CREATIVE X-FI Series 2.14.0001 XP Driver [BETA]
  • CREATIVE X-FI Series 2.14.0001 XP Driver [BETA]
    Product Supports :
    * Creative Sound Blaster X-Fi XtremeMusic
    * Creative Sound Blaster X-Fi XtremeGamer
    * Creative Sound Blaster X-Fi Platinum
    * Creative Sound Blaster X-Fi Fatal1ty®
    * Creative Sound Blaster X-Fi Elite Pro
    Notes:
    * Do not install this driver for Sound Blaster X-Fi Xtreme Audio.
    Fixes:
    * Resolves the issue for systems with 4 GB of RAM.
    * Resolves the Digital I/O detection issue when restarting your computer.
    Known Issues:
    * Before installing this driver, close the Creative MediaSource Go! application on your desktop and restart your computer. (After you have installed this driver, you may manually launch the MediaSource Go! application from the Start menu)
    * When adjusting the master volume in any of the Mode Console, there is no sound output in the rear speakers. (Use the Microsoft Volume Control panel to adjust the master volume)
    Links:
    ขอบคุณสำหรับข้อมูลคับผม
      ขอบคุณครับที่นำข้อมูลมาบอกกัน
        ใครลองแล้วมาโพสเล่าสู่กันฟังบ้างนะครับ
