รบกวนขอ Driver Sound hp pavilion 061 หน่อยค่ะ หาใน google ก้อไม้ได้ ไม่รู้จะหาที่ไหนแล้ว ขอบคุณล่วงหน้าค่ะ
kob-baby@hotmail.com
CPU-Z version 1.44.1
Processors Map
Number of processors 1
Number of threads 1
Processor 0
-- Core 0
-- Thread 0
Processors Information
Processor 1 (ID = 0)
Number of cores 1 (max 1)
Number of threads 1 (max 1)
Name Intel Pentium 4 515
Codename Prescott
Specification Intel(R) Pentium(R) 4 CPU 2.93GHz
Package Socket 775 LGA (platform ID = 4h)
CPUID F.4.1
Extended CPUID F.4
Core Stepping E0
Technology 90 nm
Core Speed 2932.4 MHz (22.0 x 133.3 MHz)
Rated Bus speed 533.2 MHz
Stock frequency 2933 MHz
Instructions sets MMX, SSE, SSE2, SSE3
L1 Data cache 16 KBytes, 8-way set associative, 64-byte line size
Trace cache 12 Kuops, 8-way set associative
L2 cache 1024 KBytes, 8-way set associative, 64-byte line size
FID/VID Control no
Features XD
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01001001h
Max CPUID level 00000005h
Max CPUID ext. level 80000008h
Function eax ebx ecx edx
0x00000000 0x00000005 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x00000F41 0x00010800 0x0000451D 0xBFEBFBFF
0x00000002 0x605B5101 0x00000000 0x00000000 0x007C7040
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x00000121 0x01C0003F 0x0000001F 0x00000000
0x00000004 0x00000143 0x01C0103F 0x000003FF 0x00000000
0x00000005 0x00000040 0x00000040 0x00000000 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000000 0x00100000
0x80000002 0x20202020 0x20202020 0x20202020 0x6E492020
0x80000003 0x286C6574 0x50202952 0x69746E65 0x52286D75
0x80000004 0x20342029 0x20555043 0x33392E32 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x04006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000000
0x80000008 0x00002024 0x00000000 0x00000000 0x00000000
Cache descriptor Level 1 D 16 KB 1 threads
Cache descriptor Level 2 U 1 MB 1 threads
Cache descriptor Level 1 T 12 KB 1 threads
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00900
MSR 0x00000017 edx = 0x00120000 eax = 0x00000000
MSR 0x0000002C edx = 0x00000000 eax = 0x16110816
MSR 0x000001A0 edx = 0x00000000 eax = 0x20842081
Chipset
Northbridge Intel i915P/i915G rev. B1
Southbridge Intel 82801FB (ICH6) rev. 03
Memory Type
Memory Size 256 MBytes
Channels Single
Memory Frequency 133.3 MHz (1:1)
Memory SPD
DIMM #1
General
Memory type DDR
Manufacturer (ID) Samsung (CE00000000000000)
Size 256 MBytes
Max bandwidth PC3200 (200 MHz)
Part number M3 68L3223ETM-CCC
Serial number F202765E
Manufacturing date Week 03/Year 05
Attributes
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
Nominal Voltage 2.50 Volts
EPP no
XMP no
Timings table
Frequency (MHz) 166 200
CAS# 2.5 3.0
RAS# to CAS# delay 3 3
RAS# Precharge 3 3
TRAS 7 8
Dump Module #1
0 1 2 3 4 5 6 7 8 9 A B C D E F
00 80 08 07 0D 0A 01 40 00 04 50 65 00 82 08 00 01
10 0E 04 18 01 02 20 C0 60 70 00 00 3C 28 3C 28 40
20 60 60 40 40 00 00 00 00 00 37 46 28 28 50 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 7D
40 CE 00 00 00 00 00 00 00 02 4D 33 20 36 38 4C 33
50 32 32 33 45 54 4D 2D 43 43 43 20 4D 45 05 03 F2
60 02 76 5E 00 53 39 48 31 32 30 30 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 23 B6 76 71 3A 23 33 C0 60 43 32 00 05 34 FF
90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00
D0 FF FF FF FF FF FF FF 00 FF FF FF 00 FF FF FF 47
