ชักลังเล เปลี่ยนค่ายดีกว่ามั้งเรา -*-
รวมมิตร-รวมหมู่ กระทู้ชาว Microlab
National Semiconductor Corporation LM4766Originally posted by Wizardmans View Postตัวpro1 ใช้ic ภาคขยาย เบอร์อะไรครับ
Features
• SPiKe Protection
• Minimal amount of external components necessary
• Quiet fade-in/out mute mode
• Non-Isolated 15-lead TO-220 package
• Wide Supply Range 20V - 78V
Description
The LM4766 is a stereo audio amplifier capable of delivering typically 40W per channel with the non-isolated "T" package and 30W per channel with the isolated "TF" package of continuous average output power into an 8 load with less than 0.1% (THD+N).
The performance of the LM4766, utilizing its Self Peak Instantaneous Temperature (°Ke) (SPiKe™) Protection Circuitry, places it in a class above discrete and hybrid amplifiers by providing an inherently, dynamically protected Safe Operating Area (SOA). SPiKe Protection means that these parts are safeguarded at the output against overvoltage, undervoltage, overloads, including thermal runaway and instantaneous temperature peaks.
Each amplifier within the LM4766 has an independent smooth transition fade-in/out mute that minimizes output pops. The IC's extremely low noise floor at 2µV and its extremely low THD+N value of 0.06% at the rated power make the LM4766 optimum for high-end stereo TVs or minicomponent systems.
Key Specification
THD+N at 1kHz at 2 x 30W continuous average output power into 8 0.1% (max)
THD+N at 1kHz at continuous average output power of 2 x 30W into 8 0.009% (typ)
Applications
• High-end stereo TVs
• Component stereo
• Compact stereo
งดแรงชั่วคราว
น่าลองน่ะท่านOriginally posted by GuDIEHARD View Postชักลังเล เปลี่ยนค่ายดีกว่ามั้งเรา -*-
แว๊ก...ก มาไงเนี๊ยะ...Originally posted by tor_za View PostNational Semiconductor Corporation LM4766
Features
• SPiKe Protection
Description
Key Specification
Applications
• Component stereo
• Compact stereo
นั้นสิOriginally posted by veza View Postจากภาพสังเกตว่าห้องลองลำโพงบ้านท่านต่อมันเรียบร้อยเกินไปนะ ^^ ทุกทีมันไม่ใช่แบบนี้หนิท่านsigpic
งดแรงชั่วคราว
ไปห้อง 385 นะดีกว่า มีอะไรดีกว่าห้องเจ๊เยอะOriginally posted by sierra View Postงั้นเราก็ต้องไปช่วยกันทำให้เหมือนเดิมละกันเนอะ
ไปห้องเจ๊ก็มีแต่อะไรก็ไม่รู้ สิงโตตัวน้อย ลำโพง สายสัญญาณ พูดแล้วปวดหัว มีแต่เรื่องเสียเงิน เอิ้กๆๆ
ไม่รู้อะไรดลใจทำให้ผมไปห้องเจ๊วันนั้น ว่าจะเลิกเล่นแล้ว แต่แล้วมันก็ทำให้ความคิดในหัวสมองเมื่อสิบกว่าปีที่แล้วย้อนกลับมา เอิ้กๆๆ
แต่พอไปเห็นสาวห้อง 385 เท่านั้นแหละ ใจแทบจะละลาย อิอิ จะทำตัวยังไงดี อิอิLast edited by tor_Za; 6 Dec 2009, 02:25:33.sigpic
งดแรงชั่วคราว
ขอบคุณครับOriginally posted by tor_za View PostNational Semiconductor Corporation LM4766
Features
SPiKe Protection
Description
Key Specification
Applications
High-end stereo TVs
Component stereo
Compact stereo
มองหาทิศทางความบันเทิง
เหอะๆ ใจละลาย ก๊ากๆๆๆOriginally posted by TSP024 View PostAvatar นี้เป็นไงบ้างจร๊ะ...ไม่ถูกใจเปลี่ยนแม่นอีก 555
นี่มันกระทู้ลำโพงน่ะเนี๊ยะท่าน ๆ พ่อแม่พี่น๊อง
เมียมาทำให้อยากแล้วก็จากไปเซ็งจริงๆเลยsigpic
งดแรงชั่วคราว
