[อยากรู้]เครื่องในรูปนี้ไว้สำหรับทำอะไรหรอครับ
  • [อยากรู้]เครื่องในรูปนี้ไว้สำหรับทำอะไรหรอครับ
    FRONT PANEL
    Instrument Inputs 2 x 6.3mm mono jack sockets, auto-select to analogue inputs 1 & 2 when plugged
    Headphone Outputs 2 x 6.3mm stereo TRS Jacks, each with illuminated volume control
    Master volume Assignable encoder / push switch with halo indication
    Standby button with standby indicator (also flashes when unit is in 'identify' mode)
    Indication:
    Level Meters 10 x multi-segment bargraphs with overload indication, 8 for analogue, 2 for digital, assignable to inputs or outputs
    Input selection Indicate mode of analogue inputs 1-4 as Mic / line / inst & plus phantom power indicator for mic mode
    Overkiller For every analogue input, lit when Overkiller limiters are acting
    Digital Input indicators for digital input unlocked and SRC (sample-rate converter) selected
    Digital Output indicator for SRC (sample-rate converter) selected
    Sync Master indicator, lit when interface is providing system sync
    REAR PANEL
    Mic / Line inputs 1-4 4 x combo connectors with XLR sockets for mic input and 6.3mm TRS jack sockets for line input (balanced or unbalanced)
    Line inputs 5-8 4 x 6.3mm TRS jack sockets (balanced or unbalanced)
    Line outputs 1-8 8 x 6.3mm TRS jack sockets (balanced or unbalanced)
    Digital inputs 1 x RCA
    1 x TOSLINK for S/PDIF or ADAT Optical input;
    (RCA can operate as AES3 input using XLR-RCA adapter supplied)
    Digital output 1 x RCA
    1 x TOSLINK for S/PDIF or ADAT Optical output;
    (RCA can operate as AES3 output using XLR-RCA adapter supplied)
    MIDI I/O 2 x 5 Pin DIN sockets
    (in and out)
    Wordclock 2 x BNC sockets, output and input (75R)
    FireWire ports 2 x FireWire IEEE1394A
    (allowing cascading of multiple units)
    Mains power 3-pin 6A IEC inlet
    SOFTWARE SUPPORT
    Mac OS Support OS X 10.4 or later, PPC or Intel platform
    Windows OS Support Windows XP, Vista or later
    Mac audio driver Core Audio device
    Windows audio driver WDM and ASIO devices
    Control Panel applet Graphical user interface for control of single or multiple Orpheus units under Mac OS X or Windows.
    ANALOGUE LINE INPUTS
    Configuration Electronically balanced, with fully-balanced analogue signal path
    Input Sensitivity Switchable '+4dBu' (0dBFS = +18dBu) or '-10dBV' (0dBFS = +6dBu)
    Input Impedance 14.5kR
    Unbalanced Mode Automatic
    Total harmonic distortion -117dB (0.00014%, -0.1dBFS)
    THD+n -111dB (0.00028%, -0.1dBFS)
    Dynamic Range 116dB (-60dBFS)
    Gain Accuracy ±0.05dB
    LF roll-off -0.05dB at 8Hz; -3dB at <1Hz
    HF roll-off fs = 44.1kHz: -0.05dB at 21.1kHz; -3dB at 22.0kHz
    fs = 48kHz: -0.05dB at 23.0kHz; -3dB at 23.9kHz
    fs = 96kHz: -0.05dB at 32.0kHz; -3dB at 47.9kHz
    fs = 192kHz: -0.05dB at 32.0kHz; -3dB at 78kHz
    CMRR 20Hz..20kHz: >70dB
    Inter-channel cross-talk 1kHz: <140dB; 20Hz..20kHz: <-120dB