E0 FF FF 4C FF FF FF FF 33 FF FF FF FF FF FF FF FF
F0 01 FF FF FF FF FF FF FF FF FF FF FF FF 00 FF FF
Monitoring
Mainboard Model Grouper (0x2E4 - 0x807D12)
LPCIO
Vendor SMSC
Vendor ID 0x55
Chip ID 0x77
Config Mode I/O address 0x2E
Dump config mode register space, LDN = 0xA
00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 77 01 09 00 44 00 2E 00 00 00 00 00 00 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 06 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Hardware monitor
Hardware monitor ID=0x550089 hardware monitor
Dump hardware monitor
SMBus Register space, base address = 0x0400
SMBus request at channel 0x0, address 0x2E
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 C3 C4 C5 C8 BE 42 2B 00 76 07 9C 0C FF FF FF FF
30 95 A1 FF 00 00 00 00 00 00 00 00 00 00 00 5C 89
40 05 00 00 00 00 FF 00 FF 00 FF 00 FF 00 FF 3A 47
50 81 7F 81 7F FF FF FF FF FF FF FF FF E2 E2 62 CB
60 CB CB 00 00 80 80 80 5A 5A 5A 64 64 64 44 40 00
70 95 A1 FF 09 09 09 09 09 09 00 10 00 E4 00 EC 18
80 7E A4 05 00 00 05 40 5A B5 00 4D 4D 0B 0B 0D 00
90 04 04 04 04 0C 0C 0C 5A F1 C5 00 00 FF 00 FF 00
A0 00 00 0C 00 02 FF FF 0B 0B FE FF FE FF FF FF FF
B0 FF 00 00 00 00 00 28 28 0E 0E 0F 0F 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 41 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PCI Device List
Host Bridge
bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2580
Revision ID 0x04
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x103C
Subsystem ID 0x2A08
Int. Line 0x00
Int. Pin 0x00
Capabilities
Vendor Dependant Capability
Offset E0h
Dump
00 86 80 80 25 06 00 90 20 04 00 00 06 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 3C 10 08 2A
30 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00
40 00 90 D1 FE 00 00 00 00 00 00 00 E0 00 80 D1 FE
50 00 00 30 00 09 00 00 A8 00 00 00 00 00 00 00 00
60 00 30 D1 FE 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 10 11 01 00 00 33 33 00 00 00 00 00 10 0A 38 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 70 01 00 00
E0 09 00 09 21 02 B3 9B 08 02 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00
VGA Controller
bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2582
Revision ID 0x04
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xCFE80000
Address 1 (port) 0x0000B800
Address 2 (memory) 0xD0000000
Address 3 (memory) 0xCFE40000
Subvendor ID 0x103C
Subsystem ID 0x2A08
Int. Line 0x0A
Int. Pin 0x01
Capabilities
Power Management Capability
Offset D0h
Version 1.1
Dump
00 86 80 82 25 07 00 90 00 04 00 00 03 00 00 00 00
10 00 00 E8 CF 01 B8 00 00 08 00 00 D0 00 00 E4 CF
30 00 00 00 00 D0 00 00 00 00 00 00 00 0A 01 00 00
40 00 00 00 00 E0 00 00 00 09 00 09 21 02 B3 9B 08
50 02 00 30 00 09 00 00 A8 00 00 00 00 00 00 80 0F
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 01 00 22 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 44 05 64 34 00 00 00 00 00 00 05 00 00 00 00 00
Multimedia device
bus 0 (0x00), device 27 (0x1B), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2668
Revision ID 0x03
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x04
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xCFE38000
Subvendor ID 0x103C
Subsystem ID 0x2A09
Int. Line 0x0A
Int. Pin 0x01
Capabilities
Offset 50h
Version 1.1
Message Signalled Interrupts Capability
Offset 60h
