New Release : foobar2000 version 1.1.12
  • New Release : foobar2000 version 1.1.12
    Change Log
    • Fixed Musepack HTTP streaming bugs.
    • Fixed incorrect MP3 decoder behavior on certain rare files.
    • Fixed crash reporter dialog crash (duh).
    • Detection of proxy server settings from Internet Explorer.
    • Fixed multi-channel FLAC encoding (channel mask now gets preserved).
    • Fixed multi-channel WavPack decoding (channel mask now gets preserved).
    • Now possible to use HDCD & DTS decoder components with ALAC.
    • Changed MP3 tag reading behaviors when multiple tags are present.
    • ID3v2 content now takes priority over APE and then ID3v1.
    • Various time-consuming operations such as conversion or ReplayGain-scanning now prevent the computer from automatically going to sleep (opt-out).
    • Tuned ReplayGain scanner for fast multicore CPU / slow HDD scenarios (beta 4).
    • Fixed Converter misbehavior on files with misplaced ?cuesheet? tags (beta 4).
    • Improved performance when playing MP3 files from internet HTTP sources (beta 4).
    • Improved compatibility with Apple's HFS driver (beta 4).
    • ID3v2 handling improvements (beta 5):
    • Fixed TXXX field name sometimes incorrectly written.
    • No longer possible to write multiple values per ID3v2.3 frame in various scenarios.
    • Improved ID3v2.3 specification compliance for TXXX and TCON (genre) frames (beta 6).
    • COMM frames with a description now show as ?COMMENT <description>?.
    • Certain broken APIC (cover art) frames are now visible.
    • APEv2 tag writing: relaxed tracknumber/discnumber field content restrictions (beta 5).
    • Fixed Converter having trouble locating oggenc.exe (beta 6).
    • Fixed WAV handling exploits affecting versions 1.1.9-1.1.12b6.
    • Thanks to FuzzMyApp for the report and samples.
    • Files with .M4R (MP4 ringtones) extension are now recognized (1.1.12 final).
    • Fixed incorrect handling of hidden files with certain Media Library configurations (1.1.12 final).
    Download : http://www.foobar2000.org/files/40d1...00_v1.1.12.exe
    นี่แหละ active version ผมชอบนะ แม้ว่า บางอย่างจะลดลงก็เถอะ เปลี่ยนเวอร์ชั่น ได้อย่างเสียอย่าง
    ร้องชัดขึ้น กระชับ แต่ ยานครางน้อยลงนี่แหละ แปลกๆไปไงไม่รู้
      Hot fix: foobar2000 v1.1.12a ออกตามมาติดๆ เลยครับ
      2012-05-27
      Hot fix: foobar2000 v1.1.12a has been released. This version corrects a regression in 1.1.12 final.
        ยังใช้ 1.1.1 อยู่เลยคร้าบ -*-
          foobar2000 change log - version 1.1.13
          1.1.13
          Fixed ID3v2 regressions from version 1.1.12
          Fixed playback-getting-stuck bugs with fade-on-track-advance enabled.
          ID3v2 compliance changes: multiple TXXX allowed again, semicolon used for multiple genre separator.
          Changed ID3v2.3 TYER/TDAT handling, now merged into one DATE field formatted as YYYY-MM-DD.
          Beta ออกอีกแล้ว
            มาบ่อยจัง
              ออกโคตรบ่อย
                ตอนนี้ออก Final มาละครับ
                  *0* ออกเร็วแท้ ครับ
