Tipard Video Converter for Mac enjoys a high reputation, which can convert all video formats to the formats you want with unmatched speed and perfect output quality, like convert AVI, MP4, MPG, MOD, TOD, MOV, MKV, WMV, DivX, XviD, MPEG-1/2, 3GP, 3G2, VOB, MPV, FLV, and HD videos. It is definitely a great way for mac users to enjoy favorite video on many types of portable player with this mac video converter.
Step 1: Load video file
After installation, you will see the the following screenshot.
Load any video file you want to convert by clicking "Add Video" option under the "File" menu. Or you can click the "Plus" image button in the main interface.
Step 3: Choose output format
Based on the formats supported by your portable devices, you can select the output format for the movie from the "Profile" column and set the destination folder. Also you are allowed to select your preferred audio track and subtitle for your video.
Detailed video and audio settings are provided by this DVD Ripper for Mac for you to adjust, such as video Encoder, Frame Rate, Resolution, Bitrate and audio Encoder, Channels, Bitrate, Sample Rate, etc. Even more, you can input your own parameters and choose preferred Aspect Ratio. The well-customized profile can be saved as "User-Defined" for your later use.
1. Adjust output video effect
Click "Clip" on the initial interface, and choose "Effect" command after context menu popped up to open the Effect window.
You are allowed to freely drag the Brightness, Contrast, Saturation, Hue and Volume 5 Effect scroll bars to choose the perfect video effect you like best.
2. Trim any video
Click "Clip" on the initial interface, and choose "Trim" command after context menu popped up to open the Trim window.
Tipard Video Converter for Mac provides you two methods to trim your video length.
Method 1: Enter the start time in the "Start Time" box, then enter the end time in the "End Time" box and click OK.
Method 2: Drag the scissors bars under the preview window when you want to trim, then the time will be shown in the Start Time box and End Time box for your reference.
After you set the trim time, the length of the captured clip will be shown in the Select Length box for your reference.
Tipard Video Converter for Mac allows you to remove the black edges around your movie video and customize the size of video play region.
3. Crop any video
The crop frame is the yellow line around the movie video. There are eight small adjustment boxes on the crop frame. Each adjustment box allows you to crop the movie video from a different position
Hint: In order to meet various viewing needs of customers, Tipard Video Converter for Mac provides 4 Zoom Modes for you to choose: Letterbox, Medium, Pan & Scan and Full.
Note: After you crop your video and set the Zoom Mode, the result can be previewed in the Preview window of the program main interface.
4.Add a text or image watermark
Click "Clip" on the initial interface, and choose "Watermark" command after context menu popped up to open the Watermark window.
Check the "Enable Watermark" checkbox, then select "Text" or "Picture" radio button to add a text or image watermark to any video as you like.
Using this powerful Tipard video converter for Mac, you can easily convert video on Mac and hope you can enjoy it.
More tools recommend:
Mac dvd ripper
Mac blu-ray converter
Mac HD Converter
2. Trim any video
3. Crop any video
Mac dvd ripper
Mac HD Converter