    Inter-channel phase 10Hz..5kHz: &#177;0.25&#176;,
    5kHz..20kHz: &#177;1.0&#176;,
    20kHz..50kHz: &#177;2.0&#176;,
    Overkiller Progessive limiter, auto-aligning, selectable per channel
    Impact Filter High-pass filter, -3dB at 80Hz, 40dB/decade (selectable for channels 1-4; whether in line, mic or instrument mode)
    RIAA de-emphasis filter Response accuracy:
    &#177;0.22dB at fs=44.1kHz;
    &#177;0.14dB at fs=48kHz;
    &#177;0.015dB at other sample rates
    M-S matrix Allows direct connection of mid-side mics, or non-matrix mic-preamps (selectable for channels 1-4; whether in line or mic mode)
    MICROPHONE PREAMPLIFIERS
    Configuration Electronically balanced, with fully balanced analogue signal path
    Gain 10dB to 65dB in 1dB steps (0dBFS = -56dBu to -1dBu)
    Gain accuracy &#177;0.05dB
    Input impedance 5.5kR
    THD +10dB gain: -116dB at -0.1dBFS (0.00016%)
    +40dB gain: -110dB at -0.1dBFS (0.00032%)
    THD+n +10dB gain: -108dB at -0.1dBFS (0.00040%)
    Equivalent input noise (EIN) +30dB gain: -128.5dBu (0R source); -126.3dBu (150R source)
    +40dB gain: -130.9dBu (0R source); -127.6dBu (150R source)
    +50dB gain: -131.2dBu (0R source); -127.7dBu (150R source)
    +60dB gain: -131.4dBu (0R source); -127.8dBu (150R source)
    LF roll-off -0.05dB at 20Hz, -3dB at 5Hz
    HF roll-off As per analogue line input data (dependent on fs)
    CMRR 50Hz/60Hz: >110dB at all gains
    1kHz: >100dB at all gains
    20kHz: >90dB at all gains
    Phantom power +48V, switchable per channel
    INSTRUMENT PREAMPLIFIERS
    Configuration Unbalanced, high impedance buffer
    Gain 10dB to 65dB in 1dB steps, 18dB pad (0dBFS = -38dBu to 17dBu)
    Input impedance 1MR
    ANALOGUE OUTPUTS
    Output amplitude Switchable '+4dBu' (0dBFS = +18dBu) or '-10dBV (0dBFS = +6dBu)
    Output impedance 100R balanced, 50R unbalanced
    Unbalanced mode Automatic, with bootstrapping level compensation
    Total harmonic distortion -107dB (0.00045%, -1dBFS)
    THD+n -106dB (0.00050%, -0.1dBFS)
    Dynamic range 115dB (-60dBFS)
    LF roll-off -0.05dB at 8Hz, -3dB at <1Hz
    HF roll-off fs = 44.1kHz: -0.05dB at 21.4kHz; -3dB at 22.0kHz
    fs = 48kHz: -0.05dB at 23.2kHz; -3dB at 23.9kHz
    fs = 96kHz: -0.05dB at 32.0kHz; -3dB at 47.8kHz
    fs = 192kHz: -0.05dB at 32.0kHz; -3dB at 76kHz
    Output balance >50dB
    Inter-channel cross-talk 1kHz: <135dB; 20Hz..20kHz: <-120dB
    Inter-channel phase 10Hz..5kHz: &#177;0.4&#176;,
    5kHz..20kHz: &#177;0.25&#176;,
    20kHz..50kHz: &#177;0.5&#176;,
    DIGITAL INPUTS
    Formats supported S/PDIF (RCA or TOSLink), ADAT, ADAT S/MUX (TOSLink)
    Sample rates supported S/PDIF (2 channel): 44.1, 48, 88.2, 96, 176.4 and 192kHz
    ADAT (8 channel) 44.1 and 48kHz
    ADAT S/MUX (4 channel): 88.2 and 96kHz
    Channel Status ignored
    Word-length 24 bit
    AES3 operation via S/PDIF RCA, using RCA-XLR adaptor (supplied)
    Sample-rate converter (SRC) Selectable at S/PDIF input; allowing input at any sample rate
