สอบถามเกี่ยวกับSound On Boardหน่อยครับ
  • สอบถามเกี่ยวกับSound On Boardหน่อยครับ
    ระหว่าง Realtek กับ VIA codec 2ตัวนี้ ตัวไหนเสียงดีกว่ากันครับ
    ข้อมูลผลิตภัณฑ์คงต้องดูรุ่นล่ะครับ....ส่วนเรื่องเสียงไม่รู้ครับ
    VIA Vinyl? VT2021
    Intel High Definition Audio Specification Rev.1.0 Compliant
    Exceeds Microsoft Windows Logo Program (WLP) Requirements
    High-performance ADCs with 100dB SNR, DACs with 110dB SNR Various Output Format
    5 Stereo DACs Output Pairs supporting 16/20/24-bit, 48/96/192/44.1/88.2 kHz sample rate
    2 Stereo ADCs supporting 16/20/24-bit, 44.1K/48K/96K/192KHz sample rate
    2 independent 16/20/24-bit S/PDIF TX Outputs supporting 48K/96K/44.1K/88.2 KHz sample rate
    威盛電子為開發智能車載、工業、邊緣和建築解決方案的全球領導品牌。
    ALC898
    High performance DACs with 110dB signal-to-noise ratio (A-weighting)
    High performance ADCs with 104dB signal-to-noise ratio (A-weighting)
    Meets Microsoft WLP3.x (Windows Logo Program) audio requirements
    Ten DAC channels support 16/20/24-bit PCM format for 7.1 sound playback, plus 2 channels of concurrent independent stereo sound output (multiple streaming) through the front panel output
    Three stereo ADCs support 16/20/24-bit PCM format, multiple stereo recording
    All DACs support 44.1k/48k/88.2k/96k/192kHz sample rate
    All ADCs support 44.1k/48k/88.2k/96k/192kHz sample rate
    ALC892
    Hardware Features
    DACs with 95dB SNR (A-weighting), ADCs with 90dB SNR (A-weighting)
    Ten DAC channels support 16/20/24-bit PCM format for 7.1 channel sound playback, plus 2 channels of concurrent independent stereo sound output (multiple streaming) through the front panel output
    Two stereo ADCs support 16/20/24-bit PCM format, multiple stereo recording
    All DACs supports 44.1k/48k/96k/192kHz sample rate
    All ADCs supports 44.1k/48k/96k/192kHz sample rate
