ผมโหลด Bolt 3D มาดูในโปรแกรม MPC ดูแล้วภาพมันเป็นแบ่งเป็นสองส่วนตามภาพ
ปรกติเคยเห็นแต่ 3D ที่เป็นสี แดง น้ำเงิน เขียว หรือว่ามันเป็น 3D แบบใหม่ ถ้าจะดูต้องใช้แว่นแบบไหนดูครับ
Bolt 3D 2008 BluRay FULL SBS DTSHD x264 dxva-EuReKA
Hardware and software needed to play these encodes:
Hardware:
- HDMI 1.4 3D Television
- HDMI 1.4 Video Card (AMD/ATi 6000 series + nVidia 400 series, except models 465-480)
Software:
- nVidia 3D Vision Video Player (use ffdshow as h.264/AVC decoder)
Using other players like MPC-HC is possible, but will not give you the full-HD experience.
E u R e K A
General Info
IMDB link......: http://www.imdb.com/title/tt0397892/
Length.........: 96 minutes
Size...........: 7.50 GB
Technical Specs
Container...........: Matroska
Video Encoder.......: x264
HD-Resolution.......: 1920x1080 for every eye (3840x1080 in total)
Video...............: 23.976 fps, average bitrate of 17.7 Mbps
Audio Codec.........: DTSHD MA / English / 5.1 channels / 48 kHz / 16-bit
Subtitles...........: English + Dutch
Extra info:
I didn't use one-button software to do this encode, but did every step manually, to end up with an optimized encode.
To be able to use this encode, you need a 3D Ready television, that is able to process full side-by-side (full-sbs) video. Next to that you also need shutter glasses.
One way I'm sure of to be able to use the subtitles, is the use of ffdshow. Activate it, select "Stereoscopic" in the 'Placement' sub-category and adjust the 'Parallax' setting, to get clear looking subtitles.
IMPORTANT: On my Samsung PS63C7700 plasma I have to play with the left-right setting (change and change back), to get the wanted 3d effect. Do the same on your television, in case the 3d effect is missing, or looks odd.
Hardware:
Software:
E u R e K A
General Info
Technical Specs
Extra info:
