ลำโพงคอมพิวเตอร์เทพๆ
  • ลำโพงคอมพิวเตอร์เทพๆ
    ตัวแรก magnepan ลำโพงแผ่น เสียงเสมือนมีคนออกมายินร้องเพลงอยู่ตรงหน้า
    Magnepan Mini Maggie desktop speaker system
    Type: 3-way planar magnetic/true ribbon speaker system
    Frequency Response: 40Hz ? 40 kHz
    Sensitivity:
    ? Desktop satellite modules: 86 dB/500Hz/2.83V
    ? Mid/bass module: 86 dB/50Hz/2.83V
    Impedance: 4 Ohms, satellite and mid/bass modules
    Dimensions:
    ? Desktop satellite modules (H x W x D): 14? x 9? x 1.25?
    ? Mid/bass module (H x W x D): 19.25 x 22.5? x 1.25?
    Weight (complete three-piece system): 41 lbs.
    Warranty: Limited Three-year, to original owner
    Standard System Price: $1490
    ตัวที่สอง kef x-300a ด้วยการออกแบบที่เสมือนมีดอกลำโพงดอกเดียว ทำให้เสียงทุกย่านเดินทางจากตำแหน่งเดียวกัน
    Introducing the KEF X300A digital hi-fi speaker system, an active design conceived to partner a PC or Mac, desktop or laptop computer. Simply connect the speakers via a ?distortion free? USB all-digital link to provide high resolution 96kHz/24 bit quality digital input and inter-speaker connection to ensure high definition sound from source to output. Each speaker features twin class AB audiophile grade amplifiers inside, one for HF and one for LF/MF. Featuring high performance toroidal transformers and high quality DACs, with the X300A you don?t need to be an expert to enjoy audiophile sound quality.
    System type
    Two-way bass reflex
    Drive units
    Uni-Q driver array:
    HF: 25mm (1in.) vented aluminium dome
    LF/MF: 130mm (5.25in.) magnesium/
    aluminium alloy
    Frequency response
    (+/- 3dB)
    58Hz - 28kHz
    Frequency range
    (- 6dB)
    49Hz - 45kHz
    Max peak SPL
    104dB
    Amplifier type
    Twin Class AB
    Amplifier power
    LF: 50W
    HF: 20W
    AC power input
    US/JP versions: 100-120 VAC, 50/60 Hz
    EU/UK/China versions: 220-240 VAC, 50Hz
    Analogue input
    AUX: 3.5mm stereo jack
    Digital input
    Resolution
    Sampling rate
    USB 2.0: mini USB type B connector
    Up to 24-bit
    Up to 96kHz, depending on source resolution
    Controls
    Balance control
    System volume control
    Internal volume
    4.7 l
    Finish
    Gunmetal
    Dimension
    (H x W x D)
    Without heatsink:
    280 x 180 x 215mm (11.0 x 7.1 x 8.5 in.)
    With heatsink:
    280 x 180 x 243mm (11.0 x 7.1 x 9.6 in.)
    Weight
    7.5kg (16.5lbs) per speaker
    It is recommended that the X300A be used with Windows 7 and Mac OS 10.6 & above operating systems.
    Experience authentic audio with KEF award winning HiFi speakers, headphones, home theatre speakers and more. Visit KEF now.
