Originally posted by CMS
Dimensions (WxDxH) / Weight Details Satellite speaker : 8.1 cm x 9.2 cm x 11.1 cm / 0.5 kg
Centre channel speaker : 19.4 cm x 9.5 cm x 8.3 cm / 0.8 kg
Subwoofer : 30 cm x 31 cm x 31.5 cm / 7.2 kg
Speaker System
Media Type 5 speakers, subwoofer
Speaker Type Active
Nominal (RMS) Output Power 185 Watt
Response Bandwidth 55 - 20000 Hz
Signal-To-Noise Ratio 80 dB
Audio Amplifier Integrated
Connectivity Technology Wired
Built-in Decoders Dolby Pro Logic, Dolby Digital, DTS decoder
Controls Input selector, 3D on/off, mute, volume, treble, bass
Additional Features Auto power on/off, satellite magnetic shield
Speaker System Details
Speakers Included 4 x satellite speaker - 2-way - 25 Watt - 120 - 20000 Hz - 4 Ohm - wired
1 x centre channel speaker - 2-way - 25 Watt - 120 - 20000 Hz - 4 Ohm - wired
1 x subwoofer - 60 Watt - 40 - 160 Hz - wired
Driver Details Satellite speaker : 1 x midrange driver - 75mm - paper
Satellite speaker : 1 x tweeter driver - 12mm
Driver Details Centre channel speaker : 2 x midrange driver - 75mm - paper
Centre channel speaker : 1 x tweeter driver - 12mm
Driver Details Subwoofer : 1 x subwoofer driver - 165mm - paper
Connections
Connector Type 1 x SPDIF input ( TOS Link )
1 x SPDIF input ( RCA phono )
2 x audio line-in ( RCA phono x 2 )
Miscellaneous
Cables Included Audio cable
Audio (digital) cable
Speaker cable kit
Included Accessories Mounting hardware, IR receiver
Remote Control Remote control - infrared
Power
Power Device Power supply - internal
Power Consumption Operational 80 Watt
เครดิตรายละเอียดยกให้ท่าน Camera เลยครับ
