http://www.guru3d.com/article/auzentech-cappuccino-ex-sneak-peek/
Auzentech Cappuccino EX Sneak Peek
The audio market is constantly expanding and evolving with new products for the internal and external market places. We always do what we can to bring our readers the latest and greatest information on upcoming audio products for their audio systems. So without further delays, lets get to the good stuff shall we?
Today, from the Guru3D Audio Lab we have our latest exclusive sneak peek of the Auzentech Cappuccino EX external USB 2.0 audio interface.
Please understand these are pictures of an early prototype so features may be added and specifications are subject to change. The information here is of the working design and specifications for Auzentech?s latest audio device.
Based on the received information, the device sports some impressive specifications, offering a high end 24/192 KHz Digital to Analog Converter with a 123dB Dynamic range and a THD of 0.0005%.
Let?s take a peek at the great looks of this upcoming external audio device:
Here we can see the .25?/6.3mm headphone output that can support headphones up to 600? impedance using reported premium grade headphone amplification circuitry.
On the opposite end of the Cappuccino EX we have the switchable RCA line level inputs/outputs, Optical/microphone input and the USB connection. The S/Pdif input accepts audio streams up to 24/96 KHz.
This Capo EX supports USB Audio Class 2.0 and high speed mode in Win XP, Vista and Win7. The device also has Mac support for OS X 10.5.7 and later. Let?s check out the controls and indicators:
The working design features touch controls for master volume level on the left. We have function indicators for source, mode and sound on the right. There is also a built in microphone for those that need it and a microphone input for those users that require a higher quality input.
There is no fixed MSRP yet, but there is some talk on the $249.99 price point. As for the release date, Auzentech is targeting early to mid December, hopefully before Christmas of this year.
We know what you are thinking, what output options are supported? This device offers: Direct Sound, WDM, ASIO 2.0, WASAPI and Core Audio Support.
To answer some other typical questions for such devices, this unit can operate in three different modes
For those that are wondering about sampling rate conversion, this device is capable of bit perfect/auto-sample rate adjustment; asynchronous resampling or the device operates as a headphone amplifier. This device also has its own proprietary USB driver.
Let?s take a look at the working feature set for the Cappuccino EX:
We have to wrap this up for now, but stay tuned to Guru3D for more info on this device and other exclusives as they become available. We are looking forward to the official review of this great looking unit and will bring you that article as soon as we can.
Until next time, this is Robscix rocking on in the Guru3D Audio Lab.
- 1. USB PC Sync
- 2. Hi-Fi DAC
- 3. Headphone Amplifier
- Compact size and Full aluminum finished exterior design
- USB2.0 High-speed / Full-speed mode compatible mini-USB port with HD Audio Processor
- Supports stereo Playback up to 24-bit/192kHz
- 1/4" stereo phone jack for professional headphones with Premium grade Headphone amplifier
- Supports wade range impedance headphones up to 600? (@High performance power plan)
- USB bus powered operation.
- Optical S/PDIF input up to 24-bit/96kHz via 3.5mm combo jack
- Selectable stereo RCA connector for line input or line output
- Built in high quality internal condenser microphone
- High-end quality Audio Convertors: 123dB dynamic range, ultra-low distortion 0.0005%, 24-bit/192kHz, DAC
- - 98dB dynamic range, 24-bit/96kHz ADC for microphone
- Asynchronous sample rate convertor with independent low jitter PLL for master audio clock
- Touch panel Volume/Level controller and Function switches on side panel
- 8 multi-function status indicator LEDs
- High performance operational amplifiers and Volume control (123dB dynamic range)
- Premium quality audio parts
- 3 Basic Operation Modes (USB PC Sync, Hi-Fi DAC, Headphone Amplifier)
- Proprietary Auzentech analog technology including Pointing Ground Design?, X-Balance Power Generation System?
- Supports USB Audio Class 2.0 and high-speed mode on Windows? XP, Vista and Windows? 7, Mac OS X 10.5.7 later
- WDM, DirectSound, ASIO2.0, WASAPI and Core Audio support