PCI Express Capability
Offset 70h
Device type Root Complex Integrated Endpoint Device
Port 0
Version 1.0
Link width 0x (max 0x)
Dump
00 86 80 68 26 06 00 10 00 03 00 03 04 04 00 00 00
10 04 80 E3 CF 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 3C 10 09 2A
30 00 00 00 00 50 00 00 00 00 00 00 00 0A 01 00 00
40 03 00 00 00 07 00 00 00 00 00 00 00 00 00 00 00
50 01 60 42 C8 00 00 00 00 00 00 00 00 00 00 00 00
60 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
70 10 00 91 00 00 00 00 00 00 08 10 00 00 00 00 00
C0 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 80 0F 03 00 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 28 (0x1C), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2660
Revision ID 0x03
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x04
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x10
Int. Pin 0x01
Capabilities
Offset 40h
Device type Root Port of PCI-E Root Complex
Port 1
Version 1.0
Physical slot #0
Presence detect no
Link width 0x (max 1x)
Offset 80h
Subsystem Vendor Capability
Offset 90h
Subsystem ID 0x2A0A
Sub. Vendor ID 0x103C
Offset A0h
Version 1.1
Dump
00 86 80 60 26 07 01 10 00 03 00 04 06 04 00 81 00
10 00 00 00 00 00 00 00 00 00 01 01 00 C0 C0 00 20
20 F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 10 01 02 00
40 10 80 41 01 E0 0F 00 00 00 00 10 00 11 4C 01 01
50 00 00 01 10 60 00 08 00 00 00 00 00 00 00 00 00
80 05 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 0D A0 00 00 3C 10 0A 2A 00 00 00 00 00 00 00 00
A0 01 00 02 C8 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 11 00 00 00 00 00
USB Controller (UHCI)
bus 0 (0x00), device 29 (0x1D), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2658
Revision ID 0x03
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 4 (port) 0x0000A400
Subvendor ID 0x103C
Subsystem ID 0x2A0A
Int. Line 0x17
Int. Pin 0x01
Dump
00 86 80 58 26 05 00 80 02 03 00 03 0C 00 00 80 00
20 01 A4 00 00 00 00 00 00 00 00 00 00 3C 10 0A 2A
30 00 00 00 00 00 00 00 00 00 00 00 00 17 01 00 00
60 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 25 00 00 00 00 00 00 00 00 01 00 00 00 00 00
bus 0 (0x00), device 29 (0x1D), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x2659
Revision ID 0x03
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000A800
Subvendor ID 0x103C
Subsystem ID 0x2A0A
Int. Line 0x13
Int. Pin 0x02
Dump
00 86 80 59 26 05 00 80 02 03 00 03 0C 00 00 00 00
20 01 A8 00 00 00 00 00 00 00 00 00 00 3C 10 0A 2A
30 00 00 00 00 00 00 00 00 00 00 00 00 13 02 00 00
bus 0 (0x00), device 29 (0x1D), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x265A
Revision ID 0x03
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000B000
Subvendor ID 0x103C
Subsystem ID 0x2A0A
Int. Line 0x12
Int. Pin 0x03
Dump
00 86 80 5A 26 05 00 80 02 03 00 03 0C 00 00 00 00
20 01 B0 00 00 00 00 00 00 00 00 00 00 3C 10 0A 2A
30 00 00 00 00 00 00 00 00 00 00 00 00 12 03 00 00
bus 0 (0x00), device 29 (0x1D), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x265B
Revision ID 0x03
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000B400
Subvendor ID 0x103C
Subsystem ID 0x2A0A
Int. Line 0x10
Int. Pin 0x04
Dump
00 86 80 5B 26 05 00 80 02 03 00 03 0C 00 00 00 00
20 01 B4 00 00 00 00 00 00 00 00 00 00 3C 10 0A 2A
30 00 00 00 00 00 00 00 00 00 00 00 00 10 04 00 00
