Share an Easy way to Convert MP4 to AVI
  • Share an Easy way to Convert MP4 to AVI
    4Easysoft MP4 to AVI Converter is a powerful MP4 to AVI tool which can convert MP4 files to AVI video and M4V to AVI perfectly and it provides a powerful way to extract audio from MP4 or M4V files to MP3, AAC, M4A ,WAV, etc.
    Want to convert the MP4 files to AVI? This is the best choice.
    It is very easy to use. Just take the following steps, you can finish the conversion.
    Preparation:Download and install 4Easysoft MP4 to AVI Converter
    Step 1.Click “Add File” button add your MP4 vdieo files.
    Step 2:Edit your videos.
    When you are previewing your videos, you can trim your video by clicking “Trim” button, crop your video by clicking “Crop” button, and take snapshot.
    You can also join your files into one by clicking “merge into one files”.
    Click “Settings” button, you are allowed to customize the output parameters, specify output folder and select output format.
    Click “preference” buttun to choose the output destination, snapshot fold,etc
    Step 3: Select output format
    Click the “Profile” button to select the output video format from the drop-down list button.
    Step 4: Start conversion
    Click “Start” button in the right of the main interface, you are allowed to start conversion. All the tasks of conversion will be finished at fast speed and high output quality.
    Key features of this converter:
    1. Supported formats
    This MP4 to AVI Converter offers the AVI, H.264/AVI, M4A, MP3, AAC to support Creative Zen Vision, BlackBerry Bold, BlackBerry Curve, BlackBerry 8800, Archos, etc. from MP4 and M4V files sources with easy procedures.
    2.Split video
    Allow you to capture your favorite video clips from your video sources by setting the exact start and end time, or drag the slider bar.
    3.Merge video
    Join separate files into one file after conversion for you to enjoy successively.
    4.Crop video
    Frame the video play region that you want using this MP4 to AVI Converter like the smart scissors.
    5.Real-time preview and Capture pictures
    Capture your favorite pictures while previewing movies.
    6.More settings for you to customize.
    Detailed video and audio settings are provided by MP4 to AVI Converter for you to adjust, such as Resolution, Video Bitrate, Frame Rate, Audio Channels, Sample Rate, etc.
    7.Easier operation and better quality
    Friendly user interface:
    An intuitively designed user interface brings you more convenience and visual enjoyment.
    Fast speed and high video quality:
    With professional video encoding and decoding technique, 4Easysoft MP4 to AVI Converter brings you the unmatched speed and best video quality.
    8.System Requirements
    Windows NT4/2000/2003/XP and Windows Vista
    Related tools:
    4Easysoft MP4 Converter which is designed to convert almost any video formats to MPEG-4 standard formats, such as AVI to MP4, WMV to MPEG-4, easily and fast is also a good choice.
    4Easysoft Total Video Converter which supports mutual conversion betwwen almost all the video/audio formats is worth having a try as well.
    Just try now.Hope this is helpfull.
    AVI Converter
