สเปค และ ราคา Onkyo DV-BD507
8ONKYO : DV-BD507
ราคา 23,900 บาท
ADVANCED FEATURES
Plays BD-Video, BD-R/RE, BD-ROM, DVD Video, DVD±R/RW, DVD±R DL, Audio CD, CD-R/RW*1
Plays AVCHD (Encoded on SD/SDHC/MiniSD/MicroSD Card, DVD±R/RW, or DVD±R DL), MP3, JPEG, DivX®, and DivX® HD Formats
HDMI™ 1.3a to Support 1080p, Deep Color™, x.v.Color™, and CEC
1080p/24fps Output for Full-HD Movies
Upscaling of All Standard-Definition DVD Sources to 1080p (1080i, 720p, and 480p)
Dolby® TrueHD, Dolby® Digital Plus, and DTS-HD Master Audio™*2 Decoding
BD-Live (Profile 2.0) for a More Interactive Experience
Ethernet Port for BD-Live Functionality
Parallel Output of HDMI and Component Video
Picture in Picture Video and Audio Configuration (BD Only)
Rapid Video Playback with Audio (1.3x Speed)
Preset Video Adjustments for Sharpness, Contrast, Brightness, Gamma Correction, Color, Black Level, and Noise Reduction*3
*1 Discs that have not been properly finalized may be unplayable or only partially playable.
*2 DV-BD507 supports DTS-HD Master Audio Essential.
*3 Noise reduction is available for DVDs only.
OTHER FEATURES
DTS Digital Surround® and Dolby® Digital Decoding
150 MHz/12-Bit Video DAC
192 kHz/24-Bit Audio DAC
Audio, Component, and Composite Video Outputs
2 Digital Outputs (Optical and Coaxial)
SD/SDHC Memory Card Slot for Media Content*1
Disc Playback Modes: Fast Forward/Fast Reverse/Slow Forward/Step by Step/Repeat (Chapter/Title/Track/Group/All)/A-B Repeat/Program/Random/Rapid/Angle
Onscreen Display for Settings and Playback (Auto*2, English, French, Spanish, German, Italian, Dutch, Swedish, Portuguese, Polish, Norwegian)
Display Dimmer (Auto/Bright/Dimmer)
Full-Function Remote Control
*1 Handles SDHC up to 8 GB
*2 The language is selected automatically to match that used by the HDMI-connected display.
GENERAL SPECIFICATIONS
Frequency Response:
BD 4 Hz–88 kHz (192 kHz)
DVD Linear Sound 16 Hz–44 kHz (96 kHz), 16 Hz–22 kHz (48 kHz)
Audio CD 16 Hz–20 kHz (44.1 kHz)
WHD: 435 x 69.3 x 310 mm
Weight: 3.0 kg
มา:HDPLAYERTHAILAND.COM
ราคา 23,900 บาท
ADVANCED FEATURES
OTHER FEATURES
Frequency Response:
Weight: 3.0 kg
