24.34 at frame 68, Max FPS: 72.20 at frame 1251
        Average Tri/Sec: -31112850, Tri/Frame: -594960
        Play Time: 64.61s, Average FPS: 54.20
        Min FPS: 24.34 at frame 68, Max FPS: 72.24 at frame 1314
        Average Tri/Sec: -30465106, Tri/Frame: -562051
        Play Time: 64.56s, Average FPS: 54.25
        Min FPS: 24.34 at frame 68, Max FPS: 72.35 at frame 1282
        Average Tri/Sec: -30308936, Tri/Frame: -558717
        Play Time: 77.42s, Average FPS: 45.23
        Min FPS: 24.72 at frame 83, Max FPS: 57.56 at frame 735
        Average Tri/Sec: -26882540, Tri/Frame: -594335
        Play Time: 76.31s, Average FPS: 45.89
        Average Tri/Sec: -25880120, Tri/Frame: -563907
        Play Time: 76.16s, Average FPS: 45.98
        Average Tri/Sec: -25955500, Tri/Frame: -564495
        Play Time: 76.36s, Average FPS: 45.86
        Min FPS: 24.15 at frame 83, Max FPS: 59.47 at frame 753
        Average Tri/Sec: -27260958, Tri/Frame: -594430
        Play Time: 75.59s, Average FPS: 46.33
        Average Tri/Sec: -25913120, Tri/Frame: -559345
        Play Time: 75.32s, Average FPS: 46.49
        Average Tri/Sec: -26123290, Tri/Frame: -561874
        Play Time: 79.91s, Average FPS: 43.83
        Min FPS: 24.34 at frame 82, Max FPS: 56.14 at frame 767
        Average Tri/Sec: -26057242, Tri/Frame: -594570
        Play Time: 79.18s, Average FPS: 44.23
        Average Tri/Sec: -24830958, Tri/Frame: -561448
        Play Time: 78.84s, Average FPS: 44.42
        Average Tri/Sec: -25036554, Tri/Frame: -563659
        Play Time: 94.00s, Average FPS: 37.26
        Min FPS: 24.30 at frame 83, Max FPS: 48.19 at frame 756
        Average Tri/Sec: -22130668, Tri/Frame: -594007
        Play Time: 93.79s, Average FPS: 37.34
        Average Tri/Sec: -20960204, Tri/Frame: -561366
        Play Time: 93.36s, Average FPS: 37.51
        Average Tri/Sec: -21129406, Tri/Frame: -563271
        Play Time: 81.02s, Average FPS: 43.22
        Min FPS: 23.20 at frame 82, Max FPS: 55.99 at frame 761
        Average Tri/Sec: -25670838, Tri/Frame: -593889
        Play Time: 80.16s, Average FPS: 43.69
        Average Tri/Sec: -24459180, Tri/Frame: -559896
        Play Time: 80.11s, Average FPS: 43.72
        Average Tri/Sec: -24610594, Tri/Frame: -562947
        01/14/2552 0918 - Microsoft Windows 7 Ultimate
        ==> Framerate [ Min: 24.34 Max: 72.30 Avg: 54.23 ]
        ==> Framerate [ Min: 24.72 Max: 57.56 Avg: 45.94 ]
        ==> Framerate [ Min: 24.15 Max: 59.47 Avg: 46.41 ]
        ==> Framerate [ Min: 24.34 Max: 56.14 Avg: 44.33 ]
        ==> Framerate [ Min: 24.30 Max: 48.19 Avg: 37.43 ]
        ==> Framerate [ Min: 23.20 Max: 55.99 Avg: 43.71 ]
          ของเล่นแต่ละอย่างของท่านนั้นสุดยอดมากๆครับ
            โห แรงทั้ง 2 วินโดเลย
              คนนี้ของเมพจิงๆ
                อยากได้ QX9650 จังเลยคับ
                  รอมือสอง
                    ของท่านทั้งแรงทั้งแพงเลยครับเกินบรรยายแล้วครับ
                    ว่าแต่หมดเงินไปเยอะนะนั่นอะ
                      แรงโคดๆ