    Bit transparency Maintained (allows recording of Dolby or DTS streams)
    DIGITAL OUTPUTS
    Channel Status Full implementation, Consumer (S/PDIF) or professional (AES3)
    Word-length 24 bit, or reduction to 16 bits using flat TPDF dither or Prism Sound SNS (Super Noise Shaping - four alternative shapes available)
    Sample-rate converter (SRC) Selectable at S/PDIF output; output rate can be referenced to Wordclock, DI or local clock at 44.1, 48, 88.2, 96, 176.4 or 192kHz
    Bit transparency Maintained in 24 bit mode (allows playback of Dolby or DTS streams to external decoder)
    SYNCHRONIZATION
    System sample rates 44.1 / 48 / 88.2 / 96 / 176.4 / 192kHz
    Sync sources:
    Master local, Wordclock, DI (S/PDIF input) or ADAT
    Slave FireWire bus master (another FireWire interface or Host computer)
    Local clock accuracy &#177;10ppm
    Jitter rejection >60dB / decade above 100Hz
    Internal mixer delay
    (total analogue in to out) fs = 44.1kHz: 0.56ms;
    fs = 48kHz: 0.52ms;
    fs = 88.2kHz: 0.2ms;
    fs = 96kHz: 0.18ms;
    fs = 176.4kHz: 0.09ms;
    fs = 192kHz: 0.08ms;
    PHYSICAL
    Form factor 1u 19inch rack mountable
    (rubber feet and rack ears supplied)
    Dimensions Table top (inc feet):
    W: 440mm D: 290mm H: 50mm
    Rack-mount (inc ears):
    W: 483mm D: 290mm H: 44.5mm
    Power: 90-250VAC, 50/60Hz
    internal power supply
    IEC 6A connector
    Power consumption 35W
    Fuse rating 0.5A(T), 20mm, ceramic
    Weight: 3.7kg
    Operation ambient conditions 0 to 35&#176;C, 85% maximum relative humidity
    Except where otherwise stated, audio performance data are RMS, unweighted, 20Hz..20kHz figures, measured at 997Hz, using fs = 96kHz and '+4dBu' sensitivity settings.
    In keeping with our policy of continual development, specifications are subject to amendment without notice. E&OE.
    All Trade Marks Acknowledged.
    มันคือ Firewire Soundcard (audio interface) ไว้อัด บันทึก monitor ทำเพลง 9ล9
      แล้ว มันราคาแพงมั้ยท่าน
      อัดเพลงได้อย่างเดียว ไม่มีภาคขยายอื่นๆ ที่ ใช้ แบบว่า เหมือน ซาวการ์ดเลยหรือปล่าว
      ตัวนี้ เป็นแบบ
      Pro
      Semi Pro
      Basic
      แบบไหนหรอครับ
      เห้นมันคล้ายๆ แอมป์เลยอ่ะ
          เข้ามาดู และก็อยากรู้ด้วย เอิ๊กๆ
            ออร์เฟียส ของปริซึมซาวด์
            เป็นของโปร ที่อยู่ระดับไฮเอนด์ตัวนึงเลยครับ
            อินพุต เอาต์พุตเยอะ ต่อ ADAT ได้ ที่สำคัญ A/D D/A ของเจ้านี้มีชื่อเสียงมาก
            ที่บอร์ดป๋าติ๊ด ปีก่อนนู้นเคยมีคนมาถามเหมือนกัน
            ผมก็ยังไม่เคยเห็นตัวจริง
            ราคาประมาณ แสนกว่าบาท เกือบ 2แสน
            อ่านที่นี่ได้ครับ
              อ่านที่นี่ได้ครับ
              http://www.patid.com/forum/showthread.php?tid=830
              รีบหามาใช้โดยด่วน
              แต่ อืม....มันจะคุ้มค่าจ้างมั้ยเนี่ย
                Originally posted by noomkorat View Post
                รีบหามาใช้โดยด่วน
                เพื่อนใช้อยู่ครับ เมืองไทยนี่แหละ คุ้มไหม ทำงานสัก สองสามงานก็คุ้มแล้วครับ ไว้ไปห้องอัดอีกทีถ่ายมาให้ดูครับ