USB 2.0 Controller (EHCI)
bus 0 (0x00), device 29 (0x1D), function 7 (0x07)
Common header
Vendor ID 0x8086
Model ID 0x265C
Revision ID 0x03
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xCFE37C00
Subvendor ID 0x103C
Subsystem ID 0x2A0A
Int. Line 0x17
Int. Pin 0x01
Capabilities
Offset 50h
Version 1.1
Debug Port Capability
Offset 58h
Dump
00 86 80 5C 26 06 00 90 02 03 20 03 0C 00 00 00 00
10 00 7C E3 CF 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 3C 10 0A 2A
30 00 00 00 00 50 00 00 00 00 00 00 00 17 01 00 00
50 01 58 C2 C9 00 00 00 00 0A 00 A0 20 00 00 00 00
60 20 20 FF 01 00 00 00 00 01 00 00 00 00 00 00 C0
70 00 00 CF 3F 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 AA FF 00 55 55 FF 00 20 00 00 00
F0 00 80 00 09 88 8C 40 00 80 0F 03 00 06 17 00 00
PCI to PCI Bridge
bus 0 (0x00), device 30 (0x1E), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x244E
Revision ID 0xD3
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 50h
Subsystem ID 0x2A0A
Dump
00 86 80 4E 24 07 01 10 00 D3 01 04 06 00 00 01 00
10 00 00 00 00 00 00 00 00 00 02 02 20 D0 E0 80 A2
20 F0 CF F0 CF F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 00 00 02 00
50 0D 00 00 00 3C 10 0A 2A 00 00 00 00 00 00 00 00
PCI to ISA Bridge
bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2640
Revision ID 0x03
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x103C
Subsystem ID 0x2A0A
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 40 26 07 00 00 02 03 00 01 06 00 00 80 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 01 08 00 00 80 00 00 00 81 04 00 00 10 00 00 00
60 8A 8A 83 8B D0 00 00 00 84 8A 80 85 00 00 00 00
80 00 00 0E 14 81 06 00 00 00 00 00 00 00 00 00 00
A0 20 02 00 00 01 00 00 00 00 00 00 00 00 03 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00 00
D0 33 22 11 00 67 45 00 00 C0 80 00 00 00 00 00 00
F0 01 C0 D1 FE 00 00 00 00 80 0F 03 00 00 00 00 00
IDE Controller
bus 0 (0x00), device 31 (0x1F), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x266F
Revision ID 0x03
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000FFA0
Subvendor ID 0x103C
Subsystem ID 0x2A0A
Int. Line 0x00
Int. Pin 0x01
Dump
00 86 80 6F 26 05 00 80 02 03 8A 01 01 00 00 00 00
10 01 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00
20 A1 FF 00 00 00 00 00 00 00 00 00 00 3C 10 0A 2A
30 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00
40 03 A3 00 80 00 00 00 00 01 00 02 00 00 00 00 00
C0 00 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00
IDE Controller
bus 0 (0x00), device 31 (0x1F), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x2651
Revision ID 0x03
PI 0x8F
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000A000
Address 1 (port) 0x00009800
Address 2 (port) 0x00009400
Address 3 (port) 0x00009000
Address 4 (port) 0x00008800
Subvendor ID 0x103C
Subsystem ID 0x2A0A
Int. Line 0x13
Int. Pin 0x02
Capabilities
Offset 70h
Version 1.1
Dump
00 86 80 51 26 05 00 B0 02 03 8F 01 01 00 00 00 00
10 01 A0 00 00 01 98 00 00 01 94 00 00 01 90 00 00
20 01 88 00 00 00 00 00 00 00 00 00 00 3C 10 0A 2A
30 00 00 00 00 70 00 00 00 00 00 00 00 13 02 00 00
40 07 E3 00 80 00 00 00 00 01 00 01 00 00 00 00 00
50 00 00 00 00 30 10 00 00 00 00 00 00 00 00 00 00
70 01 00 02 40 00 00 00 00 00 00 00 00 00 00 00 00
