ลำโพงคอมพิวเตอร์ 2.1 ระดับเทพ
  • ลำโพงคอมพิวเตอร์ 2.1 ระดับเทพ
    Dynaudio MC 15
    Connecting the MC 15 is simple: An RCA cable is first connected from the analogue output of a media player, mobile phone, or PC soundcard to each speaker, then the power cable for each MC 15 is plugged in. That’s it. Add a dedicated pre-amplifier or multi-channel audio/video processor and even more applications are possible, even a compact but very capable high-end surround system can be comprised.
    On the rear terminal of the speaker, input sensitivity (in addition to the source’s volume control) can be selected from three settings, and bass, midrange and treble adjustments can also be made.
    The matching Dynaudio Sub 250 MC subwoofer is available for deeper, more powerful bass extension down to the lowest notes.
    Features
    – Compact active monitor loudspeaker for multimedia listening
    – Two integrated 50 watt amplifiers
    – Soft dome fabric tweeter for smooth high frequency response
    – MSP mid/bass driver for powerful mid and low frequency response
    – Analogue RCA input (gold plated) for flexibility and easy connection to audio sources
    – Adjustable for various applications and listening positions (variable high pass filter,
    3-band-equalizer, input sensitivity)
    – Solid metal angling plinth for optimising dispersion (included)
    – Expandable via additional MC 15 loudspeakers
    – Bass response may be augmented through a Subwoofer (optional)
    – Detachable cloth grille (included)
    – Detachable power cord (included)
    Technical Specifications
    System Two-way active speaker
    Frequency Response 55 Hz – 21 kHz (± 3 dB)
    Input Level 16 dBu RMS (85 dB SPL @1 m)
    Input Impedance 100 kΩ
    Input 1x RCA
    Power Consumption Max: 90 W
    Amplifier Power Tweeter: 50 W / Woofer: 50 W
    Box Principle Bass reflex
    Resonance Frequency 58 Hz
    Crossover Frequency 1500 Hz
    Internal Cabinet Volume 4.8 liters
    Weight 7.0 kg
    Dimensions (W x H x D) 170 x 260 x 235 mm
    6.7 x 10.2 x 9.3"
    49,999.- บาท
    Dynaudio Sub 250 MC
    Features
    – Active Subwoofer with multimedia compatibility
    – 24 cm woofer with 100 mm pure aluminium voice coil
    – Integrated 140 watts amplifier
    – Automatic Standby/Power
    – Selectable (Master/Slave) for standalone or multiple subwoofer configurations
    – Adjustable low-pass filter (50 Hz - 150 Hz)
    – Adjustable phase (0° / 180&deg
    – Satellite output with selectable high-pass filter (flat / 60 Hz / 80 Hz)
    Frequency Range 29 - 250 Hz
    Amplifier Power 140 W
    Sat-High-Pass Filter Flat/60/80 Hz
    Low-Pass Filter Flat, 50 - 150 Hz
    Phase adjustment 0° or 180°
    Input/Output 4 x RCA / 2 x RCA
    Drive Unit 10" (24 cm), long throw
    Bass Principle Sealed
    Power Consumption max. 325 W
    Standby 14 W
    Weight (net.) 10 kg
    Dimensions (W x H x D) 289 x 294 x 318 mm
    11.4 x 11.6 x 12.5"
    24,950.- บาท
    โอ๊!!! ท่าทางเสียงเทพน่าดู
      ถึงสวรรค์แน่นอนรับรอง
      เป็นหนึ่งในยี่ห้อลำโพงระดับพระกาฬ (Totem, Proac, Focus, Dynaudio)
      Dynaudio ในรถยนต์ก็มี ได้ข่าวว่าหาแอมป์ขับยากมาก
        ราคาเทพมาก....
          75k ไหนจะค่าสายอีก= =
            Dynaudio ดอกวูฟเฟอร์เป็นเอกสักษณ์จริงๆ สวยงาม
              -.- จะคุ้มไหมน้อ เมื่อเทียบกับลำโพงบ้าน
                โอ๊ว
                  เหอๆ ราคาครึ่งค่อนแสน -*- ENZO 600 + X-Fi XtremeMusic ของผมเทพพอแระ
                  สำหรับหูสนิมอย่างผม ถ้ามีตังครึ่งค่อนแสนก็คงเอาไปทำอย่างอื่น ไม่กล้าเอามาซื้อลำโพงง่ะ
                    หุหุ
                      แค่ตัวนี้ก็พอ เสียงใช้ได้เลยทีเดียว Focal XS
                        โฮ่ Dynaudio
                          เห็นแล้วอูย เพงกว่าทั้งเซ็ตเราอีก งืมๆ
                            แพงกว่าคอมผมที่ใช้อยู่อีกนะ -*-
                              เป็นประธาน วัดได้หลายที่เลย ^^
