Analog Output Level and LPF (LPF = Low Pass Filter)
The signal level of the DAC differential-voltage output {(VOUTL+)(VOUTL), (VOUTR+)(VOUTR)} is 3.2 Vp-p at 0 dB (full scale).
The voltage output of the LPF is given by following equation:
VOUT = 3.2 Vp-p × (Rf /Ri)
Here, Rf is the feedback resistor in the LPF, and R3 = R4 in a typical application circuit. Ri is the input resistor in the LPF, and R1 = R2 in a typical application circuit.
Op Amp for LPF
An OPA2134 or 5532 type op amp is recommended for the LPF circuit to obtain the specified audio performance. Dynamic performance such as gain bandwidth, settling time, and slew rate of the op amp largely determines the audio dynamic performance of the LPF section. The input noise specification of the op amp should be considered to obtain a 113-dB S/N ratio.
เสริชเจอพาวเวอร์ซัพพลายAntec รุ่นTPQ-1200 Over Clocking Version เค้าใส่ตัวเก็บประจุเพิ่มที่ปลายสายด้วย โดยใช้ชื่อ"PowerCache"
เวปไทยมีรีวิว > Vmodtech.com
