USB to SPDIF & OPTICAL HI-FI Adapter UDA1321/CS8405
  • USB to SPDIF & OPTICAL HI-FI Adapter UDA1321/CS8405
    USB to SPDIF & OPTICAL HI-FI Adapter UDA1321/CS8405 เห็นว่ามันถูกดี 20$ มันคือ แดค อะป่าว
    This product only supports PCM dual mono signal is not supported by AC - 3, DTS, etc Multichannel output
    DIGITAL PCLINK USB-SPDIF Interface uses Philips UDA1321 as USB and digital audio interface and CS8405A as SPDIF encoder.
    UDA1321
    The UDA1321 is a stereo CMOS digital-to-analog bitstream converter. The UDA1321 is an adaptive asynchronous sink USB audio device with a continuous sampling frequency range from 5 to 55 kHz. It contains a USB interface, an embedded microcontroller and an Asynchronous Digital-to-Analog Converter (ADAC).
    The USB interface is the interface between the USB, the ADAC and the microcontroller. The USB interface consists of an analog front-end and a USB processor. The analog front-end transforms the differential USB data to a digital data stream. The USB processor buffers the input and output data from the analog front-end and handles all low-level USB protocols. The USB processor selects the relevant data from the universal serial bus performs an extensive error detection and separates control information (input and output) and audio information (input only).
    The wide dynamic range of the bitstream conversion technique used in the UDA1321 guarantees a high audio sound quality.
    CS8405A
    The CS8405A is a monolithic CMOS device that encodes and transmits audio data according to the AES3, IEC-60958, S/PDIF, or EIAJ CP1201 standards. The CS8405A accepts audio and digital data from the UDA1321, which it then multiplexes, encodes, and drives onto a cable.
    DIGITAL PCLINK USB-SPDIF Interface Features
    * Universal Serial Bus (USB) stereo digital audio interface
    * Adaptive (5 to 55 kHz) continuous frequency sampling range
    * Supports 12 Mbits/s full-speed serial data transmission
    * Supports multiple audio data formats (16 and 24 bits)
    * Fully automatic Plug-and-Play operation
    * High linearity and wide dynamic range
    * Coaxial digital out (Gold plated RCA connector)
    * Optical digital out
    * Supports kmixer bypass via ASIO4ALL and ASIO2KS
    * Using ASIO, bit-perfect digital out can be achieved.
    * Excellent computer as source to connect to external DACs
    CS8405A เขาเรียกว่า interface และ sample rate converter (line driver)
    Block diagram มีแค่นี้ ไม่มี D/A มีแต่ s/pdif encoder
    UDA1321 เป็น DAC สร้างเสียงได้ แต่คงไม่ได้ใช้ในกรณีนี้คิดว่าคงจะรับสัญญาณ usb audio มาแล้วส่งผ่านแบบ I2S ออกไปเลย เพื่อไปยัง CS8405A ส่งออกไปเป็น S/PDIF อีกที
    คุณภาพเสียงคงขึ้นกับ DAC ภายในด้วยนั่นเอง แต่ตัวนี้เก่ามากเลย ปี 1998 นู่นแน่ะ
      ห่วยกว่า pcm2706 2707 pcm 2906 อีกนะ ตัวนั้น CS8405A
      UDA1321 มันธรรมดาๆ นะ สู้ไปหา pcm1794 1700 มาให้รู้แล้วรุ้รอดยังดีเสียกว่า
        สรุปผ่านไปได้เลย
          มันใช้ประโยชน์เพื่อเอาไว้ต่อ usb จากคอม เพื่อไปเข้า DAC ที่รับแต่ coaxial กับ Optic หรือเปล่าครับ
          อย่่างเช่น Zero DAC มันไม่รับ usb อ่ะครับ
            ถูกต้อง แต่มันมีตัวถูกกว่านี้อยู่
              มีสายที่หัวเป็น USB ปลายสายเป็น Coaxial หรือ optic ในเส้นเดียวเลยไม๊ครับ สะดวกดี
              สงสัยไม่มีในโลก
              แล้วตัวที่ว่าถูกกว่านี้ อยู่ประมาณเท่าไหร่ครับ
              แล้วเวลาเอามาเสียบZeroแล้วเนี่ย คอมจะมองเห็นเป็น Dac เลยหรือเปล่าครับ
              หรือต้องลงDriverอะไรหรือเปล่า
