Uni xonar 1.41มาแล้ว ยังปวดหัวกันเหมือนเดิม
  • Uni xonar 1.41มาแล้ว ยังปวดหัวกันเหมือนเดิม
    มันมาตั้งแต่เดือนที่แล้ว แล้วล่ะ เพิ่งเข้าไปดู
    ฐานมาจากไดร์เว่อร์asus 1794
    Release notes 1.41
    - Thanks to Virus , the driver signature errors should now be fixed. Big thanks to him for figuring it out & fixing this.
    Release notes 1.40
    Still couldn?t figure out what is causing the driver signature errors. If you still encounter those errors with this version, you should try the alternate driver package (UNi Xonar 1794 v1.40_ alt.exe), which has all the files in the original form . The only change is that this will use the old Asus & Cmedia Panel tray icons.
    - Sadly, the Dynamic volume when there are 2 active sound sources issue is still there. <<< โคตรเซง อ่านต่ออีกquote
    - Includes a newer version of the C-Media Panel, which has ASIO Panel option when right clicking the tray icon.
    - Includes ASIO 2.0.0.7
    Change log from Asus:
    1. Fix playback issue when using Sequel2 with ASIO setting.
    2. Fix GX version error issue.
    3. Fix the error message ?CmEnhance.exe stop working? may pop out during the driver installation.
    4. Fix compatibility issue with ?Call of duty:world at war?.
    27 Dec 2010 - Dynamic volume when there are 2 active sound sources.
    Description: When playing a game and listening also to music, the music volume will lower down when there is a high noise coming from the game (explosions for example). I first noticed this issue in 1780 drivers, but it was kinda fixed in the later versions. I say Kinda because I recently noticed this again with 1792 drivers (Uni v1.27) .
    Fix: I noticed that this issue only present when the windows/panel volume is above 80-90%. So my recommendation is to not exceed this limit.
    Please note that moving the mixer playback sliders in Asus Control Panel above ?76? or digital volume sliders in C-Media Control Panel above ?0? dB will cause the same issues.
    ปล. เคยลองแบบนี้กับversionเก่า (อันใหม่ยังไม่ได้ลอง)
    ทดสอบvolumne ทีaudio center ดู ถ้าปรับไว้ 70 ,80,90 เทียบกัน แล้วเปิดโปรแกรมเล่นเพลง ไปปรับชดเชยvolumneในโปรแกรมเล่นเพลงเอา
    เสียงมันดันไม่เหมือนกัน
    อืม...