80 05 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 1F 00 82 01 C0 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00
SMBus Controller
bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x266A
Revision ID 0x03
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x00000400
Subvendor ID 0x103C
Subsystem ID 0x2A0A
Int. Line 0x0A
Int. Pin 0x02
Dump
00 86 80 6A 26 01 04 80 02 03 00 05 0C 00 00 00 00
20 01 04 00 00 00 00 00 00 00 00 00 00 3C 10 0A 2A
30 00 00 00 00 00 00 00 00 00 00 00 00 0A 02 00 00
40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
OHCI FireWire Controller
bus 2 (0x02), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x1106
Model ID 0x3044
Revision ID 0x80
PI 0x10
SubClass 0x00
BaseClass 0x0C
Cache Line 0x04
Latency 0x40
Header 0x00
PCI header
Address 0 (memory) 0xCFFFF800
Address 1 (port) 0x0000E800
Subvendor ID 0x103C
Subsystem ID 0x2A0C
Int. Line 0x14
Int. Pin 0x01
Capabilities
Offset 50h
Version 1.1
Dump
00 06 11 44 30 17 00 10 02 80 10 00 0C 04 40 00 00
10 00 F8 FF CF 01 E8 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 3C 10 0C 2A
30 00 00 00 00 50 00 00 00 00 00 00 00 14 01 00 20
50 01 00 02 E4 00 00 00 00 00 00 00 00 00 00 00 00
Ethernet Controller
bus 2 (0x02), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x10EC
Model ID 0x8139
Revision ID 0x10
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x00
Latency 0x40
Header 0x00
PCI header
Address 0 (port) 0x0000E400
Address 1 (memory) 0xCFFFF400
Subvendor ID 0x103C
Subsystem ID 0x2A0B
Int. Line 0x15
Int. Pin 0x01
Capabilities
Offset 50h
Version 1.1
Dump
00 EC 10 39 81 05 00 90 02 10 00 00 02 00 40 00 00
10 01 E4 00 00 00 F4 FF CF 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 3C 10 0B 2A
30 00 00 00 00 50 00 00 00 00 00 00 00 15 01 20 40
50 01 00 C2 F7 00 01 00 00 00 00 00 00 00 00 00 00
Communication Device
bus 2 (0x02), device 4 (0x04), function 0 (0x00)
Common header
Vendor ID 0x10C1
Model ID 0x048C
Revision ID 0x03
PI 0x00
SubClass 0x80
BaseClass 0x07
Cache Line 0x00
Latency 0x40
Header 0x00
PCI header
Address 0 (memory) 0xCFFFF000
Address 1 (port) 0x0000E000
Address 2 (port) 0x0000D800
Subvendor ID 0x10C1
Subsystem ID 0x044C
Int. Line 0xFF
Int. Pin 0x00
Capabilities
Offset F8h
Version 1.1
Dump
00 C1 10 8C 04 07 00 90 82 03 00 80 07 00 40 00 00
10 00 F0 FF CF 01 E0 00 00 01 D8 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 40 00 00 00 C1 10 4C 04
30 00 00 00 00 F8 00 00 00 00 00 00 00 FF 00 FC 0E
40 FF FE FF FF FF FE FF FF FF FE FF FF FF FE FF FF
50 FF FE FF FF FF FE FF FF FF FE FF FF FF FE FF FF
60 FF FE FF FF FF FE FF FF FF FE FF FF FF FE FF FF
70 FF FE FF FF FF FE FF FF FF FE FF FF FF FE FF FF
80 FF FE FF FF FF FE FF FF FF FE FF FF FF FE FF FF
90 FF FE FF FF FF FE FF FF FF FE FF FF FF FE FF FF
A0 FF FE FF FF FF FE FF FF FF FE FF FF FF FE FF FF
B0 FF FE FF FF FF FE FF FF FF FE FF FF FF FE FF FF
C0 FF FE FF FF FF FE FF FF FF FE FF FF FF FE FF FF
D0 FF FE FF FF FF FE FF FF FF FE FF FF FF FE FF FF
E0 FF FE FF FF FF FE FF FF FF FE FF FF FF FE FF FF
F0 FF FE FF FF 00 00 00 00 01 00 E2 E4 00 00 00 00
DMI
DMI BIOS
vendor American Megatrends Inc.
version 3.28
date 01/23/2006
DMI System Information
manufacturer HP-Pavilion 061
product PS159AA-AB3 a818l
version 0000211LX101GROUP00
serial THT50710VL FD440
UUID A057B7CA-5C80D911-9FED8F4A-AD17FE54
DMI Baseboard
vendor ASUSTeK Computer INC.
