Onkyo Wavio Soundcard SE-200PCI LTD Price: US $299.00
Windows XP, Vista, & Win7 compatible.
Top of the line sound card for true Audiophiles. Onkyo Quality. 10th Anniversary Limited Edition full-size model.
True Hi-Fi fidelity for your computer music available only with this hi tech card.
Direct import from Japan. MADE IN JAPAN!
* Signal-noise ratio: 115dB(2CH ANALOG OUT)
* Frequency characteristic: 0.3Hz~88kHz(2CH ANALOG OUT,+0/-3dB )
* Digital IN sampling frequency: 32, 44.1, 48, 88.2, 96kHz
* Digital OUT sampling frequency: 32, 44.1, 48, 88.2, 96, 176.4, 192kHz
* Hardware requirement:
o Corresponding type PCI (the Ver. 2.1 or more) the PC/AT compatible machine which has the bus slot
o OS: WindowsR2000 professional (SP3 a výše), XP (SP1 a výše), Vista (None of them corresponds to 64bit edition); System manager authority (Administrator) with only it is enabled
o Processor: 32 bits (x86) or 64 bits (x64) processor; Above 800MHz (2000/XP), above 1GHz (Vista)
o Memory: Above 128MB (2000/XP), above 1GB (Vista)
o In addition: CD-ROM drive (necessity at time of software installation)
* Input:
o ANALOG IN x 2 (stereo RCA, internal connection)
o MIC IN x 1 (φ 3.5mm/monaural)
o DIGITAL IN x 1 (light)
* Output:
o 2ch ANALOG OUT x 1 (stereo RCA)
o DIGITAL OUT x 1 (light)
o 7.1ch ANALOG OUT (Front L/R, Center, Surround L/R, Surround Back L/R and Subwoofer)
* Dimensions: (mm) 22 (w) x 121 (h) x 163 (d)
* Weight: 200g
* Package contents:
o SE-200PCI LTD itself, RCA stereo pin - RCA stereo pin cord/code (0.8m/1 book) and multiple input/output cord/code (1), optical digital cable (1.0m/1 book), installation CD-ROM and instruction manual, guarantee, customer card,
* Input:
* Output:
* Weight: 200g
* Package contents:
