รบกวนสาวก JBL ตอบผมทีครับ
  • รบกวนสาวก JBL ตอบผมทีครับ
    ผมอยากได้ JBL e90 มือ 1 และส่วนประกอบต่างๆที่ทำให้มันใช้ได้กับ Notebook ของผม
    และผมต้องใช้งบเท่าไรครับ
    ขอบคุณล่วงหน้าสำหรับข้อคิดเห็นครับ
    ปล.ผมไม่ค่อยมีความรู้กับลำโพงระดับนี้ซักเท่าไร
    The good: Towering full-size speaker; three-way design featuring two 8-inch woofers, 4-inch midrange, and 0.75-inch tweeter; dual binding posts.
    The bad: Stereo imaging lacks depth; not quite as hefty as some towers.
    The bottom line: JBL's big speaker sound offers a truly visceral home-theater or music experience.
    Review:
    Not so long ago, retro sound and a macho visual presence were considered the only virtues of heavyweight floor-standing speakers, and buyers turned instead to pip-squeak satellite/subwoofer systems. But today, tallboys are making a comeback thanks to the growing popularity of Super Audio CD and DVD-Audio. Smaller speakers squander most of the sonic advantages of specialized recordings; that's why professionals always mix and monitor with large full-range models. To fully appreciate their handiwork, you need big, all-American speakers such as JBL's E90, listed at $399 each.
    Product Type Left / right channel speakers .Width 9.9 in .Depth 14.5 in .Height 40.2 in .Weight 48.1 lbs .Available Body Colors Black ash, beech, cherry .Speaker System
    Speaker Type 3-way - Passive .Nominal (RMS) Output Power 110.0 Watt .Max (RMS) Output Power 440.0 Watt .-3dB Frequency Response -19964.0 Hz .Input Impedance 8.0 Ohm .Sensitivity 91.0 dB .Crossover Frequency 4000Hz,
    300Hz .Output Features Bass Reflex .Magnetic Shield Yes .Connectivity Technology Wired .Recommended Placing Floor-standing .Detachable Grilles Yes .Additional Features Gold-plated connectors,
    Bi-wiring .Speaker System Details
    Speakers Included Right/left channel speaker - 3-way - 110.0 Watt - -19964.0 Hz - 8.0 Ohm - Floor-standing - Wired .Driver Details Right/left channel speaker : 1.0 x Tweeter driver - 0.75 in - PolyPlas (polymer-coated cellulose fiber),
    Right/left channel speaker : 1.0 x Midrange driver - 4.0 in - PolyPlas (polymer-coated cellulose fiber),
    Right/left channel speaker : 2.0 x Woofer driver - 8.0 in .Miscellaneous
    Remote Control None .AV Furniture None .Power
    Power Device None .Battery
    Type None
    ดูรูป
      แล้วผมจะหาราคาที่แน่นอน..
      และหาซื้อได้ที่ไหนครับ
      มีความเห็นจากท่านอื่นไหมครับ
        ดันครับๆๆๆๆๆๆๆๆๆๆ
        ขอคำแนะนำหน่อยครับบบบบ
          ดันครับบบบบ