model Grouper
revision 1.xx
serial X312345678
DMI System Enclosure
manufacturer Chassis Manufacture
chassis type Desktop
chassis serial Chassis Serial Number
DMI Processor
manufacturer Intel
model Intel(R) Pentium(R) 4 CPU 2.93GHz
clock speed 2933.0MHz
FSB speed 133.0MHz
multiplier 22.0x
DMI Port Connector
designation PS2Mouse (external)
port type Mouse Port
connector PS/2
DMI Port Connector
designation Keyboard (external)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation USB1 (external)
port type USB
connector Access Bus (USB)
DMI Port Connector
designation USB2 (external)
port type USB
DMI Port Connector
designation USB3 (external)
port type USB
DMI Port Connector
designation USB4 (external)
port type USB
DMI Port Connector
designation USB5 (external)
port type USB
DMI Port Connector
designation USB6 (external)
port type USB
DMI Port Connector
designation AUX (internal)
port type Audio Port
connector On Board Sound Input From CD-ROM
DMI Port Connector
designation CD (internal)
DMI Port Connector
designation IDE (internal)
connector On Board IDE
DMI Port Connector
designation FLOPPY (internal)
connector On Board Floppy
DMI Port Connector
designation CPU_FAN (internal)
DMI Port Connector
designation SYS_FAN (internal)
DMI Port Connector
designation ATXPWR (internal)
DMI Port Connector
designation FP_AUDIO (internal)
DMI Extension Slot
designation PCIEX16
type A5
width 32 bits
populated no
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated yes
DMI Extension Slot
designation PCI3/PCIEX1
type PCI
width 32 bits
populated no
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 4096MBytes
max# of devices 4
DMI Memory Device
designation DIMM1
format DIMM
type DDR
total width 64 bits
data width 64 bits
size 256 MBytes
DMI Memory Device
designation DIMM2
format DIMM
type unknown
DMI Memory Device
designation DIMM3
format DIMM
type unknown
DMI Memory Device
designation DIMM4
format DIMM
type unknown
Software
Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX Version 9.0c
Resources
Memory I/O Space, BA=0x00000000CFE80000
Port I/O Space, BA=0xB800
Memory I/O Space, BA=0x00000000D0000000
Memory I/O Space, BA=0x00000000CFE40000
Memory I/O Space, BA=0x00000000CFE38000
Port I/O Space, BA=0xA400
Port I/O Space, BA=0xA800
Port I/O Space, BA=0xB000
Port I/O Space, BA=0xB400
Memory I/O Space, BA=0x00000000CFE37C00
Port I/O Space, BA=0xFFA0
Port I/O Space, BA=0xA000
Port I/O Space, BA=0x9800
Port I/O Space, BA=0x9400
Port I/O Space, BA=0x9000
Port I/O Space, BA=0x8800
Port I/O Space, BA=0x400
Memory I/O Space, BA=0x00000000CFFFF800
Port I/O Space, BA=0xE800
Port I/O Space, BA=0xE400
Memory I/O Space, BA=0x00000000CFFFF400
Memory I/O Space, BA=0x00000000CFFFF000
Port I/O Space, BA=0xE000
Port I/O Space, BA=0xD800
Port I/O Space, BA=0x808, size=0x4
Memory I/O Space, BA=0x00000000FEE00000, size=0x1000
Memory I/O Space, BA=0x0000000000000000, size=0x1000
Memory I/O Space, BA=0x00000000FED1C000
Port I/O Space, BA=0x680
Port I/O Space, BA=0x2E
Processors Map
Number of threads 1
Processor 0
-- Core 0
-- Thread 0
Codename Prescott
CPUID F.4.1
Extended CPUID F.4
Core Stepping E0
Technology 90 nm
FID/VID Control no
Features XD
Thread dumps
CPU Thread 0
APIC ID 0
Type 01001001h
Chipset
Memory Type
Channels Single
Memory SPD
DIMM #1
General
Memory type DDR
Size 256 MBytes
Attributes
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
Timings table
CAS# 2.5 3.0
RAS# Precharge 3 3
TRAS 7 8
Dump Module #1
Monitoring
LPCIO
Vendor SMSC
Vendor ID 0x55
Chip ID 0x77
Hardware monitor
PCI Device List
Host Bridge
Common header
Vendor ID 0x8086
Model ID 0x2580
Revision ID 0x04
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x103C
Subsystem ID 0x2A08
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset E0h
Dump
VGA Controller
Common header
Vendor ID 0x8086
Model ID 0x2582
Revision ID 0x04
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x103C
Subsystem ID 0x2A08
Int. Line 0x0A
Int. Pin 0x01
Capabilities
Offset D0h
Version 1.1
Dump
Multimedia device
Common header
Vendor ID 0x8086
Model ID 0x2668
Revision ID 0x03
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x04
