USB/Line-In Digital Amplifier ผมเคยเห็นคนใช้ตัวนี้ มันเอาไว้ต่ออะไร-ยังไง แต่เห็นว่ามันเสียบยูเอสบีได้ ราคาไม่แพง 5-6 ร้อย จะเอามาเล่นซะหน่อย
Features
?The best audio quality upgrade equipment for PC audio system
?Combined USB DAC and PWM digital amplifier
?Featured both USB and Line-In inputs
?Can be power supplied just by USB terminal of PC
?Supports Microsoft Windows 98SE/ME/2000/XP and Mac OS X operation systems
?The USB input is USB1.1 and USB2.0 compatible and fits in with the standard of USB1.1 audio equipment
?It provides a LED to show the USB input condition
?It uses the PDA5871S1 chip to convert audio signal into PWM signal and then drive your speaker system
?The power output capability is 1W@5V(4ohm) for each channel
?When using USB input it provides volume control and mute function and can also be controlled on your computer
?When using Line-In input it provides volume control and mute function
?It provides 32-step digital volume control for USB and Line-In inputs respectively
?It provides four initial volume preset (0,9,16 and 31) for the Line-In input
?It provides a LED to display the mute condition
?It also can be powered by an external 5V DC power supply
?It also provides an ear phone output
?All the SMD components have been soldered on the PCB, so the soldering operation is quite easy
Features