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x103C
Subsystem ID 0x2A09
Int. Line 0x0A
Int. Pin 0x01
Capabilities
Offset 50h
Version 1.1
Offset 60h
Offset 70h
Port 0
Version 1.0
Dump
PCI to PCI Bridge
Common header
Vendor ID 0x8086
Model ID 0x2660
Revision ID 0x03
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x04
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x10
Int. Pin 0x01
Capabilities
Offset 40h
Port 1
Version 1.0
Physical slot #0
Presence detect no
Offset 80h
Offset 90h
Subsystem ID 0x2A0A
Offset A0h
Version 1.1
Dump
Common header
Vendor ID 0x8086
Model ID 0x2658
Revision ID 0x03
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x103C
Subsystem ID 0x2A0A
Int. Line 0x17
Int. Pin 0x01
Dump
Common header
Vendor ID 0x8086
Model ID 0x2659
Revision ID 0x03
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x103C
Subsystem ID 0x2A0A
Int. Line 0x13
Int. Pin 0x02
Dump
Common header
Vendor ID 0x8086
Model ID 0x265A
Revision ID 0x03
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x103C
Subsystem ID 0x2A0A
Int. Line 0x12
Int. Pin 0x03
Dump
Common header
Vendor ID 0x8086
Model ID 0x265B
Revision ID 0x03
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x103C
Subsystem ID 0x2A0A
Int. Line 0x10
Int. Pin 0x04
Dump
Common header
Vendor ID 0x8086
Model ID 0x265C
Revision ID 0x03
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x103C
Subsystem ID 0x2A0A
Int. Line 0x17
Int. Pin 0x01
Capabilities
Offset 50h
Version 1.1
Offset 58h
Dump
PCI to PCI Bridge
Common header
Vendor ID 0x8086
Model ID 0x244E
Revision ID 0xD3
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 50h
Subsystem ID 0x2A0A
Dump
PCI to ISA Bridge
Common header
Vendor ID 0x8086
Model ID 0x2640
Revision ID 0x03
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x103C
Subsystem ID 0x2A0A
Int. Line 0x00
Int. Pin 0x00
Dump
IDE Controller
Common header
Vendor ID 0x8086
Model ID 0x266F
Revision ID 0x03
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x103C
Subsystem ID 0x2A0A
Int. Line 0x00
Int. Pin 0x01
Dump
IDE Controller
Common header
Vendor ID 0x8086
Model ID 0x2651
Revision ID 0x03
PI 0x8F
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x103C
Subsystem ID 0x2A0A
Int. Line 0x13
Int. Pin 0x02
Capabilities
Offset 70h
Version 1.1
Dump
SMBus Controller
Common header
Vendor ID 0x8086
Model ID 0x266A
Revision ID 0x03
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x103C
Subsystem ID 0x2A0A
Int. Line 0x0A
Int. Pin 0x02
Dump
Common header
Vendor ID 0x1106
Model ID 0x3044
Revision ID 0x80
PI 0x10
SubClass 0x00
BaseClass 0x0C
Cache Line 0x04
Latency 0x40
Header 0x00
PCI header
Subvendor ID 0x103C
Subsystem ID 0x2A0C
Int. Line 0x14
Int. Pin 0x01
Capabilities
Offset 50h
Version 1.1
Dump
Ethernet Controller
Common header
Vendor ID 0x10EC
Model ID 0x8139
Revision ID 0x10
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x00
Latency 0x40
Header 0x00
PCI header
Subvendor ID 0x103C
Subsystem ID 0x2A0B
Int. Line 0x15
Int. Pin 0x01
Capabilities
Offset 50h
Version 1.1
Dump
Common header
Vendor ID 0x10C1
Model ID 0x048C
Revision ID 0x03
PI 0x00
SubClass 0x80
BaseClass 0x07
Cache Line 0x00
Latency 0x40
Header 0x00
PCI header
Subvendor ID 0x10C1
Subsystem ID 0x044C
Int. Line 0xFF
Int. Pin 0x00
Capabilities
Offset F8h
Version 1.1
Dump
DMI
DMI BIOS
version 3.28
date 01/23/2006
DMI Baseboard
model Grouper
revision 1.xx
serial X312345678
DMI Processor
manufacturer Intel
FSB speed 133.0MHz
multiplier 22.0x
DMI Port Connector
connector PS/2
DMI Port Connector
connector PS/2
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Extension Slot
designation PCIEX16
type A5
width 32 bits
populated no
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated yes
DMI Extension Slot
type PCI
width 32 bits
populated no
usage System Memory
correction None
max# of devices 4
DMI Memory Device
designation DIMM1
format DIMM
type DDR
total width 64 bits
data width 64 bits
size 256 MBytes
DMI Memory Device
designation DIMM2
format DIMM
type unknown
DMI Memory Device
designation DIMM3
format DIMM
type unknown
DMI Memory Device
designation DIMM4
format DIMM
type unknown
Software
Resources
